08-16-2012, 03:05 PM | #1 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
BPMsport: Tuning Services
BPM Sport was created to provide the best ECU coding, tuning and performance engineering for the European car market. Our combined expertise ranging from IT engineering, market analysis, to race- proven cockpit experience, fuels our passion for cars. Our goal is to help envision, create and tune the best aftermarket vehicles for our clientele.
Over 10+ years experience in module coding Fully Equipped with Factory BMW Dealer Software (ISSS, ISTA/P (Programming), ISTA/D (Diagnostics) Fully Equipped with Factory BMW Engineering/Expert Software for E-Series and F-Series platforms Factory Programming and Coding Hardware ICOM A (For Factory Coding/Programming/Diagnostics of F Series Ethernet, D CAN, and KLINE Vehicles) ICOM B (For Factory Coding/Programming/Diagnostics of MOST BUS (Fiber Optic 2008-2012) Vehicles ICOM C (For Factory Coding/Programming/Diagnostics of Legacy OBD I Vehicles) Factory Ethernet Communication System for Programming/Coding/Diagnostics on F Series Ethernet equipped Vehicles Proper Voltage Stabilization maintained with 75 Amp Microprocessor Controlled Battery Maintainer/Stabilizer Non-biased programming facility, with no fear of warranty rejection Information about our performance tuning: MW E9x M3 S85 DME Tuning Software - MSS60 Features/Benefits: Raised RPM limit to 8600 (at customers request) Removed top speed limiter Removed cold start cat heat cycle for smoother cold starts Reprogrammed torque management parameters Reprogrammed throttle response in both normal and sport modes (aggressiveness per customers taste) Reprogrammed ignition timing, and optimization for your fuel quality (91-100 octane tunes) Reprogrammed Vanos control for maximum drivability Sharper throttle response and smoother engine operation Cold start redline reduction (to prevent abuse while engine is cold) Freestanding rev limit/manual launch control for 6MT cars Software available for US, European, and Canadian specification cars. Cat delete for cars that have an SES light due to exhaust modifications (off road use only!) Will not effect emissions testing! You may see a very slight increase in fuel economy. (Will retain check engine light functionality for any other detected malfunction) Includes an update to BMW's latest factory DME software. Feel free to mix and match the options available above, the tune will be calibrated per your spec and accounting to your modifications (i.e, tune is different for cars with cats, highflow cats, and catless) Note: -Catless and high flow cat software is for off road use only. -All software programming is completely reversible. -All software has been dyno, track, and street tested for maximum reliability and engine longevity. |
