      08-23-2012, 04:10 AM   #1
flinchy
126
Drives: E82 135i
M3 Front upper+lower control arms $100's less than normal!
so in reading the thread ' E81- M3 E93 anti-roll bar and rear subframe bushings installed- REPORT!"
it was mentioned that a company 'trw' makes the M3's control arm items
any truth to this?
so far in googling, it seems like it to me, and at half the cost of any vendors 'm3 upgrade kit' .. well LESS than half the cost.. closer to a third of the cost..
this could be a huge find
thanks for any input.
      08-23-2012, 08:57 AM   #2
andrey_gta
andrey_gta's Avatar
298
Drives: 130i coupé ;)
2008 BMW 128i  [10.00]
as mentioned before, no one knows the quality of bushings. so maybe factor in the cost or replacement m3 bushings/ Other after market bushings.
http://www.trwaftermarket.com/
http://outcat-cs.tecdoc.net/ows/en/0...dexFramesetJsp
- i think this serves euro only market since i'm getting no price
TRW parts:
front?? control arm bushing - JBU774
JTC1423 Track Control Arm
Fitting Position: Lower Front Axle
Fitting Position: Right Front
Steering Type: Control Arm, Paired article numbers: JTC1424
JTC1424 Track Control Arm
Fitting Position: Left Front
Steering Type: Control Arm, Paired article numbers: JTC1423
JTC1426 Track Control Arm- Wishbone Left
Fitting Position: Rear
Steering Type: Control Arm, Paired article numbers: JTC1427
JTC1427 Track Control Arm- Wishbone Right
Steering Type: Control Arm, Paired article numbers: JTC1426
JTC1428 Track Control Arm- rear
Fitting Position: Rear Axle Upper
Fitting Position: Left Rear
Steering Type: Control Arm, Paired article numbers: JTC1429
JTC1429 Track Control Arm- rear
Fitting Position: Right Rear
Steering Type: Control Arm, Paired article numbers: JTC1428
JTC1430 Track Control Arm- rear
Steering Type: Control Arm, Paired article numbers: JTC1431
JTC1431 Track Control Arm- rear
Steering Type: Control Arm, Paired article numbers: JTC1430
JTC1432 Track Control Arm- rear centre
Fitting Position: Rear Axle Lower
Fitting Position: Centre
Fitting Position: Left and right
possible stores:
http://www.oembimmerparts.com/category_s/1837.htm <-- full m3 front TRW kit priced at $374 before tax & ship to most likely USA only
http://seekpart24.com/trw/track-control-arm-jtc1426
http://www.ebay.de/itm/Lenker-Radauf...-/260907888720
http://www.teilesuche24.de/trw/lenke...engung-jtc1426
before shipping the cost may be $50-$100 USD cheaper over nearest m3 kit supplier. Applying shipping, it may equal the same cost
another brand name: https://www.google.ca/search?ix=seb&...er&safe=active
not sure why it is listed as more expensive, doesn't seem to make any m3 parts. Reviewed to be same as TRW
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff
"The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is
      08-23-2012, 04:29 PM   #3
flinchy
126
Drives: E82 135i
For m3 front upper and lower, shipped to my door is about $750 (599ish no shipping)
So.. Yeah cheaper
If trw tuly is oem manuf, that means the bushings ARE m3 bushings anyway
And even an upgrade (i'd go powerflex) still comes out cheaper than straight m3
I'll check out all those links after work tonight though lol
Ed: jut had a google for '31 10 2 283 575' everything inicates it's an oem m3 replacement part made by trw
      08-24-2012, 12:30 AM   #4
flinchy
126
Drives: E82 135i
Another question.. The m3 lower control arm is totally different and adds camber.. The upper (tension rod) is different too, correct? Not just in the bushings? Ie, it's stronger etc and worth replacing for that too?
      08-24-2012, 10:39 AM   #5
andrey_gta
andrey_gta's Avatar
298
I guess it is what you pay for, the added feel good of having ///M stamped
TRW bushings look identical to m3 parts, both have red and green "washers"/seals
only for the control arm, everything else seems static.
Maybe RE bushings are priced okay, or other brand like AKG racing
Yes the lower wishbone adds camber.
the upper control arm may be just made to be lighter and stronger vs stock. I really don't know.
      08-24-2012, 11:39 AM   #6
Dackelone
European Editor
Dackelone's Avatar
Germany
10539
Drives: N54 e82
This is an interesting thread.
I recently looked at the M3/1M alloy suspension parts. They are really light units. Strong but light. Much more so than what our cars came with! I know I am gonna have to go with these M3 bits sooner or later.
      08-24-2012, 12:21 PM   #7
andrey_gta
andrey_gta's Avatar
298
Do you want to dig around for Euro prices for the TRW items above?
Also can you comment on the difference between these brands of OEM parts found on http://seekpart24.com/bmw/3-coupe-e9...ar-100017?lp=1
Metzger<- - usually listed cheaper than TRW, but images and refs point to simple 3 series parts
Lemforder<- - seems to have replacement m3 steering links, but that is all
Febi Bilstien<- - has some rear control arm components, but parts do not match up in realoem
TRW<- - reviewed to be on par if not more reputable than Meyle / Meyle HD. e34/e39 and e46/e36 guys have used their control arm parts. Have not seen any bad reviews for German cars. Some USA cars had issues maybe because of made in china items
      08-26-2012, 12:41 AM   #8
flinchy
126
Drives: E82 135i
from OEMbimmerparts
Subtotal:
$ 374.90
Shipping:
$ 162.04
Duty / Tax / Processing:
$ 47.61
Order Total:
$ 584.55
to australia, TRW front control arm and tension rod - BUT it's not listed as 'trw' it says 'oem' but is made by TRW, this sounds good to me?
the cheapest i've been able to find elsewhere that will ship directly here was more like $749 shipped
$225 saving! (though you don't get the headlight adjuster rods, no matter since i don't have adaptive headlights ) - and a quick google tells me that 'oembimmerparts' is a legit site (results from other BMW forums mainly)
done!
      08-26-2012, 08:25 PM   #9
andrey_gta
andrey_gta's Avatar
298
Here is Canada using OEMbimmerparts
Shipping:
$ 121.10
$ 132.57
Order Total:
$ 628.57
Some savings, can be used for a sway bar, used DISA, tune, etc.
I think shipping will make or break this path, comparing costs without shipping will not do much.
      08-27-2012, 12:32 AM   #10
flinchy
126
Drives: E82 135i
Shipping:
$ 121.10
$ 132.57
Order Total:
$ 628.57
where does that site list swaybars?
i even searched for sway bars, no dice
heck, how can you get a used DISA or a tune from oembimerparts :/
also
They are OEM as stated in the listing, OEM means original equipment manufacutre, Which means they are made by the same company that makes them for bmw. In this case TRW. Yes they do include the bushing as well.
Max
Max @ Oembimmerparts
Oembimmerparts.com "Where the BMW Enthusiasts Purchase Parts"
legit OEM m3 parts confirmed - placing my order, since i'm going to save $225 lol
      08-27-2012, 08:23 AM   #11
andrey_gta
andrey_gta's Avatar
298
That was me talking to my self Saying that the 200+ or so saved can be used else where. LOL
Btw check http://www.ecstuning.com/
they have TRW branded m3 arms too
And let us know what vendor you will use, the shipping cost is what I worry the most about. I usually get a customs fee anywhere between 15-20%
      08-27-2012, 05:40 PM   #12
flinchy
126
Drives: E82 135i
as in the other thread, ECS has much cheaper shipping, as well as stocking the headlight levelling arm
1addicts
