08-16-2012, 03:11 PM | #1 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
BPMsport: Coding Services
BPM Sport was created to provide the best ECU coding, tuning and performance engineering for the European car market. Our combined expertise ranging from IT engineering, market analysis, to race- proven cockpit experience, fuels our passion for cars. Our goal is to help envision, create and tune the best aftermarket vehicles for our clientele.
Over 10+ years experience in module coding Fully Equipped with Factory BMW Dealer Software (ISSS, ISTA/P (Programming), ISTA/D (Diagnostics) Fully Equipped with Factory BMW Engineering/Expert Software for E-Series and F-Series platforms Factory Programming and Coding Hardware ICOM A (For Factory Coding/Programming/Diagnostics of F Series Ethernet, D CAN, and KLINE Vehicles) ICOM B (For Factory Coding/Programming/Diagnostics of MOST BUS (Fiber Optic 2008-2012) Vehicles ICOM C (For Factory Coding/Programming/Diagnostics of Legacy OBD I Vehicles) Factory Ethernet Communication System for Programming/Coding/Diagnostics on F Series Ethernet equipped Vehicles Proper Voltage Stabilization maintained with 75 Amp Microprocessor Controlled Battery Maintainer/Stabilizer Non-biased programming facility, with no fear of warranty rejection A partial list of our coding is below. Check out our entire offering at www.bpmsport.com/coding.php NEW: Euro MDM (M Dynamic Mode) mode activation (much better than the US spec) For E9x M3/ E6x M5/ E6x M6 Coding/Individualization - Video In Motion (CIC iDrive models only) - Remove BulbCheck errors (for HID/LED or aftermarket lighting retrofits) - Windshield Wipers complete full cycle when ignition is shut off - Remove Ignition/Door gong - Remove iDrive [ACCEPT] screen - Remove Seatbelt warning gong for Driver, Passenger or both Driver/Passenger (light remains on dash) - Unlock doors when key is ejected - A/C off when Auto Climate is pressed - Auto Sunroof close when rain is detected - Open/Close windows with Key FOB - Open/Close Windows with Comfort Access - Open/Close Convertible Top with Key FOB - AutoFolding Mirrors - Change Low Fuel Warning from 1/4 tank to 1/8 tank - Remove CityLights (Amber sidemarkers) - Enable FogLamps with High Beams - Disable Window Safety Feature (allows windows to continue rolling up while door is open) - Enable Digital Speedometer in OLED gauge cluster - Enable/Disable auto-correction for Digital Speedometer/MPG - Euro SMG Software Updates for e46M3, e60M5, e63 M6 (~5000RPM Launch Control, improved shifting) - Euro Hazard Lamps (double flash vs US single flash) - Triple Blink turn signals - Mirror Curb tilt - Automatic Door Locking - Auto Trunk/Tailgate Closing Retrofit Options - LCI Taillight and Headlight Retrofits - Park Distance Control (PDC) Retrofits - Halogen Highs enabled with Xenon High Beams - OEM Alarm Coding - iDrive CCC-CIC Conversions/Upgrades - LCI Headlight Retrofits - FRM2 and FRM3 Module Upgrade/coding - Sirius Radio Retrofits - IBOC HD Radio Coding - Heads Up Display (HUD) - CD CHanger, iPod/MP3, Dension & mObridge Coding - Bluetooth Retrofits RaceCar/Track Preparation Setups - Remove TPMS - Race Seat Coding/Recaro Coding/BMW Performance Seat Coding - EDC Delete (for coilover setups) - Airbag deletes for vehicles with roll cages - Remove Headlamp Washer System CBS Coding - Flash Programming - Dealer level ECU Software Coverage - ECU Permanent Substitution - Quick Test & Quick Clear - Fault codes timeline report - CBS: Condition Based Service reset and error correction - Retrofitting of BMW accessories and extras - Car/Key Memory Function for personalizing vehicle Service Options - Module Troubleshooting - Reset Adaptions - Module value Monitoring - Value Reporting (Fuel Pressure, Ignition Advance, etc) BMW Dealer-Level Module Updates - Individual Module Updates, including Engine ECU, TCU/ULF/mULF and iDrive - MKIV, CCC & iDrive OS updates |
08-20-2012, 10:54 PM | #2 |
228
Rep 447
Pm'd you the other day. let me know if you got it.
DCT. Custom Cantrell MS cage. Fire, SCCA, dedicated track. Diffs-online 3.62, diff cooler, MCS 2-ways, SPL arms, TMS solid SF/Diff bushings, RD sway, DO88 Coolers (DCT, RAD, PS, OIL) Akra catless GT4, BPM tune, Hans Recaro, AP Pro 5000R, Cobalt XR2/4 race pads, BBS E88's, Yoko A005 slicks, RKP GT4 Splitter, GT4 canards, APR GT250 Wing, CFK Hood, Flossman CFK fenders, BW carbon doors, Dinan R toe links, Mini battery.
08-21-2012, 08:18 AM | #3 |
307
Rep 13,093
