M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      10-17-2012, 03:12 PM   #1
Rob///M5
Rob///M5's Avatar
76
Drives: 2013 M5 SSII
2013 BMW M5  [10.00]
Sunroof issue
Anyone else have a problem where the sunroof will not auto open/close. I have to hold the button the entire time. Manual says there are two levels to the button (just like auto windows), but neither work.
      10-17-2012, 04:57 PM   #2
zzzmmm
SICK
Drives: MCB F10 M5
U didnt know that's a recall issue also.
lmao just kidding.
waiting on pump
      10-17-2012, 05:10 PM   #3
bclk55
36
Drives: 14 X5 35D, 15 GT3
Try this, it worked for me.
Make sure the engine is on. Push in the sunroof button and hold it in for 15 secs, the sunroof will slide open and slide closed. After this your sunroof have reset itself and you should have the auto open and close.
Appreciate 3
msq12334.50
PB-32159.00
      10-17-2012, 05:32 PM   #4
Rob///M5
Rob///M5's Avatar
76
2013 BMW M5  [10.00]
DUDE! Genius! You just saved me a trip to the service center.
Cheers!
      10-17-2012, 05:34 PM   #5
Rob///M5
Rob///M5's Avatar
76
2013 BMW M5  [10.00]
lmao just kidding.
waiting on pump
Haha, don't tempt fate!
Sorry about the pump...it's gotta be done soon
      11-02-2013, 04:38 PM   #6
vulcan747
19
Drives: bmw 545
Faulty sunroof
And I also salute you.
Sunroof working again.
Thanks Much
      11-03-2013, 12:25 AM   #7
nugent
nugent's Avatar
66
Drives: f10 m5
if you push it twice it will open and closed both cover and glass without Having to hold it down.
e92 m3 6MT, RS4 6MT, S4 Avant 6MT, WRX 5MT, Corsica
      11-05-2013, 06:16 AM   #8
jc
Drives: 535i
I have a slightly annoying problem in that when I press the fob to close the doors and fold the side mirrors the sun roof cover also partially closes. This is annoying. Will the above reset work?
      01-02-2018, 11:25 AM   #9
V8munro
V8munro's Avatar
49
Drives: F10 M5 Sakhir Orange
I have had this issue for 4months, car isnt with me currently but cant wait to try as bugs me alot
F10 M5 2013 Sakhir
Eventuri Intakes, Supersprint backboxes, catless downpipes, ssp spec r, ECU flash, JB4 BCM and BMS dual CM10 meth
Insta: Tommy_turb0
      01-02-2018, 11:32 AM   #10
allmotor_2000
F10 1/4 WR: 9.9s / 142.5mph 1/2 WR: 175.5mph
1087
Drives: 2018 RS3, 991 Turbo
Happens when you disconnect the battery for anything. Need to run the adaptation cycle via ISTA.
I have heard you can just hold down the button for 20s and it does it... never worked for me.
      01-13-2018, 06:07 PM   #11
PetrolFumes
351
Drives: Raptor, GT3RS,E92 M3,X5M50i
I tried this twice today and nothing. odly enough it started after I got a tune...anyone else?
      01-14-2018, 01:34 AM   #12
Craze
161
Drives: M5 E60, M5 F10, X5 50i
Yes had the same
Push and hold the button up till it opens and closes
      01-14-2018, 05:44 AM   #13
V8munro
V8munro's Avatar
49
Brought a laptop loaded with ista yesterday luckily, handy when messing around with these cars
F10 M5 2013 Sakhir
Insta: Tommy_turb0
      01-22-2018, 04:45 PM   #14
V8munro
V8munro's Avatar
49
Held for 15seconds and its now working nice one
F10 M5 2013 Sakhir
Insta: Tommy_turb0
      11-02-2018, 03:10 PM   #15
BalSingh
15
Drives: E31, F20 and F10
Just tried this, need to hold the vent button for 20s or so, then once it pops in the vent position release the button and press and hold again for 20s or so. During the second hold, the sunroof will go open fully and close. Once closed the rest has been complete
      02-17-2019, 03:45 PM   #16
ShainoF10M5
ShainoF10M5's Avatar
Drives: 2021 BMW M8 GC
I am having the same problem after replacing the battery.
Kudos to the poster on reset cycle, but it didnt “completely” restore previous functiinality. While the 20-second hold did fix the glass auto-open and close when the shade is open, it does not auto-open or close the shade itself. For 5 years both were auto-open and close sequences but no more.
Any suggestion?
      02-19-2019, 11:10 PM   #17
AWF10M5
224
Drives: f10 m5
I've never opened my sunroof once lol
      02-20-2019, 07:23 AM   #18
technician117
251
Drives: 2000 M5, 2001 M5, 2013 M5 6MT
1990 BMW M5  [0.00]
2000 BMW M5  [0.00]
2013 BMW M5  [0.00]
Any suggestion?
As mentioned above, you may need to do a reset using a program such as ISTA.
      02-20-2019, 04:18 PM   #19
TLK
TLK's Avatar
112
Drives: '14 M5 CP, '12 550i, '04 545i
Full initialization without computer
You guys really should read up the instructions for reinitializing the sunroof in TIS:
https://www.newtis.info/tisv2/a/en/f...nroof/1LMfmNXx
You press the lift button to raise the vent an then keep holding it for 30 seconds until the initialization routine begins. Then KEEP holding the lift button pushed until it is done. It will open and close the shade, open and close the glass. Keep holding it until it finally stops moving. If you let go at any time you will have to start over.
If you owned a older BMW you may be thinking of the simpler window and sunroof procedures but that isn't the case here. Also your supposed to do it when the roof is warm but not in the sun and with a full battery, because a lot of this is really about memorizing the current draw so it can sense obstructions, pinching, jams. Given this is wintertime I guess you just do what you can.
      04-13-2019, 01:56 PM   #20
Sailorbaz
Sailorbaz's Avatar
Ireland
Drives: 2014 F10 M5 & 2004 M3 CSL
Just dug this out from the archives after collecting an F10 M5 the other day. Saved me a trip to the dealers, my roof wasn't tilting at all and would only open all the way if I kept my finger on the button until it was all the way open. Thanks to above, all perfect now, cheers.
      11-01-2020, 07:52 PM   #21
meins2
Drives: M5/330i ZHP
Sunroof Issues
Hello everyone, just joining and glad I did. Found the problem with my sunroof here and followed the instructions that were posted and it now works like a champ!
      06-24-2021, 09:26 AM   #22
Beowulf
Drives: BMW M5
Thanks
This worked. Old post , same issue! Saved us a lot of time and wasted money.
m5post
