      01-02-2013, 07:06 PM   #1
Fritzl
Drives: BMW
Ticking/Clicking sound when turning left
Recently I have noticed that when I turn left at speed a loud ticking/clicking noise is heard. It does not happen at very low speeds or when turning right whether at speed or otherwise.
I have looked up the symptoms on the net but it appears it could be anything from CV joints to a loose brake dust plate. Anyone have this issue with a hydro-power steering equipped 135i?
Any help appreciated!
      01-02-2013, 07:47 PM   #2
Pig Farmer
340
Drives: E92M
I think anyone who has pushed the car through its paces has heard the ticking. I hear it coming from both the right and left wheels. Removing the wheels and retorquing the lugs seems to help for a few weeks/days but the ticking always returns. If someone has a definitive explanation/fix, i'd love to hear it.
      01-15-2013, 05:57 AM   #3
Andrew517
Drives: BMW135
Did you change the rims but keep using the factory run flat tyres with new rims.
      01-15-2013, 11:14 AM   #4
mike the snake
68
Drives: 135i
Many of us have had the ticking, including myself. Simply removing and reinstalling the wheels and torquing (with a torque wrench) the lugs seems to eliminate the ticking.
I think it is from incorrectly torqued lugs, which cause the rotor hats to warp/flex.
No one has 100% confirmed what it was, but R&R the wheels seems to fix the ticking most of the time.
      01-25-2013, 03:29 PM   #5
stride007
Drives: e82|f44|g21|g01
what is the proper torque specs for wheels?
      01-25-2013, 04:18 PM   #6
fboutlaw
Cone Cruncher
fboutlaw's Avatar
31
Drives: Dinan 135i
88 ft-lb for wheel bolts
I've heard clicking turning before from crap in the OEM brake pads. Usually reversing quickly then jamming on the brakes dislodges particles or crap that's in there.
If it's at low speeds it can be a whole bunch of things and you have to go through your suspension parts and make sure they're all torqued properly. If it continues, it's likely a bushing or insert in suspension geometry.
Currently I hear loud clunks when I turn right. I've got a broken link somewhere in my tie rods and have ordered replacements. Things are bound to break. Hopefully what OP is going through is minor.
      01-25-2013, 06:26 PM   #7
08LMB135i
Rally Armored 135i, don't copy me!
Drives: 2008 Lemans Blue 135i M Sport
If you has a broken tie rod the car would be undriveable as the steering would not be connected to one wheel, sway bar end links are a different story.
      02-08-2013, 02:41 PM   #8
FIRST1
109
Drives: '15 M235i Melbourne Red
I also hear strange noises when turning the wheel, but... once the car has warmed up ~15-20 mins, I no longer hear the sound when I turn. What do you guys think that's about?
      02-09-2013, 11:52 PM   #9
MinionM3
MinionM3's Avatar
492
Drives: 2012 E92 M3 // 2020 M2CS
IT IS WHEEL BEARINGS.... I have had it twice, first was driver side, then a few months later it was passenger...
After I changed them, it's gone
Instagram: @MinionM3
Current Garage:
2012 M3 ZCP, Mineral White, DCT: Track Build
2020 M2CS, Misano Blue, 6MT
      02-11-2013, 09:09 AM   #10
FIRST1
109
*newb question*
how do you go about replacing them? should it be done at a shop?
      02-11-2013, 04:26 PM   #11
flinchy
126
Drives: E82 135i
Sway bar bushings? Was for me
1addicts
