      01-05-2013, 10:28 PM   #1
donsaxena
13
Drives: BMW 135i
Review: Ohlins Road and Track with all M3 parts
On my car
-M3 Front Upper and Lower Control Arms
-M3 Rear Guide Rod
-M3 Rear Upper Link
-M3 Subframe Bushings
-Ohlins Road and Track Coilover suspension
-Vorshlag Camber Plates
-Whiteline front and rear sway bars (bought earlier put on during performance upgrades). Didn't know much at the time or would have used M3 parts.
All parts were ordered from Turner and Ahmed Sulfab at Vivid Racing who I deal with exclusively now after having a bad experience at **********s. I still will order from HPF though nice guys.
The car is simply amazing. I put down on e20 350/450 and a bit more with e85/93, however, I generally run e20 off the pump available here in OKC. I notice that the turning ability has greatly improved and the ride quality is not harsh to drive daily. I really like the adjustments of the setup and feel like I can put the power down better. I feel like I have a different car now. It feels much like my old M3 except with a tremendous amount of torque. I do have a 3 clutch LSD from Turner so I am sure it does help.
I feel like I pull harder than I did before. If anyone is looking at this setup and hasn't pulled the trigger I would say it is safe to do so. If anyone has any questions let me know. Prior to suspension one of my friends and I using my P3 car vent clocked a 4.3 0-60 with my LSD. I feel like the car is hooking up a ton better so I will definitely check it out and report back.
BMW 135i Jet Black AT. Hpf intercooler, Hpf exhaust, injen intake, ER competition oil coolers, ER charge pipe, Tial BOV, AR catless DP,BMS OCC, VMR 718s 19s, BMW performance spoiler, agency power rear diffuser, slek lip (on highway somewhere), FXomar abs lip, Ohlins Suspension, All M3 bits, Cobb protuned, turner 3 clutch LSD, Escort 9500ci
      01-05-2013, 11:34 PM   #2
josh135
josh135's Avatar
Germany
21
Drives: 2010 135i
I'm thinking going the same route as you except for the rear guide rod and upper link. I'm going to test the coilovers by themselves and if I'm not happy I'll put some m3 parts on it.
Ohlins R&T 1m setup, m3 rear links, M3 arms, bushings, AR Downpipes, ARK DTS exhaust, SPEC S3+/Mfactory, Stett CP, Stett CAI, ETS FMIC, RB EVO Stealths, Motiv PI, VTT Inlets.
      01-06-2013, 01:38 AM   #3
jsmonet
302
Drives: 2020 x7 m50i
they're good on their own, but i'm still planning on getting, at the very least, the m3 front bits and dinan camber plates
2020 bmw xHippo, v8tt edition
      01-06-2013, 01:46 AM   #4
donsaxena
13
Drives: BMW 135i
thats a good plan. it was cheaper to get it all at once. the rear stuff from what I understand helps traction.
      01-13-2013, 05:23 AM   #5
mikal7
Drives: 128i / Rx7 Turbo
How much was your LSD? Is it a os giken or a turner in house model?
      01-13-2013, 03:49 PM   #6
fboutlaw
Cone Cruncher
fboutlaw's Avatar
31
Drives: Dinan 135i
Originally Posted by donsaxena View Post
On my car
-M3 Rear Guide Rod
-M3 Rear Upper Link
Running a similar setup and have been contemplating the Ohlins, but I run really wide rubber in front and may have to change spring rates.
Questions: What do you think of Ohlin's spring rates F/R? Have you had the car on a track? Do you feel like you store a lot of energy side to side in turns in the suspension or do you slide the car more easily?
      01-13-2013, 06:32 PM   #7
pixelblue
pixelblue's Avatar
140
Drives: the silver bullet
2010 135i  [8.90]
Ohlins supplied springs are a bit on the soft side for track usage imo. they're 345/400. I upgraded my rears to swift 550 and it was a noticeable improvement. planning on upgrading the fronts to swift 500 this year. keep in mind you'll lose some of the 15 point adjustments with stiffer springs. since you have a LSD I would recommend even going to a 600 for the rear but otherwise the extra mechanical grip for me is welcomed since I don't have a LSD
"I would quote everything pixelblue said, but you've already read it. Take it from someone who's put the 1 through its paces"
Last edited by pixelblue; 01-14-2013 at 06:38 AM.. Reason: correction to ohlins spring rates
      01-13-2013, 10:33 PM   #8
donsaxena
13
Drives: BMW 135i
It is one through turner I went 3 clutch diffs online does it for turner. I paid 3200. I didnt want to have a shop rebuild a different so I went through turner.
      01-13-2013, 10:37 PM   #9
donsaxena
13
Drives: BMW 135i
I have just started driving the car and honestly car has been in detail for a few days now. I think I like the spring rates for now I may have a different opinion when I get time to go to the track. I need to take a track session to really be able to give u better feedback
      10-07-2014, 07:11 PM   #10
dcaron9999
dcaron9999's Avatar
157
Drives: 2011 135i M package
I have a Quaife LSD myself, and some M3 bits. Seriously considering the Ohlins R&T and stiffer Swift Springs. I use the car mainly on the track, but have some rough roads to deal with too. Wouldn't mean reducing the lean I experience in corners, and corner to corner transitions.
Would really appreicate your feedback on how well they behave on the track, and also on the road.
2011 X3 35i with M pack + 2011 135i w/6SPMT | 255 square tire setup | Quaife 3.46 LSD | Diff lock down bracket | Bilstein B8+Swift SpecR springs+H&R FSB | CDV delete | BMS Oil Tstat bypass | ER FMIC & CP | N54Tuning DP | GC Street Camber Plates | M3 FCA +guide rods+RSFB's+Tranny mounts | Manzo toe arms | Cobb Stg2 agressive tune | Hawk DTC70 brake pads | RB SS brake pistons | Goodridge SS brake lines | Custom brake cooling ducts
      10-07-2014, 07:52 PM   #11
fe1rx
1397
Drives: 135i, 328i, Cayman S
The front spring rate selected by Ohlins (60 N/mm = 342 lb/in) is good based on actual ride quality and theoretical ride frequency. The rears (70 N/mm = 399 lb/in) are soft to accommodate the soft rear subframe. Since you have RSFB you can stiffen up the back substantially. It should be approximately twice the rate of the front to provide an appropriate rear ride frequency (i.e. 120 N/mm = 684 lb/in). This is what I am running so my comments are based on 60 front, 120 rear with M3 RSFB. Incidentally the 1M kit is 60/120.
The Ohlins recommended damper settings provide very good ride quality on the street - definitely better than OE. The rears have conventional elastomeric bump stops that are very progressive. The fronts have integral bump springs that are very stiff. When you run into them, you really know it. Key is don't over-lower the car, particularly at the front. I plan on raising the front of my car a bit because I have had a few good thumps when daily driving. Anyway, you have the ability to raise your car enough that whatever your normal is keeps you off the stops 99% of the time.
1addicts
