08-31-2012, 07:29 AM | #1 |
137
Rep 571
Strut Tower Brace vs Strut Brace
08-31-2012, 11:14 AM | #2 |
323
Rep 1,804
The brace stretching around the car laterally will, in theory, increase the rigidity of the chassis. The E82 has such a stiff chassis already, the affect will be minimal. I added one to my car and there was no discernible difference. I'd spend my money on a sway bar instead.
-Nick
2018 BMW 440i - M Sport, Exec Glacier Silver Metallic/Coral Red Dakota Retired: '00 323i, '06 325Ci, '09 135i, '06 Z4M Roadster, '93 525i, '76 2002, '14 X1, '14 M235i, '16 X4, '16 435i |
08-31-2012, 07:34 PM | #3 |
126
Rep 3,099
the ones reaching from the tower to the firewall compared to the strut to strut.. probably not much difference between them
the best ones are 3-point (firewall AND struts) i personally find the chassis to be a bit too floppy for my liking - definitely not as rigid as my previous (modified) cars |
09-03-2012, 06:28 PM | #4 |
111
Rep 919
Drives: BMWs
Garage List 2008 E60 M5 6MT [0.00]
2019 G01 X3 sDrive30i [0.00] 2007 E86 M Coupe [0.00] 1997 E36 M3 [10.00] 2006 E53 X5 4.8is ( ... [0.00] 2006 E85 M Roadster ... [0.00] 2002 DINAN 5 (sold) [0.00] 2013 E89 Z4 sDrive3 ... [7.00] 2011 E92 M3 (sold) [0.00] 2001 E46 M3 (sold) [0.00] 2007 R56 Cooper S ( ... [0.00] 2002 996TT (sold) [10.00] 2009 E82 135i (sold) [9.00] 2006 E85 Z4 M (sold) [6.00] 2007 B7 A4 2.0T (re ... [0.00] 2003 E46 M3 (sold) [0.00] 2002 E46 325Ci (sold) [0.00] |
Agreed. Coming from an E46 M3 and E85 Z4M, the 135i's chassis leaves A LOT to be desired in terms of stiffness. Even getting a dealer's E90 loaner several times was an improvement over the sloppy feel of my 135i. Upgrading to M3 suspensions bits has since improved the overall chassis feel for me, but it's still a far cry from what I'm used to.
09-03-2012, 07:09 PM | #5 | |
126
Rep 3,099
I wouldn't call it outright *floppy* - tests show that it's a pretty good and stiff chassis compared to most stock cars.. But again, i'm used to 'floppy' oem cars that have a whole bunch of bracing to pretty much make them as stiff as possible (without fully custom seam welding etc.) - after riding in a few cheaper cars with bracing, then my car.. It's not much to fix up, and what stiffening can be done is more than sufficient M3's and z4's also have very stiff and low suspension, more seam welds, thicker sway bars (and more solid strut braces from the factory) |
09-03-2012, 07:30 PM | #6 |
12
Rep 437
Certain strut hat mounts and/or camber plates don't fit with stock strut braces, they however fit with M3 strut braces. Just throwing that out there when considering to upgrade your front strut support setup. Best would be as mentioned above, a 3 point system, pretty much a triangle on your engine bay.
E30 x2 Sold
E39 x2 Sold E46 x3 Sold E82 x1 Sold E60 x1 Furniture... |
09-03-2012, 09:14 PM | #8 | |
126
Rep 3,099
The stock 1er brace (at least in mine) isn't a full brace. It hits back to the firewall straight away where you'd want it to meet in the middle |
09-03-2012, 10:49 PM | #9 | |
N55 Commando
55
Rep 797
09-05-2012, 01:00 AM | #10 |
Supreme Allied Commander
3845
Rep 54,376
Drives: F80 M3
A brace designed to tie the firewall and the towers together will give you better rigidity then just a brace mounted between the two towers. The M3 style brace also spreads the load evenly over the tower, not just to one point only.
09-05-2012, 01:42 AM | #11 | |
126
Rep 3,099
09-05-2012, 02:13 AM | #12 |
3845
Rep 54,376
Drives: F80 M3
09-05-2012, 03:27 AM | #13 |
126
Rep 3,099
09-05-2012, 11:45 AM | #14 |
3845
Rep 54,376
Drives: F80 M3
