      09-19-2012, 09:54 PM   #1
BMWbab1
Drives: 135i
Help...Rattle from suspension/engine bay.
I have an odd rattle from my engine bay when I go over bumps at a slower speed (up to 35 MPH) and the sound is similar to when you do not have the top nut on the shock arm/strut tight. However, I have hit each bolt with an impart and they are tight so that is not the issue. The sounds continues for about a second after I hit a bump. For example once I hit the bump you will hear the rattle for about a second. If you ask me I would say the sound in coming from more the middle of the car in the engine bay and not the out areas where the suspension is connected (however I do know suspension sounds can travel to other areas). It also is not loose brake pads as the noise is still there under breaking. If you have had any issue like this please let me know or if you have any suggestions. Thanks!
      09-20-2012, 08:12 AM   #2
JSILVER135I
25
Drives: SILVER 135I, MSPORT PKG
Maybe check stabilizer bar and links. Had that happen to me on a sunbird and found that the whole link was broken so the stabilizer bar was literally whacking against the Frame over bumps
      09-20-2012, 12:50 PM   #3
BMWbab1
Drives: 135i
Is the stabilizer bar the bar that connects to each of the strut mounting points n then to the back of the engine bay? I appreciate your help!
      09-20-2012, 02:28 PM   #4
JSILVER135I
25
No it doesn't connect to the back of the engine bay. It does tie the 2 sides together though. It just connects to the frame of the vehicle but I bet if it's banging against the frame it would sound as if it were hitting the back of the engine bay.
      09-20-2012, 02:40 PM   #5
BMWbab1
Drives: 135i
Where is this bar located. Under the car?
      09-20-2012, 02:51 PM   #6
t02t
t02t's Avatar
Taiwan
30
Drives: 135i
Not sure if he's referring to the same thing, but check your endlinks for loose bolts
      09-20-2012, 03:11 PM   #7
Focusedintntions
105
Drives: 2011 135i M-Sport :D
I believe he means check your sway bar and end links....
Faster, faster, faster, until the thrill of speed overcomes the fear of death… – Hunter Thompson
      09-20-2012, 03:26 PM   #8
BMWbab1
Drives: 135i
Ok. I was thinking he meant the sway bar. Thanks!
      09-20-2012, 06:09 PM   #9
BMWbab1
Drives: 135i
Ok. Came home today n made sure all suspension parts were tight. They were all tight. I am double checked camber plate strut bolt was tight and it can get any tighter. I took two different people for a ride and they both think that the sound is coming from the center of the car somewhere forward of the passenger area (engine area). To give a better description of the sound it sounds like a piece of metal (similar to the piece of metal tubing the extends from strut towers to back of engine bay) that would be bouncing up and down after you hit a bump for about a second n it rattles up and down about eight times or so. Any help would be VERY much appreciated as I know if I take it to the dealer they will blame the camber plates right away and not look for anything else.
      09-21-2012, 02:08 PM   #10
Focusedintntions
105
Make sure the sway bar bushing didn't fall out...that would be the only thing I could think of there....you'll have to remove the plastic under tray to actually see it.
      09-21-2012, 05:49 PM   #11
pixelblue
pixelblue's Avatar
140
Drives: the silver bullet
2010 135i  [8.90]
I had the same issue with mine. it use to drive me crazy. it all stopped when I switched out my coilovers and camber plates. can't tell you which one was the culprit but it's all good now. I can't believe how long I tolerated. I say take out the camber plates and see if the noise stops. I don't know if you're mechanically inclined or not but that would be where I would start.
"I would quote everything pixelblue said, but you've already read it. Take it from someone who's put the 1 through its paces"
      09-23-2012, 09:06 AM   #12
BMWbab1
Drives: 135i
Sat on front of car w hood open n had someone drive it at about 5 mph (not safe, I know) and the rattle is certainly not coming from camber plates. It is coming from center of car behind the engine. Might just take it to dealer and see what they say.
      10-16-2012, 01:19 PM   #13
4tDX
Drives: E30 325i
I have an e90, but I am experiencing a similar noise under the very same driving conditions. So, I was wondering if you had solved your issue.
It began occurring shortly after I had the car aligned, but I've been unable to find the culprit. Did you are anyone else experiencing this problem after similar maintenance was performed?
      10-16-2012, 03:16 PM   #14
TC Kline Racing
TC Kline Racing's Avatar
45
Drives: Many BMW's & Porsche's
any updates?
did you check you sway bar and endlinks like others suggested?
      05-07-2013, 01:51 PM   #15
Stan.mac
Stan.mac's Avatar
Drives: 135i M-Sport
Boo this man for no updates... ! Boooo!
"I live my life a quarter mile at a time. Nothing else matters: not the mortgage, not the store, not my team and all their bullshit. For those ten seconds or less, I'm free."
afe DCI/Greddy Oil Catch Can/Catless DP/ Cobb Stage 2+/Berk Axle-Back(Race)/AAW CP w BOV/H&R Springs/ ALPINA Flash/Helix FMIC/
1addicts
