BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > General M3 Forum (E90 + E92 + E93)
      09-25-2012, 03:57 PM   #1
Arben72
Albania
50
Drives: E92 M3
Idle problems.
I know this issue has been discussed before so i'm not going to go much in it. My car during warm up sometimes goes from less than 500 rpm to all the way over 1100 rpm. My car is a 2012 and I only run ethanol free 93 octane. I called my dealer to try and get this fixed and they told me it sounds normal (not to me). He told me without a check engine light he couldn't do much, but he told me to fill up with midgrade (89 with 10% ethonal) for 2 tank fulls and if that doesnt help to call them. I was wondering if this will do more harm then good and maybe if I should try another dealer?
      09-25-2012, 04:23 PM   #2
e1000
that's what SHE said!
75
Drives: 2011 E92 M3 ZCP
Didn't know you could get ethanol free gasoline these days.
Do NOT fill 2 tanks with 89.
      09-25-2012, 04:51 PM   #3
Prince_of_Persia
Prince_of_Persia's Avatar
248
Drives: 6MT E92 M3
Do not use 89. It usually starts from 1200RPM and it settles between 500-700RPM. I think it is normal as long as it stays in this range.
AW|FR 6MT E92 ///M3
      09-25-2012, 05:32 PM   #4
Arben72
Albania
50
Drives: E92 M3
yes but it goes from 1200 down to roughly 400 back up to 1200 and repeats itself till I get on the accelerator
      09-25-2012, 05:36 PM   #5
Grail05
Putcha ang ganda...
Grail05's Avatar
281
Drives: 17 F82 M4
sounds like its the gas... dont mix just use normal gas for a week or so... start on that first...
its funny how your complaining on this issue and looks like the answer is right under your nose.
      09-25-2012, 05:44 PM   #6
audioMeth
BTC maxi
audioMeth's Avatar
222
Drives: F80
he is using 93 so why are you saying its the gas? should he be using 104? i think you might have misread that first post
      09-25-2012, 06:12 PM   #7
Grail05
Putcha ang ganda...
Grail05's Avatar
281
Drives: 17 F82 M4
Mixture of 89... Just a merely suggestion to not mix.... At this point... Stay and use one gas and should notice after a week...also I would also use another gas station.... A lot of things that can cause this at this point start with obvious...
If that doesn't work it might be the idle valve
But op mine did the same thing and it was my low pressure sensor
Just wait for the engine light to come on cause if your idle keeps going up and down at any time of day cel will show up soon
      09-25-2012, 06:17 PM   #8
Arben72
Albania
50
Drives: E92 M3
I don't mix fuels. My choices are 93 (ethonal free) 89 10% ethonal, and 87. None of those include mixing from different pumps.
      09-25-2012, 06:21 PM   #9
Grail05
Putcha ang ganda...
Grail05's Avatar
281
Drives: 17 F82 M4
89 and 87? Wtf that might be the answer
      09-25-2012, 06:26 PM   #10
Arben72
Albania
50
Drives: E92 M3
I think you misunderstood me. We have 3 pump choices. 93, 89, 87. I only use 93 *shell v power. At my gas station 93 is the only one that is ethonal free. My dealer is recommending me to use 89. 89 at my gas station has 10% ethonal.
      09-25-2012, 06:29 PM   #11
audioMeth
BTC maxi
audioMeth's Avatar
222
Drives: F80
dude, he isn't using 89 or 87, those are just the other choices at the pump. the dealer suggested using 89. the op was only using 93 non ethanol blend which i wish i had the choice for. is this bizzarro land or am i reading this thread wrong?
      09-25-2012, 06:30 PM   #12
Arben72
Albania
50
Drives: E92 M3
No your 100% correct. Thanks for summing it up for me.
      09-25-2012, 06:31 PM   #13
Race_Doc11
Race_Doc11's Avatar
463
Drives: 2023 G82 M4
2023 BMW G82 M4  [10.00]
2018 F80 M3  [10.00]
2013 Audi RS5 (Sold)  [10.00]
2008 E93 M3 (Sold)  [10.00]
Same here. I was told it is normal however I started a new 2012 and it didn't do it....
      09-25-2012, 06:33 PM   #14
Grail05
Putcha ang ganda...
Grail05's Avatar
281
Drives: 17 F82 M4
Wtf dude I know about the choices stop putting it in.. Lol okok I mis understood ...
Ok now since that's cleared if u haven't gotten a cel yet like I said it might be your ICV
Wait until u get the engine light if u get the p0172 and p0175 it will be your low pressure fuel sensor...
One question though is this every start up or just in the morning?
By the way normal is when your rpm is at 500 700 but when it goes up to 1200 not normal might not show right away but seems like your low fuel sensor is about to go bad or the worst ICV....
      09-25-2012, 06:35 PM   #15
audioMeth
BTC maxi
audioMeth's Avatar
222
Drives: F80
Op, if you do some digging i could swear they had a software update for this issue, maybe someone will chime in with a service bulletin. your idle behavior is not normal, if its been like this over more then one tank of gas then i wouldn't be thinking bad gas. fyi, as i am sure you already know this but dont use anything less then 91 the dealer gave you terrible advice.
      09-25-2012, 06:37 PM   #16
Arben72
Albania
50
Drives: E92 M3
Ive only noticed it around start ups after it sitting outside for 8 hours during school. It's been getting progressivly worse. Today was especially bad and noticeable and i'm not sure if it's because it rained today. No cel yet but i'll scan for codes when I get one.
      09-25-2012, 06:37 PM   #17
audioMeth
BTC maxi
audioMeth's Avatar
222
Drives: F80
when my idle control valve went it generated a cel, it was more of a start to almost stall then cel type of event.
      09-25-2012, 07:04 PM   #18
Grail05
Putcha ang ganda...
Grail05's Avatar
281
Drives: 17 F82 M4
This happened to me and found out later that it was a bad gas... But since u said its getting worst and specially on cold start I'm guessing its low pressure sensor don't worry just wait for the cel to come out... And if it doesn't come out its the gas... Your idle should go back stable once u get new gas....hope it works out ...
      09-25-2012, 07:05 PM   #19
Grail05
Putcha ang ganda...
Grail05's Avatar
281
Drives: 17 F82 M4
Yes usually it will but when one is about to go out this is usually the symptoms.. Hope it's not though let's see....
      09-25-2012, 07:30 PM   #20
Arben72
Albania
50
Drives: E92 M3
It can't be the gas because this has happened during other tanks . We filled up our s550 at the same gas station within 10 mins of me filling up and it never had a problem. I'm guessing it's the idle valve control. It almost stalled out on me today and still no cel. It's probably going to be a wait and see thing. Hopefully no permanent damage.
      09-25-2012, 07:50 PM   #21
audioMeth
BTC maxi
audioMeth's Avatar
222
Drives: F80
i had my idle control valve and idle control actuator replaced on separate occasions, i wouldn't worry its a somewhat quick fix and common for these cars.
      09-25-2012, 09:10 PM   #22
EuropeanM3
Drives: ML350
if it helps my 2008 ml350 does something similar and I think I remember hearing how it has to do with the engine needing to build up oil pressure or something :S
m3post
