09-21-2012, 09:14 PM | #1 |
41
Rep 567
Drives: 991 GT3, '12 CLS63 Kleemann K3
launch control ain't working too good, maybe MDM??
any suggestions ?
I just hop of the line like crazy using launch control... |
09-22-2012, 02:00 AM | #5 | |
Boats & Hoes
21
Rep 345
Its launch control for rpm's..... You still control throttle... Back off lightly if you get out of line/counter steer. Get back on throttle as soon and smooth as you can keep traction..... Spinning isn't fast.. But its tons of fun! Its not auto pilot. Its a glorified 2step Aloha Alex |
09-22-2012, 08:47 AM | #6 | |
Rep 78
09-22-2012, 01:59 PM | #7 | |
41
Rep 567
only thing, (i tried it twice last night at the strip,) the first time i was in the right lane, i never am able to get off the line on time because its just so tricky to get it armed as you have like maybe one second to set it up and launch if you wanna get off as soon as the the light is green. anyway the car just starting shuttering violently and hopping all over the place right after i launched. it did this for what seemed like at least 20-50 feet. when it finally hooked up it was a clean hookup but it was way too late. my 60' time was like 2.3 and i did a 12.4 that run. my first. next the i tried MDM in auto and managed a 12.2 at 119.79 still my 60' was 2.2. and even though i was in MDM i still spun quite a bit in 1st and second. then tried the launch control in the left lane, and same thing, violent shuttering and hopping. the whole time im thinking - what the hell is going on? it sounds like the car is literally going to vibrate into 1000 pieces. i had the same issue with my e60 m5 come to think of it. when it hooked up on this run, it was like the car went into limp mode because i finished with a retarded 109 mph speed. at that point i was like , ok, that's it for the launch control. however this didnt happen with race start on my cls63. just clean launches. maybe a tiny, tiny skip off the line, that's it. the only thing with the AMG race start, its completely HOPELESS to get it set up. even worse than the m5. you end up being there fiddling with you settings for like 2 or 3 seconds and by that time the guy your racing is halfway down the track... i did a few more runs, all in auto, MDM and managed another 12.2 and a 12.3 but all in all i dont get this launch control, if its maybe an issue with the traction on this particular track, or what. the temp ranged from around 23 deg C to 17 towards the later runs i never attempted to do a burnout before either pass, and drove around the water box each time.. |
09-22-2012, 04:22 PM | #8 | |
105
Rep 806
09-22-2012, 05:14 PM | #9 | |
41
Rep 567
well you you don't reall have a choice, unless in missin something, after you push the lever forward, you can't move forward any more until you launch. I have my M1 programmed to sport plus and S3, so I'm already in M1 mode before I even pull up to the lights. but it still takes a second or do to push the lever forward, take a quick glance to make sure Launch control active appears in the cluster , then, floor the gas, remove your left foot from the brake(actually you don't need to do this after you floor it, it could be before. but there's literally no time, or any of that. it's very difficult. all my reaction times were between 1 and 2 seconds. when I attempted LC. it's funny, the 12.2 pass, I ran against a mustang 5.0 even though I did a normal launch off idle, i still messed it up bigtime. he still got off the line waaaay before me. by the time I really got moving he was a good 8-10 car lengths ahead if me. but the rate at which I reeled him in was quite amazing. i realized quickly, before my eyes what a ridiculously fast car the f10 m5 is. we crossed the line at about the same time. I think he ran a 12.9 that run. |
09-22-2012, 08:40 PM | #11 | |
Boats & Hoes
21
Rep 345
Try it and you will get better.. Aloha Alex |
09-24-2012, 09:08 AM | #12 |
Rep 63
I think there are two launch modes: Burnout mode and launch mode. Thats what the e60 M5 had and I think it was passed to this model and all of you are using Burnout mode instead, hence the crazy tire spinning.
Burnout mode you engage everything, hold the gear lever forward and stomp the throttle then when ready release lever to launch. Launch mode you engage everything, hold the gear lever forward and ease on the throttle slowly until it is at wot then when ready release lever to launch. Try the launch mode and report back with results. |
09-24-2012, 09:44 AM | #13 | |
76
Rep 1,341
Drives: 2013 M5 SSII
09-24-2012, 12:12 PM | #14 | |
41
Rep 567
09-24-2012, 02:10 PM | #15 |
Rep 63
This is what the E60 M5 had (although alot of owners didn't realize it, only a few did) and I think it was carried on the F10 aswell. Just go out and try it, only thing that could happen is it either works or it doesn't, no harm done.
10-18-2012, 11:14 PM | #16 |
25
Rep 279
Has anyone "perfected" this yet? My LC has been inconsistent and I've been practicing...
I'm always looking for the flag and LC to light up. My procedure is to come to a stop (the car is in sport plus and S3, DSC off of course) apply the brake, push the lever forward, floor the throttle, and release the brake. It seems that the LC flags only come on once I release the brake - same for you guys? |
10-19-2012, 07:58 AM | #17 | |
Driver
94
Rep 636
10-19-2012, 09:25 AM | #18 | ||
67
Rep 704
Myth |
10-19-2012, 09:50 AM | #19 |
13
Rep 151
As far as I know, the more you use it the quicker you need your clutch replaced, same as a real stick.
10-19-2012, 08:11 PM | #20 |
25
Rep 279
10-28-2012, 11:46 PM | #21 |
69
Rep 961
Same here, I used launch control from 3500RPM and ended up sideways at around 30MPH and had to disengage. Of course right before I engaged it, I ran over a dam puddle from sprinklers, not sure what affect that had on it. Ill try comfort suspension next time, anyone else had any success with LC? Insane feature..LOL
10-31-2012, 02:51 PM | #22 |
Rep 78
Yes, wet tires would not be a helpful additive to your launch.
