08-22-2012, 10:41 PM | #1 |
Lieutenant General ***
61
Rep 751
Wastegate Ticking/Rattle
I went to the BMW stealership and was charged $130 for a diagnostic test on my car, that they didn't diagnose.
So I decided to fix it myself with the help from Mr.5's DIY. It works! I went to SEARS to get a 4mm, because Lowes, Harbor Freight or Home Depot didn't have one. Also, remember your space is very limited while working in there so you'll need small wrenches. In case you're not sure what you're looking for, watch the quick video. (recorded with my phone) Originally Posted by Mr. 5 I take no responsibility for what you do with your car. What you do is at your own risk! As some of you know, I've had some problems with my wastegates rattling. I was one of the first to have this issue. If you don't know about this issue then read the link down below and look at the pictures. It will help you understand this issue. I started this thread once I found what I thought was the issue but then I realized that it had nothing to do with gaps where I thought. http://www.e90post.com/forums/showthread.php?t=132037 I closed that thread because of a couple reasons: 1. If you want it done professionally and you don't care about the extra lag and the less power with tunes then you need to take it into the dealer and have them fix it. 2. This really is a solution to the problem. In most (if not all) cases that I know, the wastegate ticking is caused from the rear wastegate ticking. The front one is perfectly fine. First off, how is everything working? When you start the car with a pre 29.2 program, the rear wastegate shuts at idle to decrease some of the lag. The solenoid is controlled electronically to control the actuator with a vacuum. This is why there is a vacuum line going from the solenoid to the actuator. When the actuator is being controlled with a vacuum, the actuator rod gets sucked into the actuator, which pulls the wastegate closed. The ticking is the sound of the wastegate rattling against the seal if there is not enough pressure keeping it closed. Why does 29.2 solve the issue most of the time? Because with this program, when you start the car up, the rear wastegate is not closed anymore. It is open. Therefore, there is nothing to rattle against any seal. Here is the issue: The Actuator Rod is loosening after time. When the rod loosens, the length of the rod increases and increases, eventually making the wastegate not seal properly. Since there eventually becomes little to no pressure against the seal, then the wastegate rattles against the seal, causing the ticking sound. I took my car to the dealer and they told me that in order to fix the problem, they would need to first update the program to the newest software before they touch the wastegates. The dealer does not adjust the actuators. They are told to replace the actuators with brand new ones and then adjust the new ones. So, because of this, I refused the service. Let's think about how to fix this: There is the one 10mm nut, and there is a groove on the actuator rod, which is meant for a wrench to adjust. I figured, why I can’t I do this? The first thing you need to do is loosen the 10mm nut. Second, you need to find a wrench that's small enough to fit in the groove of the rod. I actually made one using a regular piece of scrap metal in the garage and a dremel to cut a groove in it since I don't have tools that small. Once you have the tool, tighten the rod a couple revolutions (this is subjective because some ticking could be worse than others). Of course, you don't want to tighten the rod up that much since the wastegates still need to open. Seriously, for those out there that never ever wants the new program because of the lag and all the crap that goes with it, this really is an easy solution for you to do if you are somewhat handy. I take no responsibility for what you do with your car. What you do is at your own risk! |
08-23-2012, 01:19 PM | #2 |
87
Rep 808
Why did you not press the issue at the dealership instead of DIY? There is a recall on the wastegates, you could possibly have defective parts so the adjustment is a temporary solution at best.
08-23-2012, 01:41 PM | #3 |
2454
Rep 7,341
Why would you have to pay a diagnostic fee??? That makes no sense to me...
The views and opinions expressed in this post are those of the author and do not necessarily reflect the official policy or position of Bimmerpost.
2018 Jeep Grand Cherokee High Altitude Hemi | 2010 S4 Sold | 2010 BMW 135i Retired | 2006 Lotus Exige Sold |
08-23-2012, 02:20 PM | #4 |
17
Rep 144
What dealership did you go to in the Boston area?
2009 BMW 135i - Alpine White/Coral Red - M-Sport+Premium + 6-Speed Manual
08-23-2012, 02:25 PM | #6 |
Resident Kerbalnaut
478
Rep 10,703
I'm in the midst of doing this now! New turbos at 78K
08-23-2012, 04:03 PM | #7 | |||
61
Rep 751
Sudbury Quote:
Congratulations! I hope when I return everything to stock, things go smoothly. What mods do you have? Last edited by UsualSuspect; 08-23-2012 at 09:55 PM.. |
08-23-2012, 04:32 PM | #8 |
87
Rep 808
08-23-2012, 04:36 PM | #9 | |
Resident Kerbalnaut
478
Rep 10,703
My car sounded like a bicycle coasting! |
08-23-2012, 04:43 PM | #10 | |
87
Rep 808
So did the dealer try to just replace the wastegates first or did they own up and replaced the turbo's without hesitation? |
08-23-2012, 04:51 PM | #11 | |
Resident Kerbalnaut
478
Rep 10,703
http://www.1addicts.com/forums/showthread.php?t=733801 Sorry OP! |
08-23-2012, 09:54 PM | #12 | |
61
Rep 751
08-24-2012, 12:28 PM | #13 |
87
Rep 808
He is getting bent over on this. I may start a thread highlighting owners cases and the dealers issuing repairs or denials to help show who is getting help or screwed, and why.
08-24-2012, 12:36 PM | #14 | |
Resident Kerbalnaut
478
Rep 10,703
Just got told "Youre wastegates have failed, but they havent failed enough to constitute a replacement" What a load of shit. In the last week it went - come in we need to replace everything, to, well sorry youll have to come back later. |
08-24-2012, 12:40 PM | #15 | |
87
Rep 808
Does your car have the symptoms described in the bulletin? If so, it's open shut - there is not a mention of gradiation of failure, it either failed or didn't, period. I would be hot man, push it and push it. Bring the car back daily, make them work, and be a thorn in their side until they do it right. Shit like this pisses me off. You shouldn't have to fight it. They get paid by BMW, wtf do they care if they repair/deny the claim? |
