02-19-2013, 06:38 PM | #1 |
293
Rep 1,015
Unstable over patches and bumps
Hi everyone, just purchased a '08 128i with sp. The handling is unstable over patches and bumps, over wet roads it is even more unstable. I sometimes have to hold the wheel with 2 hands on occasions to keep it straight. I'm going to change out the tire obviously, but haven't yet decided to replace that tire, the front set or just go to non-rft all around.
BMW is saying there is no issue with the suspension, but I hardly doubt they actually gave a thorough inspection of the suspension and took it for a test drive. Anyone experience this and had it repaired? Wondering if that bubble separated a belt or something. Thanks, Mo |
02-19-2013, 06:48 PM | #2 |
298
Rep 4,040
Drives: 130i coupé ;)
i upgraded my front sway bar and i gained stability. Roads that used to pull @ my steering stopped doing it.
Do you have the sport package suspension? You should also look into replacing runflat tires for better rubber
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff "The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is |
02-19-2013, 07:02 PM | #3 | |
293
Rep 1,015
Yea, highly considering changing out all the tires. |
02-19-2013, 07:04 PM | #4 |
298
Rep 4,040
yes just the front to e92 or e93 m3 swaybar. And noticed the change on run flat tires
I also have sport package. Currently on winter tires and thinking about addressing the rear end bounce, esp for the summer since i will be getting non runflats. So read up on non runflats and what they mean for the car
02-20-2013, 12:18 PM | #5 | |
293
Rep 1,015
02-21-2013, 04:32 AM | #7 |
194
Rep 1,457
during full heave motion, swaybars do not work, and I think what OP is describing is that. I've heard many times that the unstable feel is related to rear subframe bushings.
02-21-2013, 04:35 AM | #8 |
194
Rep 1,457
Additionally; From TC Kline himself.
"Bushings also play a major role in suspension dynamics, and Kline says that the 1 Series’ rear subframe bushings—parts it shares with the mass-market 3 Series—are its biggest shortcoming. Kline says they’re too soft and have too much vertical movement for enthusiastic driving." 2nd page on http://www.bimmer-mag.com/issues/101...1#.USX4XKUqaPs
02-21-2013, 12:31 PM | #9 | |
22
Rep 277
135 has plenty of stock power, the first upgrades I was going to install were suspension upgrades. Now I know exactly what to aim for with my setup! |
02-21-2013, 07:32 PM | #10 |
293
Rep 1,015
Thanks Guys, I read Kline's article and it's very informative. Unsure if I will change over to M3 parts as of yet, maybe in the future.
Luckily the Pirelli Euforia had a free replacement and the car drives much much better. Didn't know a bubble in the sidewall can make such a big difference in handling. |
03-08-2013, 07:58 PM | #11 |
Rep 17
I just had my rear subframe bushings upgraded to the M3 bushing and it was like I replaced worn out shocks. The bounce in curves has been replaced by a firm controlled ride. This is a must do upgrade.
And I have to thank the guys at Harrison Motorsports. If you are in the Atlanta area these are the guys to go to. They work only on BMW's, track their cars and have reasonable rates. |
03-09-2013, 11:33 PM | #12 | |
Supreme Allied Commander
3845
Rep 54,376
Drives: F80 M3
03-10-2013, 12:29 AM | #13 |
European Editor
10589
Rep 22,992
As long as your tires are not wor out or very low on thread.... I would suspect the rear suspension bushings. You will not believe how .u h nicer the M3 rear axle ushi gs .ake our cars drive. They lt only firm up the fear end wiggle ut the frknt of the car seems to track much better.
03-10-2013, 01:14 AM | #14 | |
Internet Famous
Rep 232
03-11-2013, 07:27 AM | #15 | |
293
Rep 1,015
I can only assume they are fine, based on the dealers findings. Would bushings be covered under CPO? |
03-11-2013, 09:39 AM | #16 |
3845
Rep 54,376
Drives: F80 M3
03-11-2013, 11:27 AM | #17 |
298
Rep 4,040
Yes, e9x m3 sways need their own busings & bushing holders/mounts
03-11-2013, 08:54 PM | #18 | |
1397
Rep 777
The OP hints at a 'bubble" that he later clarifies was in the sidewall of his tire and when fixed, fixed the problem. How can he now reply "I can only assume they are fine" to the question "any abnormal wear on your tires?" He doesn't need swaybars or bushings or anything like that. How about we go back to square one and say, when something obvious is wrong, fix it before you start looking for other explanations for your symptoms. And maybe we should add, when you are starting a thread, include the relevant details. |
03-14-2013, 12:57 PM | #19 | |
293
Rep 1,015
03-14-2013, 01:12 PM | #20 |
49
Rep 654
Personally, I think the 2 biggest flaws of the many flaws in the 135i's suspension are the pathetic bushings and the dampers. The bushings feel like they're equivalent in terms of deflection to gummy bears and that includes the control arms, all the suspension links, subframe bushings, transmission mounts and all that shit. Beyond that, the dampers suck. They have no bump travel and don't react fast enough to road imperfections. Combine that with the crappy stock run flat tires and it makes for a ride that's not only jarring over minor imperfections, but also soft and difficult to predict. Get a proper set of dampers with good rebound valving with proper bump stops and you'll be happy. Bilstein dampers have internal bump stops and Koni's are external. With the Koni's you could go BMW Performance bump stops, Z8 or E36 M3. They're all substantially shorter than the factory bump stops which minimize the stroke. Plus the factory dampers are twin tubes and a good monotube damper will always have faster reaction to road bumps and dissipate heat more efficiently.
03-14-2013, 07:02 PM | #21 |
232
Rep 2,643
The rear suspension of the one series has some kind of designed-in dynamic toe control. It makes the rear wheels toe-in as the suspension is compressed. It also makes the car steer in the opposite direction of the body roll. When driving quickly on bumpy country roads its a noticible effect and needs steering corrections sometimes. I still have the stock rear bushings on the rear subframe which may contribute to this issues, although I have no way to know.
03-18-2013, 12:51 PM | #22 | |
172
Rep 2,347
Hey how much was install?
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms |
