02-18-2013, 11:37 AM | #1 |
106
Rep 996
BPM vs. ESS
BPM is the car with the camera and ESS is the car beside me.
We did the same gear and same RPM (4500) for these runs. The first run was dead even off the start, as for the second, UBER had the jump on the start. Sorry that the clips are so short but my GoPro was acting funny. The videos still show a good idea of whats going on. ***STi_traitor: BPM Tuned 2010 E90 M3 DCT (52k miles) OEM Exhaust Mod (ACM Style) Macht Schnell Test Pipes 245 (fronts) 265 (rears) PSS Tires ***UBER///M3: ESS Tuned 2012 E92 M3 DCT (11k miles) Akropovic Slip On Axel Back Auto Couture Motoring Test Pipes AA Green Drop in Filter 255 (fronts) 305 (rears) PSS Tires Last edited by STi_traitor; 04-05-2013 at 08:07 PM.. |
02-18-2013, 11:46 AM | #2 |
205
Rep 729
I think to validly compare tunes you'd have to run them on the same car, with the same driver, on the same course, and with similar atmospheric conditions. Your test will run an E90 v E92, different drivers, different tires, and it seems that in a not particularly controlled environment (i.e., the street). My prediction is that you won't be able to determine any meaningful difference, but I'm nevertheless interested in seeing what happens.
Good luck and be safe. |
02-18-2013, 11:52 AM | #3 | |
106
Rep 996
In the end this will be an interesting comparison. |
02-18-2013, 11:57 AM | #4 | |
106
Rep 996
ruff101726.50 |
02-18-2013, 12:23 PM | #5 |
63390
Rep 24,680
STi traitor..you are the man !!!
I can not wait for the results.... I have already made a shortcut of this tread... Why....i have also the oem. exhaust mod. and the same PSS tires and DCT ! So... now i was also considering a tune from Mike (BPM) in spring, and now i see this from you...i'm so f@cking curious about the result ! And when i may question you...is it possible to post a video about this ??? |
02-18-2013, 12:26 PM | #6 |
Nüburgring Nordschleife BTG 8:05
49
Rep 826
yeah buddy!!! is it april yet man!!!??? and there will be videos of this via Go Pro..Also this will all be done legally on the Autobahn in the unrestricted zone
ESS V2 Tune, ACM Test Pipes, AA Green Filter,Custom painted Recaro Pole Positions, Akrapovic slip on, Stoptech ST60/ Pagid pads, KW Clubsports, APEX ARC8s/Pilot Sport Cups, Hamann carbon fiber hood, ONEighty Headlight mod (selfmade), CRT lip with splitters, Blacked out/paint matched emblems, black aluminum extended paddles and pedals
02-18-2013, 12:56 PM | #7 |
136
Rep 1,128
Drives: 2013 E92 M3, 2016 X5 50i
I want to jump on this! I'll be back Saturday from downrange and will be picking my beast on the 8th. Sitting at the house already is an Eisenmann Race Exhaust, ACM Test Pipes with ESS Tune, BMC Drop in Filter, On it's way already Active Autowerks Power Pulley Kit. 2013 E92 DCT also will be running on VMR 710 19X9.5 Front with Stock Tires and 19X10 Rear Also Stock Tires.
I Am The Strength Behind The Fight!
02-18-2013, 01:08 PM | #8 | |||
106
Rep 996
02-18-2013, 01:17 PM | #9 | |
49
Rep 826
02-18-2013, 01:19 PM | #10 | |
136
Rep 1,128
02-18-2013, 01:36 PM | #11 |
63390
Rep 24,680
[QUOTE=STi_traitor;13500075]Good to see your excited! If anything you should join us the day it is done to see the outcome in person. I will post videos as soon as we make them, around mid April. This will be the best time since UBER and I will be busy all through March.
I can not join...i must always work ...also weekends and in shifts ! But i will follow your video... |
02-18-2013, 01:37 PM | #12 |
19
Rep 426
This is about as fair of a test as you can get. The test would be useless if there was no run stock vs stock because one person may have a stronger car stock for stock. So if the stock cars are essentially even than this will make for a perfect comparison.
I think I saw one guy did not have a drop-in filter so may as well get one and throw it on to completely even out mod for mod. Different rear section exhausts will make no difference whatsover, atleast on this car. Ideal road pulls would be 40-140. Gives you the powerband of 2nd and all of 3rd and good chunk of 4th to really display the legs of power up at the full peak area of the band |
02-18-2013, 01:58 PM | #13 | |
106
Rep 996
02-18-2013, 02:52 PM | #14 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
STi: You'll wanna change your plugs if they haven't been done before the event.
02-18-2013, 02:57 PM | #15 |
63390
Rep 24,680
02-18-2013, 03:28 PM | #16 |
106
Rep 996
02-18-2013, 06:38 PM | #18 |
09 M3 E90
Rep 168
subscribed
E90///M3 : ESS ECU & Shift tune w/ full ESS exhaust | KW V3's | LUX AE | 19" TE37's | Mode Carbon V1 lip | JB's CF trunk spoiler PARTING OUT EVERYTHING, SEE RESPECTIVE PARTS UNDER PARTS SECTIONS
02-19-2013, 01:59 AM | #20 |
274
Rep 2,664
Drives: Goggomobil
F86 X6///
02-19-2013, 02:25 AM | #21 |
30
Rep 1,789
What kind of wheels do you guys have?
From a roll, I'd say that the 265s have the advantage over the 305s due to weight. With a 4-5lbs difference per corner, that makes a noticeable difference in these type of runs. |
02-19-2013, 07:49 AM | #22 |
7494
Rep 12,310
STi, thanks for doing this. These are the tunes I'm interested as well (add Evolve to the mix too) and will have similar mods.
What kind of OEM exhaust mod do you have, bypass or perforated pipes? I'm holding out on a tune until I get test pipes, but since I already have a bypass OEM muffler, I'm not sure how that'll sound. I've heard a few terrible videos and it's kind of hard to tell. Wanted to see what your experience has been. Thanks again.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
