08-12-2012, 09:00 AM | #1 |
30
Rep 362
I just took off my runflats and I miss the sidewalls.
So I took off my runflats to run pilot super sports (I was told they would be as wonderful as my last set of PS2s - which I ran on an s4 with coilovers)
At this point I'm not sure I dislike the pilot ss's but I think the lack of the stiff sidewall has really made the car less confidence inspiring in cornering. I'm wondering of I can do any minor mods to get the car back to the original feel. I'd rather not do a full suspension because the road height is nearly perfect. Maybe bars can make this difference up? -- Yes it said sidewalks before --
Alpine White E82 135i 6spd Manual
Factory Alarm | Clutch Stop | Alflugen 18 CS7 Hyper Silver Shadow Blue MK6 GTI 4-Dr DSG Euro OEM Reverse Camera | Last edited by Bruck; 08-12-2012 at 10:11 AM.. |
08-12-2012, 09:21 AM | #2 |
31
Rep 409
Drives: 2008 Montego Blue 135i
Try the front sway bar and maybe Koni Yellows. If you hare happy with your ride height, but want better springs you can buy the BMW performance springs or H&R OE.
There are no impossible deeds, only incapable men.
Eibach frontsway,BMS JB4,AFE Drop InBerk Street Axleback, H&R SPORT SPRINGS,Active Autowerke DP's ,Active Autowerke BOV,Active Autowerke FMIC , BMWPEDALS.COM, JB SPEED Black Grills,Alpina B3 TCU Flash |
08-12-2012, 09:33 AM | #3 | |
37
Rep 2,084
You can also try tire pressures at the upper range like 40. Maybe you'll get used to it and can gradually decrease the pressure. |
08-12-2012, 09:38 AM | #4 |
30
Rep 362
When you say Front Sway are you suggesting the 26.5mm or the 28mm?
Factory Alarm | Clutch Stop | Alflugen 18 CS7 Hyper Silver Shadow Blue MK6 GTI 4-Dr DSG Euro OEM Reverse Camera | |
08-12-2012, 10:06 AM | #5 |
31
Rep 409
I have the Eibach 28mm bar and I've benn very happy with it.
08-12-2012, 10:07 AM | #6 |
bimmerphile, technogeek
998
Rep 3,784
Drives: 2012 E82 6MT Sport
You miss the sidewalks??
08-12-2012, 10:10 AM | #7 |
30
Rep 362
08-12-2012, 10:51 AM | #8 |
406
Rep 1,348
Yeah, what are your tire pressures set at?
21 BMW X5 xDrive40i
20 BMW M2 CS 19 Mini Cooper S Countryman ALL4 6MT |
08-12-2012, 11:49 AM | #10 |
302
Rep 913
runflats are runflats because the sidewalls are so heavily reinforced--making them *super* stiff. the problem switching to non-runflats is that nothing will have as stiff a sidewall, leading to a feeling of mushiness in comparison.
08-12-2012, 03:22 PM | #11 |
30
Rep 362
This is a great question - I can only assume they are set to the door sticker pressures which I believe are 38-ish?
08-12-2012, 04:48 PM | #13 |
121
Rep 2,037
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
Yep, inflate them harder. Next time try to find the stiffest sidewalled nonRFT that you can find.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
08-12-2012, 05:29 PM | #14 |
Rep 182
I have gone to PSS from RFT on 2 cars, and I agree that this had the immediate effect of increasing comfort (far less harsh on bumps), better traction, less road noise, and generally just all-around better. However, you do feel a little less immediate turn-in response as the sidewall gives a tiny bit. So I understand the post.
Adding the M3 front kit, adding a bigger front sway, etc. will help with the feel (for different reasons) without any negative effects. And these are quite inexpensive and easy to install (you could do all of these for well under $1000). I went with the BMW PS setup (got a great deal on it very lightly used) along with M3 bits, and it's been FANTASTIC - much more comfortable and quiet than stock, and much more performance too. And only a TINY drop in height. Very highly recommended.
2009 E90 335i - All go, no show
Mr. 5 Intake, VRSF FMIC, Quaife LSD, BMW PS, M3 Bits, RE Toes, ER CP, Forge DV, JB4, PSS |
08-12-2012, 05:46 PM | #15 |
44
Rep 1,265
I ran a set of PSS when they first came out.. I was coming from Dunlop Direzza Star Specs and had mixed feelings about the tires. The PSS' had a noticably softer sidewall from even the Direzza's but the trade off I noticed was wayyyyy less road noise.. Dirazza's are pretty annoying from road noise. With that said after 1 season of autox with no negative camber the PSS' were dead and went back to Direzza's. Direzza's are a great tire if you can get over the road noise they emit.
08-12-2012, 06:27 PM | #16 |
Mbira
30
Rep 1,011
Drives: Sedonna Red 09 135i SOLD
I did not want to give up the stiff sidewall turn in feeling from the RFT;s so i went with a tire with sidewalls as stiff with MUCH stickier rubber for superior handling and grip and chose Yokohama ADO8.s.. They have far surpased my expectations and actually are wearing really well....although i am fairly easy on my car so...but in the hot weather the tires feel like they have teeth. The cheapest way to improve your issues is as stated try to inflate the tires more and see if that helps if not sell the PSS and get the ADO8's....You will not loose hardly any money selling the PSS as they will go quick...Plus the tread pattern is very cool on the Yoko's...Good luck..
08-13-2012, 12:06 AM | #18 |
126
Rep 3,099
Front lower control arm, front upper tension rod, most places seem to have it for $500-$600, i think turner is $599 USD or so
08-13-2012, 12:19 AM | #19 |
Rep 182
http://www.trademotion.com/partlocat...catalogid=4462
It's $515 there, no negative impact to installing these, takes 1 hour, will need a new alignment afterwards.
08-13-2012, 03:04 AM | #20 | |
298
Rep 4,040
Drives: 130i coupé ;)
Great thread, will certainly take all this info into account when i go non-RFT.
Where can we get sidewall stiffness ratings??? Quote:
Did you need an alignment afterwards??
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff "The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is |
08-13-2012, 03:35 AM | #21 | |
126
Rep 3,099
Their 'rsb' addon seems fishy though... $240 for 2/4 bushing when turnee has them for $240 for all 4? Haha |
08-13-2012, 05:41 AM | #22 | |
37
Rep 2,084
It's been 2.5 years , but I remember steering effort is slightly more, steering precision is better, and there's more road feel through the steering wheel. |
