BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
EXXEL Distributions
      02-15-2013, 02:20 PM   #1
dead ringer
09 M3 E90
dead ringer's Avatar
Drives: 09 M3 E90 - DCT
got car back from dealer, making weird sound...(?)
ok, let me start off by saying I am not that handy when working on cars...
2 weeks ago I discovered a leak & took to dealership. They found it was a bad seal in the transmission & I got the car back a week later on Friday. He mentioned they had to drop the transmission....
That same night I discovered another leak, took it back into the dealer the next morning ( ** at that time I didn't notice anything different, BUT I did swap in an AA filter from the stock before taking it back in the next morning** )... He called on monday and said they found another leak, not related to the first but who knows what could have happened during the first fix.... If anyone needs to know I am sure I can find the parts they replaced if it makes a difference
Got the car back yesterday so it was at the dealer 5 days, and last night/today it just sounds different, kinda like there is a leak, you can hear the engine a lot more (kinda raspy but not in a good way), its just louder where as before it was smoother. My question is would/could they have disconnected the exhaust and not replaced it back correctly (I have ACM test pipes), or anything else to make it sound differently? I highly doubt it, but could they have run any ECU changes?
thanks for any input
E90///M3 : ESS ECU & Shift tune w/ full ESS exhaust | KW V3's | LUX AE | 19" TE37's | Mode Carbon V1 lip | JB's CF trunk spoiler PARTING OUT EVERYTHING, SEE RESPECTIVE PARTS UNDER PARTS SECTIONS
      02-15-2013, 02:56 PM   #2
VCMpower
25
Drives: 2010 Dakar, 2013 Fire Orange
2 coolant lines and 2 oil lines come off if the trans was out. Sounds like exhaust is not aligned, it is tight in there.
      02-15-2013, 03:00 PM   #3
joe@trinityautosport
joe@trinityautosport's Avatar
211
Drives: E92 M3 | F10 M5
^ +1 I would check the exhaust (section 1) where it meets the header or where the x pipe meets the mufflers.
      02-16-2013, 06:19 AM   #4
CanAutM3
CanAutM3's Avatar
21117
Drives: 2021 911 turbo
You mention that you changed the OEM air filter for an AA unit. This will definitely change the sound of the intake. It will be louder and raspier, especially at full throttle.
You might want to double check if you installed your filter right and that the airbox is well sealed.
      02-16-2013, 07:28 AM   #5
surlynkid
surlynkid's Avatar
115
Drives: 2013 E92 M3
put the original air filter back on and see if your problem goes away. always try to compare apples to apples.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
      02-16-2013, 10:41 AM   #6
m33
m33's Avatar
115
Drives: E92 VT650 MCB Individual
Is it a sound when car is under load around 2,500 rpm ?
      02-16-2013, 11:00 AM   #7
dead ringer
09 M3 E90
its all across the board, but only under hard throttle. Normal driving it doesn't sound different. I will drop by the shop that installed test pipes on Monday & have them check. @ idle in the garage I can't locate any strange sounds.
      02-18-2013, 06:45 PM   #8
dead ringer
09 M3 E90
found the issue, there is an exhaust leak from where the test pipes meet up with the stock pipes. You can see exhaust "residue" around the collar that holds the 2 pieces together. I am going back to have it fixed on Thursday @ the shop that installed them. Not sure if its a design issue or if the dealer somehow messed it up, but the pipes look a little misaligned. I hope its an easy fix!
      02-19-2013, 11:36 AM   #9
kitw
kitw's Avatar
471
Drives: F91 M8, 991.2 GT3
That is normal behavior when you go for a higher flowing air filter. My AA filter made some additional induction noise.
It's much more pronounced on the charcoal filter 08/09 cars too.
The exhaust leak is still a possibility making the noise, but it's a quick fix to swap in the air filter, so I would try that too.
m3post
