08-18-2012, 02:05 AM | #1 |
38
Rep 652
Koni Sport Yellow HELP
How are you all adjusting the fronts post install with that strut bar in the way? I haven't adjusted mine yet but want some feedback!!
So far I love them btw.... Interestingly my rears which did rub on stock m sport don't rub now on koni yellow and eibach
2012 BMW 135i M-Sport PPK AW with Black Boston Leather- SOLD
2010 Acura TSX V6 Tech BSM 2003 Corvette Z06 TR "Widebooty" |
08-18-2012, 10:16 AM | #2 |
Pablo
39
Rep 263
You have to disconnect the strut brace. I installed the M3 front strut brace (as modified and sold by HP Autowerks) to have easy access to adjust the Konis. Look at HPs website and call Harold (the man) who can answer all your questions.
BMW PPK V2, M3 26mm sway bar, M3 front control arm kit, M3 steering wheel, BMW 313 wheels w Michelin PSS
08-19-2012, 06:42 PM | #3 |
43
Rep 272
Drives: 2008 128i
I made a small notched tool to fit under. I'll show a pic when I get home from vacation.
Afe Scoops and CAI, PBX, BMS Paddleshift upgrade, 261M's Powder Coated Gunmetal, 225/255 Michelin PSS, (BMW Performance: BBK, Illuminated Door Sills, Shifter Knob and Boot, E-Brake Handle, Steering Wheel, Front Strut Bar), E93 FSB, E92 RSB, M3 Rear Subframe Bushings, M3 Front Control Arms, HPA coilover kit (Koni Adjustables and Swift Springs), Steel Brake Hoses, Black Kidneys, Smoked LED side markers, Blacklines, Msport lip spoiler...
08-22-2012, 01:39 AM | #4 |
Supreme Allied Commander
3845
Rep 54,376
Drives: F80 M3
Either get the M3 style strut tower brace kit, remove the oem strut bar at adjustment time or make a special tool to allow easier adjustments.
08-22-2012, 03:42 AM | #5 |
Cone Cruncher
31
Rep 534
The cheapest fix is to use a couple of washers and move the OEM strut bars up a bit and out of the way for daily driving. When you want to adjust them, then remove the bolt, raise the bar, and adjust.
The more elegant solution is the M3 style strut tower brace that HPA sells. |
08-23-2012, 09:56 PM | #6 |
38
Rep 652
Guess the m3 bar is the way I am going
