BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > General M3 Forum (E90 + E92 + E93)
      11-16-2012, 02:16 PM   #1
IDM
Drives: M3
e92 M3 operation oil pressures
I just installed an oil pressure gauge and am curious to see if it's working properly. What kind of pressures should I be seeing when at idle and at full throttle?
      11-16-2012, 02:20 PM   #2
MikeE92M3
MikeE92M3's Avatar
39
Drives: 08 E92 M3
Idk if this will relate as they are totally different cars, but in my Nismo 350z that I had, with the factory OIL PSI guage, when it is idling (warmed up) it was around 35-40PSI. At full throttle it was above 120 PSI, though I am sure with the 8500 rpm redline, that it is probably higher than that (maybe 160 PSI?)
2008 (07/08) E92 M3 BPM Stage II Tuned by Mike Benvo, 6MT, Turner Test Pipes, Magnaflow Custom Catback Exhaust (Magnaflow X Pipe, secondary cat delete, Aero Resonators and Helmholtz Chambers),Vorsteiner CF Lip, Hamann Style CF rear diffuser, CF Rear Decklid Spoiler, BMW Performance Kidney Grills, CF Side Grills, OEM GTS Wheels, K&N Drop-In Filter, GP Thunder 8k Angel Eyes, Painted Reflectors.
      11-17-2012, 01:41 AM   #3
julians999
Drives: 2008 m3
Cant answer your question ,so this could either be slightly interesting or completely pointless depending on your point of view, but my caterham 7 when warmed up at idle has pressure around the 30-35psi range, and when revving, has pressure around 60-75psi
      11-17-2012, 04:17 AM   #4
SenorFunkyPants
SenorFunkyPants's Avatar
2511
Drives: 2019 M5
I'm going for 25psi idle 75psi full throttle.
m3post
