      02-10-2013, 12:49 PM   #1
BBursey
Work hard, play harder
BBursey's Avatar
14
Drives: 2011 135i
2011 135i  [0.00]
Alignment for Dinan Suspension, M3 Control Arms and No Rubbing w/ 235 PSS's on EC-7s
The long title pretty much says it all, but just in case...
I'm looking for known working alignment specs to fit 235/40R18 Michelin Pilot Super Sports on 1-Series fitment APEX EC-7s without any rubbing up front. The car has Dinan suspension and bushings with M3 lower control arms.
As a bonus, I'd also be interested in rear alignment specs to fit 265/35R18 PSS's on the same staggered set of EC-7s with only Dinan suspension in the rear.
Thanks very much!
Cheers,
Bryan
2011 135i M Sport | COBB V3 AP Stage 1+ | ER FMIC and CP | BMS OCC | Dinan Stage 3 Suspension | Dinan High Performance Bushing Kit | M3 Wishbones | Modified CDV | Clutch Stop | APEX EC-7 Wheels w/ Michelin PSS 235/40R18 265/35R18 Tires | Maddad Street Series Exhaust | BMW Performance Kidney Grills | LCI Blacklines | Armrest Delete | Spoiler Delete | 28% Tint
      02-10-2013, 09:18 PM   #2
Nugget
Nugget's Avatar
650
Drives: G81 M3 Touring, GR Supra GTS
2011 BMW 135i  [10.00]
Try for something like this (note that camber is degrees and minutes).
      02-10-2013, 10:26 PM   #3
blutattoo
22
Drives: 2012 135i
2012 BMW 135i  [0.00]
Alignment specs for my car. M3 control arms, Dinan Camber plates, Dinan stage 1 suspension w/ARC 8's running 235/40/18 RE-11's and the pins removed. Im able to get a max of 2.7/2.4 neg camber. Without the camber plates you should be able to get about 1.7-2.0 deg of neg camber. My rear specs have the rear M3 setup as well so I'm not sure if you can get this much neg camber, but I still don't think you'll have any problems fitting the 265's in the back.
Before I installed the M3 suspension stuff I ran that exact setup without any rubbing issues. PSS's 235/40 265/35. Some other folks have complained about rubbing on the inside of the front. When I switched to the RE-11's I had to add 3mm spacers to clear the front.
For drivability sake I'd try to keep the toe settings as close to neutral as possible.
      02-11-2013, 07:32 PM   #4
BBursey
BBursey's Avatar
14
Drives: 2011 135i
2011 135i  [0.00]
Thanks guys. I'll start building up a spec sheet based on that input.
Cheers,
Bryan
      02-11-2013, 07:42 PM   #5
andrey_gta
andrey_gta's Avatar
298
Drives: 130i coupé ;)
2008 BMW 128i  [10.00]
subscribed, good info here
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff
"The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is
      02-11-2013, 08:26 PM   #6
arcticcat522
Drives: 135i
where are you getting your alignment done?
      02-11-2013, 08:33 PM   #7
BBursey
BBursey's Avatar
14
Drives: 2011 135i
2011 135i  [0.00]
I've got two places to call / visit to start. I've seen Precision in the NE show up as a recommendation on beyond.ca and one of the guys at PT said the Viteks got a new alignment machine last year. I want this done once and done right, so I'll be doing my homework beforehand.
Have you got any other suggestions or recommendations?
Cheers,
Bryan
      02-12-2013, 09:48 PM   #8
arcticcat522
Drives: 135i
i dont have any helpfull info. your current set up is a direction i am headding. purchased camber plates around christmas, hopefully some coilovers before summer hits. What colour is your car?
      02-13-2013, 08:06 PM   #9
BBursey
BBursey's Avatar
14
Drives: 2011 135i
2011 135i  [0.00]
So, I've taken the input from this thread and created a little alignment spec sheet to bring along with me to the alignment shop. Have a look and let me know what you think. One thing I've noticed from my earlier alignment results - the SAI is a couple of degrees different between sides. It should be equal and is much closer in the other alignment sheets I've seen posted online. Should I be worried?
Cheers,
Bryan
      02-15-2013, 04:06 PM   #10
BBursey
BBursey's Avatar
14
Drives: 2011 135i
2011 135i  [0.00]
Hey guys. I've got my alignment appointment booked for March 9. I stopped by the shop today and talked with the owner. He was great to chat with, and is planning to do my car as his last appointment of the day so we can take whatever time is necessary to get it right.
Let me know if you guys have any suggestions on the specs I posted earlier.
Cheers,
Bryan
1addicts
