09-07-2012, 11:04 PM | #1 |
60
Rep 508
So I was just cruising tonight and it was running fine till out of no where I noticed the exhaust was loader then normal. I hit the gas and It had almost no boost. Sounds like I'm on map 8. NA map. It will boost a little bit but sounds like crap. Seems like only one of the turbos are working. I've had the wastegate rattle for the longest time and is it possible that the wastegate flap broke off? Any input will help. No check engine light or anything. Thanks
08 135i N54
- Vargas Stage 1 Turbos with Billet wheels - BMS Intake, BMS Charge pipe, AR DPs, Stock mids, berk race muffler delete - JB4 G5 Map 3 75 Meth Additive with RACE DME flash - MS-109 and 100% meth injection (Single CM12 nozzle) |
09-07-2012, 11:22 PM | #2 |
12
Rep 437
There is definitely something wrong with your wastegate. When mine started rattling very loudly after letting off the throttle. Slight boost leak issues, I did not have any check engine lights whatsoever, I had to replicate the issue to the SA and they decided to slap on new turbos under warranty. This was back when I only had JB4. Judging from your mods list, I'm guessing your wastegate actuator snapped since you cant hold boost.
btw I'm also an 08'
E30 x2 Sold
E39 x2 Sold E46 x3 Sold E82 x1 Sold E60 x1 Furniture... |
09-07-2012, 11:31 PM | #3 |
915
Rep 3,456
Drives: Harrop E90 M3
Sounds like there is so much play in the wastegate pivot bushings, that one of them seized up. I wouldn't be surprised if they free back up from time to time with temperature changes in the turbo itself. Happens quite often
09-07-2012, 11:38 PM | #4 |
60
Rep 508
Is it possible that the wastgate came off in the turbo? I think I would hear that rattle out the exhaust but I didn't hear anything
08 135i N54
09-08-2012, 07:32 PM | #5 |
60
Rep 508
Found the problem. Little pin that holds the actuator rod and wastegate lever snapped. Guess its back to stock and off to the stealership :/ front turbo too. Fml...
08 135i N54
