02-10-2013, 01:26 AM | #1 |
75
Rep 731
KW Clubsports
Just got my KW Clubsports Installed with Macht Schnell 12mm front 10mm rear! These are some pictures I got after the install from the shop, but I haven't seen it in person/driven it yet Ill have to wait until Monday. I will be taking better pictures soon, and I am thinking about going lower. Opinions?
Updated with some new pictures! Thinking about either lowering the front slightly, or raising the rear slightly, as the rear is currently sitting lower. (proper shoot coming soon)
02-10-2013, 01:37 AM | #2 |
22
Rep 441
That's a nice height. Any lower and your rears would start rubbing and you would have too much rake.
2011 Alpine White/Fox Red 6MT E92 M3 | Active Stage 2 w/Meth | KW Clubsport | OSS | Challenge Front Lip | Vorsteiner Type 2 Rear Diffuser and Bootlid | Brembo | Recaro | Akrapovic Slip-On | Challenge Race+ X-Pipe | Vossen CV3 | OEM 359M | TE37SL
02-10-2013, 01:56 AM | #4 | |
75
Rep 731
02-10-2013, 09:49 AM | #9 |
2739
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
The current height already looks fantastic. Lower=impractical. I ran my car at your approximate height and I was rubbing on driveways, speed bumps, etc. Test the current height before you go any lower.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
02-10-2013, 09:59 AM | #10 |
***Major MammelToe
159
Rep 1,139
That looks nice. Looks same height as mine with clubsports. These setting are actually pretty high. The rear is probably close to max height.
E92 M3 SG DCT - AA Filter, Verstraβe Paddles, ECS SS, MH race stud, Stoptech BBK, MR Exhaust,RE Pulley, BPM Tune,Euro bumper and GTS lip, Euro MDM & DCT, KW CS, Recaro PP, TMS Soild Diff Mounts, MRF solid subframe mounts, GTS aero, RPM track built motor.
02-10-2013, 10:45 AM | #11 | ||
75
Rep 731
Thanks!
I have a full IPE exhaust on right now, ESS tune, and now the suspension. thinking about a front lip from Mode Carbon, and if i get some $$ ESS supercharger somewhere down the line Quote:
02-11-2013, 11:31 AM | #14 |
75
Rep 731
hey guys so i picked up the car today, i am getting a little popping sound when the rear is under load (taking a bump or getting up a driveway) any ideas? its not happening on normal city/highway driving even if bumpy
02-11-2013, 11:38 AM | #15 |
***Major MammelToe
159
Rep 1,139
Take it back to get it looked at. I just had mine installed by MRF engineering 3 weeks ago. No noises at all. Just as quiet as stock.
02-11-2013, 11:38 AM | #16 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
Looks good.
02-11-2013, 12:13 PM | #18 | |
75
Rep 731
02-11-2013, 12:18 PM | #19 | |
***Major MammelToe
159
Rep 1,139
However, looks great! |
02-11-2013, 12:36 PM | #20 | ||
75
Rep 731
02-11-2013, 01:53 PM | #21 |
***Major MammelToe
159
Rep 1,139
I think the last page of installation manual clearly states that the lower rear spring support should be at the bottom end of the spring. I would check that out first. There must be a reason the mention that part at the end.
02-11-2013, 01:57 PM | #22 |
75
Rep 731
will check that out thanks again!
