M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      02-23-2013, 06:54 PM   #1
M5DDS
Drives: 2013 BMW M5 (In Production)
Headlight Question
Hey guys. I keep my headlight knob on Automatic at all times. On occasion I'll notice my right cluster inner lamp turns on at night but my left one does not. Are there times when both lamps in each cluster should be on? If so, when and why can't I manually turn both on?
      02-23-2013, 07:25 PM   #2
Warehouser
Warehouser's Avatar
29
Drives: 22 X5M TBlue2
Try adjusting the illumination knob? It only works when the headlights come on.
      02-23-2013, 09:29 PM   #3
M5DDS
I mean the inner headlight bulb. The outer headlights always illuminate, but the inner headlights seem to do as they please.
      02-23-2013, 09:35 PM   #4
Warehouser
Warehouser's Avatar
29
Sorry, thought you were talking about the cluster on the dash.
      02-23-2013, 09:37 PM   #5
mdernst
mdernst's Avatar
37
Drives: Tesla Model S
2013 BMW M5  [0.00]
Those are the cornering lamps. They both come on when you put the car in reverse and the headlamps are on. Otherwise, they come on individually when you're going below 25 MPH and you use the turn signal or when you turn the steering wheel at low speed.
They illuminate the edges of the road in the direction you are turning.
Mike
      02-23-2013, 11:15 PM   #6
M5DDS
Thanks for the info! That explains why I notice one come on and not the other while I turn into my garage.
      02-24-2013, 01:19 PM   #7
cpdp
15
Drives: BMW
what lights are the cornering lights? The inner of the the lights with corona rings is the high beam, isn't it?
      02-24-2013, 01:27 PM   #8
Netwon
Netwon's Avatar
Drives: '12 BMW M5 Alpine White
2012 BMW M5  [0.00]
The two inner most headlamps of the four are the cornering lamps. Not to be confused with the regular headlamps that can turn during cornering!
      02-24-2013, 03:11 PM   #9
bradone1
BMW Extraordinaire
51
Drives: 2019 X7 M Sport, 2015 M4 Vert
Interesting.... Lots of thought put into this, I see.
m5post
