01-02-2013, 07:28 PM | #3 |
28
Rep 220
Yes. Coding or an additional module may still be necessary to eliminate possible light flickers.
Specifications: - (2) OEM BMW Outer LED/CELIS Tail lamps, including reverse bulbs with RED Turn signals - (2) OEM BMW Inner Trunk Lamps, including bulbs - (1) Set PnP harnesses Note: A minimal flickering will appear for the first few seconds of startup, this is the system's BulbCheck in use and is harmless to the vehicle. Coding from an independent with an Autologic programmer (currently in development) will be required to fully remove disable BulbCheck. Lighting assemblies and PnP harness are not returnable. Models Supported: 2007-2010 3-series Coupe/Convertible, including M3 Notes: - On MY07-09 models, the use of a FRM3 module may be required. - E93 (convertible) tail lights currently have a 3-4 week lead time. |
