09-07-2012, 03:05 AM | #1 |
Rep 20
Small dent on back bumper
Anyone know a good body shop in so cal to get rid of an annoying small dent on back bumber. Dent only really noticable when you see it at an angle, very small but very annoying like i said. no scatches to paint just need paintless dent removal. Thanks
09-07-2012, 03:24 AM | #2 |
356
Rep 1,749
its plastic. doubt PDR can happen. plastic can't be repaired easily. If it really bothers you probably only way to make it flawless is replacing the bumper cover.
"It gave you amazing satisfaction, but anyone who says he loved it is either a liar or he wasn't going fast enough." - Jackie Stewart on racing at the Nurburgring
09-07-2012, 07:35 AM | #6 |
84
Rep 451
I had a very small vertical crease on my 08 car, caused by a gate blowing closed as I reversed through the opening.
The dent was removed by heating the plastic and then using typical PDR tools/techniques. The dent was completely removed by this process. It did require painting afterwards, but overall the cost was half of the cost of replacing the bumper (which had been recommended by one of the BMW bodyshops). I have "before" pictures if you are interested |
09-07-2012, 09:12 AM | #7 |
15
Rep 408
i have two "dots" on my door from parking, looks like someone opened their door on it. i dont know what i can do about it, but things can't stay perfect forever.
that said, would love to fix it. |
09-07-2012, 10:08 AM | #8 |
1006
Rep 3,341
I just had a crease removed on my bumper. I took it to BMW for an estimate, they wanted $800 to fix it. The body shop estimator recommended a local body shop that could do it for less...cool guy. I ended up getting it fixed for $400. Maybe give BMW collision a call and see if they'd recommend a local body shop for you.
09-07-2012, 10:11 AM | #9 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
No such thing as PDR for plastic.
09-07-2012, 10:32 AM | #10 | |
67
Rep 2,536
So why did you waste money getting PDR and still ended up getting it painted? The body shop could have just repaired it, and painted it. |
09-07-2012, 02:18 PM | #11 |
84
Rep 2,792
Not true. As one poster mentioned above, heat can be used to remove dents in plastic bumpers. I'm not a pro but I've done it myself with amazing results.
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R |
09-07-2012, 02:20 PM | #12 | |
84
Rep 2,792
If the OP literally has a barely noticeable dent and no paint damage, heat and PDR techniques will work.
09-07-2012, 05:48 PM | #13 |
307
Rep 13,093
Because you would likely have to either get at from behind if you're lucky or likely take the bumper off, I hardly consider it PDR.
09-07-2012, 06:38 PM | #14 |
127
Rep 6,773
PDR is not for bumpers ..FYI I had a big dent in my rear bumper..and it couldnt be saved even after heating and remolding it still sagged..only solution was a new bumper cover..
Bumper dents can be repaired but sometimes it doesnt come out perfect. |
09-08-2012, 06:39 AM | #16 | |
84
Rep 451
I wrote PDR tools and techniques The tools and techniques enable the return of the material to its original shape after it has gone through a plastic (in the true sense of the word, beyond elastic) deformation. With steel, this is fairly easy to do at room temperature. With "plastic" it is not so easy and requires elevated temperature, which usually results in damage to the paint surface if present. I had the choice of - fill the dent and paint the bumper. No thanks very much. - heat and reform (using PDR tools and techniques) then paint the bumper - buy a new bumper and paint it. As option 3 came to £1100 plus, and option 1 was a complete no no, I went for option 2 at £450. And a perfect job was done. With none of that "blowing in" nonsense either. Pictures will follow when I have time to find them. |
09-08-2012, 06:46 AM | #17 |
84
Rep 451
If the paint has not cracked, and the inside of the panel has any access, this should be fixable using PDR.
09-08-2012, 10:08 AM | #18 | |
Ninja
390
Rep 4,014
2019 AW G30 530e l ZPP l ZMP l ZDH
Retired: 2016 F80 M3, 2012 E90 M3, 2008 535i |
