KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
12-14-2012, 05:43 PM | #1 |
1889
Rep 5,506
Tire rubbing rear fender liner
I know this is probably a common problem with people running larger/wider wheel/tire fitments. How do you take care of the problem of the rear tires rubbing on the rear fender liner?
The tire is hitting the fender liner where the rear bumper and the rear quarter panel meet. The fender liner sticks out to cover the ledge/bolt that holds the bumper corner to the quarter panel. I can imagine shaving the fender liner will get rid of some rubbing but will the tire then contact the ledge/bolt behind the liner? Here is a pic for reference. This is not my car but it is the same problem. Last edited by Z K; 12-14-2012 at 05:50 PM.. |
12-14-2012, 05:56 PM | #2 |
2740
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
You can dremel the spot you describe but that may not be your actual rub point. Aggressive wheels / tires rub at the metal fender around 4 or 5 o'clock if you are facing the passenger side of the car. You can also add negative camber to help the situation. There is no easy fix for metal the fender rub.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
12-14-2012, 06:10 PM | #3 |
1889
Rep 5,506
The wheel and tire fully fits under the fender when compressed. It just hits the fender liner where I described. I don't think the tire hitting the fender is a problem in my case. I am mainly worried about that bolt. If I trim the fender liner and it hits the bolt that'll really screw up the tire.
12-15-2012, 10:18 AM | #4 | |
2740
Rep 6,734
'23 X7
