M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Engine, Exhaust, Drivetrain Modifications
      12-25-2012, 12:40 PM   #1
Charlie Brown
Charlie Brown's Avatar
53
Drives: F10 M5 Azurite Black
I'm leaning heavily towards the axle-back Eisenmann race with 90mm tips. This setup removes the valves that control the exhaust passage at the rear. My questions are; what does that valve really do? Is it just noise control or does it add back-pressure at low rpm for fuel economy or pressure at part throttle for low RPM torque? How will the computer react to the missing valve? Thoughts?
      12-25-2012, 12:43 PM   #2
BarryB
BarryB's Avatar
868
Drives: 30Jahre M5 plus a few more M's
No negative effects. I think the valve is closed upon cold startup to help the cats warm up faster?
Current non-BMW's
20 Jeep Grand Cherokee
03 Cooper S (Maxi Tuned 50bhp)
60 Impala (43k orig mi)
15 Turbo S (Kobb tune and Kline exhaust)
      12-25-2012, 12:59 PM   #3
Nate@IND
Nate@IND's Avatar
2868
Drives: BMW
+1
The valves are in place to reduce emissions during start up. Just make sure that the vacuum lines are plugged during the install or you will get a CEL. My installer uses a small drop of adhesive and two small license plate size screws to block the line.
IND DISTRIBUTION | 866-963-4520 • FACEBOOKINSTAGRAMFLICKR
m5post
