09-01-2012, 02:38 PM | #1 |
25
Rep 574
Help with Cobb!
Hey guys, I just got a Cobb, I downloaded the map and everything, everything's going well so far, but I'm a bit confused on the boost gauge , how can I make my fuel the boost gauge? And also, do I keep the Cobb plugged into my obd II or take it off? Thanks in advance !
09-01-2012, 02:58 PM | #2 |
Rep 207
Assuming you mean using your BMW 's fuel gauge as boost gauge? I don't think Cobb AP can do that. But you can keep plugging in your OBD II and use the AP 's monitor feature. Boost is the second last from the monitor manual
09-01-2012, 03:05 PM | #3 | |
25
Rep 574
09-01-2012, 08:12 PM | #4 | ||
376
Rep 2,388
Drives: M2 Competition
drive - 89 octane sport - 91 octane aggressive - 93 octane. you can run stage 1 with 0 supporting mods. stages with a "+" require an FMIC and stage 2 requires at least hi-flow catted downpipes. |
09-01-2012, 08:17 PM | #5 |
380
Rep 5,730
Drives: BMW i3 rex
Garage List 2018 I01 i3s | CURRENT [0.00]
2018 G01 X3 | CURRENT [0.00] 2017 I01 i3 | SOLD [0.00] 2017 F48 X1 | SOLD ... [0.00] 2016 I01 i3 | SOLD [0.00] 2017 F22 M240 | SOLD [8.00] 2016 F25 X3 diesel ... [0.00] 2006 E60 550 | SOLD [6.00] 2011 E90 335 | SOLD [8.66] 2012 E82 135 | SOLD [5.50] 2011 E82 1M | SOLD [7.94] 2007 E85 Z4M| SOLD [4.50] 2003 E53 X5 4.6is S ... [9.00] 2008 E92 328 | SOLD [0.00] 2008 E82 135 | SOLD [0.00] 2008 E90 335 | SOLD [0.00] 2003 E46 M3 | SOLD [7.50] 2006 E90 330 | SOLD [10.00] 2003 E46 330ZHP | SOLD [0.00] |
no boost gauge hack with cobb its for jb4!
09-02-2012, 01:59 PM | #6 | |||
25
Rep 574
09-02-2012, 02:13 PM | #7 |
247
Rep 1,827
09-02-2012, 02:20 PM | #8 |
Rep 50
do NOT run stage two if you do not have an exhaust. Do you have one besides the down pipes and midpipes? the reason is this is because of how lean the cobb runs and the maps are very specific. if u want to run stage two. atleast do not run the aggressive setting. use the sport. and then get your car ProTuned. My car was running dangerously lean until i get it tuned.
ETS FMIC - Riss Oil Catch Can - E92 Front Sway Bar - AFE dual scoops - DCI - TurboSmart dual port BOV's - AR design down pipes (catted) - N55 mid - Remus quad race exhaust. COBB Stage 2+fmic. V4. PRotune
09-02-2012, 03:44 PM | #10 |
456
Rep 6,478
As has been said, stay away from ST2 aggressive for the time being, do some logging on sport or drive and see what type of timing and AFR you're getting. If those check out and the car feels good, experiment with aggressive and run some more logs. The 135 stock exhaust is a pretty restrictive unit, esp. on the N54 the DPs, Midpipes, and axle-back portion all present significant choke points.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
09-02-2012, 06:51 PM | #11 |
25
Rep 574
Thanks guys, I have no cats, no muffler no res, full straight up...so I can run stage 2 but not the +? Mine doesn't have any of it though..should I put it in my computer and find some maps?
09-02-2012, 08:10 PM | #12 |
456
Rep 6,478
It's easy to get more OTS maps, just plug in your AP and download the maps from Cobb's website based on your ECU type (EX. mine is IJEOS). From there put the downloaded maps in the AP map folder, and the manager can copy them onto your accessport. Takes about 45 seconds once you figure the map you want to download.
09-02-2012, 09:40 PM | #13 | |
25
Rep 574
09-03-2012, 12:15 AM | #15 |
25
Rep 574
Oh okay perfect thanks a lot! I'll update you guys tomorrow ..it says some of the maps is not available and it's available to some other car?
09-03-2012, 09:46 PM | #16 | |
456
Rep 6,478
09-05-2012, 05:23 PM | #20 | |
25
Rep 574
09-05-2012, 07:33 PM | #21 |
89
Rep 3,732
Drives: BMW S1000XR
Hey, sounds like you like it, have fun, and be safe. Get an FMIC upgrade !
BMWCCA member |
