10-12-2012, 08:32 PM | #1 |
Rep 9
Question about s mode/manual shifting
Hi I'm new to this forum and I'm getting my M3 in 2 weeks. So I just wondering that if you are using s mode and you are deciding when to shift manually, what different styles u get from choosing 1-5?
10-12-2012, 08:35 PM | #2 |
1770
Rep 6,696
Drives: F30 340i
1 starts with the least aggressive shifts with 5 being the most aggressive. I personally love 5 but alot of people like to stick with S3 or S4
10-12-2012, 08:38 PM | #3 |
So Kewl Guy
49
Rep 619
Depends. I personally like 4, unless I am really wanting hard shift, then I use 5. I read on some thread that the higher shift modes shift faster.
2010 E93 M3 / MS Catless X-Pipe / AA Catback / Vorsteiner Vented Hood and Bootlid E93 Trunk / ADV1 7.1 Wheels GB / LS3 LED Lights / Harrop Supercharger
10-12-2012, 11:20 PM | #5 |
37
Rep 421
It's funny to me that there is even an option to change the the speed/firmness when in manual mode (S). I think it should just be defaulted to 5. Having the ability to cycle through the levels when in D I can understand.
10-12-2012, 11:34 PM | #6 |
713
Rep 1,248
Would you guys rather have less choices? This is what the M3 is all about. Having the ability to make changes depending on our driving needs. It does need more learning curve but I think its more fun this way, it keeps our M3 interesting despite the daily grind.
10-12-2012, 11:37 PM | #7 |
Havin' a blast!
125
Rep 4,847
+1
BRP 1:56 | CVR 2:01 | ACS 1:53 | WSIR 1:34
10-12-2012, 11:48 PM | #8 |
11
Rep 242
Here is my preferred style:
1) Push clutch pedal in. 2) Push/pull gear shift lever until it is in neutral position 3) Move gearshift lever sideways to desired gate 4) Push/pull gear shift lever to engage desired gear 5) Let clutch pedal out. |
10-13-2012, 01:07 AM | #9 | |
18184
Rep 11,760
Drives: 2018 M4 Comp Indv
Who cares? It's no biggie. |
10-13-2012, 01:29 AM | #10 | |
18184
Rep 11,760
Near as i can tell 5 almost always does a full throttle blip while 4 will do it depending on your speed and de/acceleration, and 5 likes to go ... if you back off of the throttle too quickly at too slow of a speed you'll get lurching as anyone who learned to drive a stick at 13 is familiar with. S3 is my default for traffic or if I'm just chillin - I've never used 2 or 1 or any of the "d" modes. I have my M-button programmed for 5 but back it off to 4 if I'm having a "fun friday". such as today. another board member shamed me into going to dealer to get a liter of oil and on the way out it was all s5. Since I have a 'vert (and had the top down) I really hear the throttle blips and as I was coming around right-turn loop from a 45mph to another 45mph I shifted from 3 to 2 and then romped it through turn. I layed down a little rubber in a slight drift since I have winters on (vred wintracs from last winter!) and she snapped back right fracking now under heavy throttle. Anyway, the throttle blip scared the shiz out of a older guy who was on the sidewalk and I know because I heard him go "aahhHHHH!" as I downshifted. I feel pretty bad about that. So there ya go: S5 scares pedestrians. That's your difference. |
10-13-2012, 05:24 AM | #11 |
2511
Rep 4,381
The actual shift speeds are essentially the same for all gearbox settings, what changes is the amount the ECU adjusts engine settings to reduce torque and throttle opening.
At one end S6 is basically a power shift while S1 is the smoothest with the most amount of torque blend and reduced throttle opening. If you are in the habit of making full throttle shifts at the edge of grip in a turn or to tame power oversteer then S2 is the better shift map as it unbalances the chassis less. |
10-13-2012, 10:21 AM | #12 |
172
Rep 676
Throttle sensitivity does NOT vary with transmission mode. I suspect you are feeling increased torque due to higher engine speed secondary to "blip".
10-13-2012, 12:50 PM | #14 |
Never underestimate the Home-Bowl
484
Rep 821
Drives: F87 M2<E92 M3<E46 M3
Garage List 2017 BMW M2 [0.00]
2016 BMW M235i [0.00] 2012 BMW 120d M Spo ... [0.00] 2010 BMW M3 - SOLD [10.00] 2002 BMW Z3 2.2i Sport [0.00] 2001 BMW M3 - SOLD [9.00] |
The S mode will default to the last setting you used, so in mine it's always on level 5. Level 1 pulls away in 2nd and is meant for low traction conditions. levels 2-4 are pointless. Use 5 all the time. Use level 6 for lulz.
2017 F87 M2, MG, M-DCT
2002 E36/7 Z3 2.2 Sport 5MT 2016 F22 M235i Coupe, MW, ZF8 |
10-13-2012, 03:12 PM | #16 | |
18184
Rep 11,760
If I'm in S3 and slowly press down I'll get smooth acceleration. In S5 it's MUCH more touchy - I seem to have to do EXACTLY the right pressure with no changes or I'll get lurching. Thus if I'm in traffic where someone in front of me may suddenly apply brakes etc then S5 will throw around passengers and S3 won't. So whatever is happening it has the effect of making the throttle feel much more sensitive. |
10-13-2012, 10:50 PM | #17 |
369
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
On your side of the pond this is true, but not in the US. Here, it goes into S mode first and S mode always defaults to S3. D mode always goes to whatever you had it in last. Don't know why it's different. I'm sure lawyers had something to do with it.
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra. |
10-14-2012, 03:19 PM | #18 | |
18184
Rep 11,760
Apologies for any confusion and props to Jeff for the correction! |
10-15-2012, 12:47 PM | #20 |
369
Rep 1,887
It's like hill holder that some cars have with manuals... It holds with the brakes for 2 or 3 seconds then releases.
10-17-2012, 04:23 PM | #21 |
484
Rep 821
Oh, wow, that's weak. You miss out on the really handy little storage cubby on the drivers side, too because of those ball sacks.
10-17-2012, 04:55 PM | #22 |
Scythe-Meister
90
Rep 1,053
The purpose of having shift programmes is to provide optimal shift characteristics for the driving situation and the amount of traction available, not just for the sake of driver's preference. As an extreme example, choosing S6 for on a wet track will yield slower lap times than S3 when driving as fast as possible.
