BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
EXXEL Distributions
      02-11-2013, 06:12 PM   #1
eclause13
Drives: 2009 E92 M3 DCT
2009 BMW E92  [0.00]
Launch control issue
Alright so I have a 09 e92 m3 with the DCT and I followed these steps to do the launch control.....
1 Turn on power button
2 Turn off DSC
3 Drove more then 6 miles and pushed up the 6 bars
4 Released brake and held forward until checkered flag shows up
5 Gas all the way down
6 Release shifter and held gas down
My issue is that when I release the brake and then put the gas to the floor the car moves like the clutch is slipping. I'm on flat ground so that isn't the issue. Any suggestions to what I'm doing wrong? Thanks.
      02-11-2013, 06:18 PM   #2
s14_kev
s14_kev's Avatar
367
Drives: E90 M3, E30 M3
Does it roll forward before you push the shifter forward and press on the gas pedal? If it does then the ground isn't perfectly flat
      02-11-2013, 06:21 PM   #3
SYZ
SYZ's Avatar
34
Drives: :O
Are you positive you are on flat ground? My car will roll forward the same way if its not perfect. It seems I can only engage launch control 5% of the time because of this.
Your steps are correct.. oil temp needs to be at normal temperatures as well otherwise it won't work, but if the checkered flag is coming up, then it should be working fine. Are you actually seeing the flag? How is the car moving like the clutch is slipping? Can you describe it better?
      02-11-2013, 06:50 PM   #4
eclause13
2009 BMW E92  [0.00]
Yes the checkered flag does show up. As soon as I let off the brake and hold the shifter forward then push the gas pedal down is when it starts moving forward. I will double check to make sure the ground is perfectly flat again though.
      02-11-2013, 07:47 PM   #5
JDM3
JDM3's Avatar
109
Drives: 2009 M3 E92
The car moves forward even on flat ground due to engine vibration. As soon as u get the flag and it revs, release the stick quickly. Why are u launching on the street? You won't gain anything and have everything to loose...
      02-11-2013, 08:09 PM   #6
SYZ
SYZ's Avatar
34
Drives: :O
What's the issue with launching on the street? There isn't anything illegal about it in lots of places.
      02-11-2013, 08:56 PM   #7
JDM3
JDM3's Avatar
109
Drives: 2009 M3 E92
I never said it was illegal. All your gonna get is a lot of wheel spin, even on R compound tires. If you get wheel hop which is possible, you run the risk of breaking something in the rear. So I'll ask,you again....what are you trying to accomplish? If its spinning tires and looking cool you will accomplish that. If your trying to get a good launch, it will never happen.
      02-11-2013, 09:01 PM   #8
M3takesNYC
19
Drives: m3
LC allows me a perfect launch and allows the quickest times I ever am able to do with a DCT. Only other option is to just press the pedal down from a stop but the problem is you waste time in 1-5k RPMS where the engine is not in its powerband whereas LC allows you to access the powerband from time 0.
I don't do it often but for the best launch it certainly works.
      02-11-2013, 09:08 PM   #9
eclause13
2009 BMW E92  [0.00]
I just got the car and don't plan on ever tracking the car. I wanted to try the LC.
      02-11-2013, 09:28 PM   #10
M3takesNYC
19
Drives: m3
OP, go ahead and enjoy the car, including LC! BMW did not put it there not to use and they cannot and will not deny a claim for its use. Sure, using it all the time is silly as ultimately what is the point but to use it a few times here or there to feel what a full out pull feels like from a stop is pretty cool.
I personally get more enjoyment out of slower rolling bursts in 2nd gear. You get the full press back into your seat and are at the powerband the entire time with no tire spin. Best "feeling" in my view.
      02-11-2013, 10:07 PM   #11
SYZ
SYZ's Avatar
34
Drives: :O
I don't get much wheelspin when I use it. It takes off pretty well. I bet with a supercharger it is pretty useless though.
      02-12-2013, 05:18 PM   #12
JuRuKi
Drives: E90 M3
I read somewhere in this forum that with DCT if you floor the pedal from a dead stop past the click it does some type of launch? can anyone confirm this?
      02-12-2013, 06:01 PM   #13
JDM3
JDM3's Avatar
109
Drives: 2009 M3 E92
correct. It drops the clutch at 3k. do it enough times and you will fry your clutch! Guaranteed....happened to well known forum member after one day at the 1/4 mile track
      02-12-2013, 07:37 PM   #14
JuRuKi
Drives: E90 M3
^^ thx for the heads up
      02-12-2013, 11:20 PM   #15
EliteM3
21
Drives: 2009 E90 M3
I have the same problem. You can't have the brake on to initiate launch control. And the car will not roll forward until you floor it...at which point I still haven't released the lever.
I don't get how you can use this usefully if it rolls forward when you don't want to.
It's like the engine revving is slowly engaging the clutch pushing the car forward. Weak!
09 Space Gray E90 M3 DCT: BPM (Stage 1, DCT and Servotronic) tune, Gintani Sport Exhaust, Dinan Intake
      02-13-2013, 11:48 AM   #16
Nordstat
38
Drives: 2014 Porsche 911 Turbo S
And this is worse than LC, which seems to drop the clutch at ~5k?
No sarcasm...just seems counter intuitive.
2014 Porsche 911 Turbo S - FOR SALE
2010 BMW M3 (e90) - SOLD
2005 Corvette C6 - SOLD
      02-13-2013, 04:50 PM   #17
C|3R1C
So Kewl Guy
C|3R1C's Avatar
49
Drives: 2010 E93 M3 DCT
I read on a thread here stating when you floor it from a stop, the clutch slips a little on purpose to produce a smooth start. LC on the other hand is a controlled clutch drop intended to protect the tranny and keep the clutch from slipping/glazing. The computer controls those two in different ways. Something to this effect was in the thread of how to maintain your tranny with a vt650.
2010 E93 M3 / MS Catless X-Pipe / AA Catback / Vorsteiner Vented Hood and Bootlid E93 Trunk / ADV1 7.1 Wheels GB / LS3 LED Lights / Harrop Supercharger
      02-13-2013, 06:55 PM   #18
CanAutM3
CanAutM3's Avatar
21117
Drives: 2021 911 turbo
2 Turn off DSC
Does not answer your question, however just for your info, your step 1 is not required. You do not need the "power" button to be engaged to activate launch control.
      02-15-2013, 08:35 AM   #19
PhoenixRising
Important text here
24
Drives: 2013 M3 Conv
I can't wait to get out of the break-in period so I can try this out. Patience is NOT one of my virtues.
2009 AM V8 Vantage Conv - Berwick Bronze, Quicksilver Exhaust
2013 M3 Conv - (RIP) thanks to uninsured a-hole
2004 Porsche 911 C4S Conv
m3post
