08-11-2012, 12:43 PM | #1 |
460
Rep 4,531
I'm going to become a track rat
Finally finished up my first HPDE yesterday at Mid-Ohio!
Caught 2 wet sessions in the AM and 2 dry sessions in the PM. The wet was an interesting experience, little to no traction certainly sums it up. But it was good experience. There are plenty of areas to work on, obviously. China Beach, Madness, The Esses is a pretty tricky section to get it right. I was being a baby braking into China Beach...the first session I hit oil into the braking zone and it was not a fun experience. Kept it straight and all...just had the o-shi moment. It was still a little cold and the track wasn't completely dried up, so threshold braking wasn't really worked on at all Overall though, It was really fun. I'm amazing at what type of grip is out there. Here's my last session. Critique if you want. |
08-11-2012, 01:57 PM | #2 |
Dog Listener
703
Rep 7,850
Too long to view all of it now. But, looks like you have another addiction to add to AutoX. Looks like a fun track, with elevation changes, off camber turns, esses, etc. That's great, as it means there's a lot to learn and practice on! Also looks like you're not making "fast in slow out" mistakes, excellent. I like wet track days, as it really forces one to slow down a bit and take a very smooth approach to inputs in order to maximize all available traction. Track is very different from AutoX isn't it? (I went the other direction, and it was another world, but a fun world that opened up.)
08-11-2012, 01:58 PM | #3 |
149
Rep 688
Nice to see another guy get bit by the track bug! haha Good luck and have fun!
Lone Star Chapter BMWCCA HPDE Event Chair, Texas Trifecta Event Chair, & BMWCCA driving Instructor |
08-11-2012, 09:22 PM | #4 | |
460
Rep 4,531
This track (apparently) has a reputation of being extremely slick under wet conditions. The esses is actually all polished, so slick it was crazy. I was sliding every time around. It was pretty funny. I asked the instructor where exactly the wet line was prior to heading out the first session and he responded "Wherever you have traction". That certainly summed it up. AutoX is COMPLETELY different. It was really hard to get it down. 1 single steering input and using the throttle to control the steering. Thanks! |
08-12-2012, 11:06 AM | #5 |
460
Rep 4,531
It this common to see on tires after a track day?
It's rubber build-up from other cars it seems. Any easy way to get this off besides peeling it by hand? |
08-12-2012, 02:10 PM | #6 |
Dog Listener
703
Rep 7,850
Yes, common, and I haven't found a great way to remove it other than to drive it off (I'm not patient enough to remove it by hand).
Some is from other tires, some is from your own (heat, friction, degree of slip angle, etc.). Bottom line, it's part of the game. What kind of hot tire temps were you running? (Learning the track, and the line, means being a bit offline a bit, and that tends to increase the addition of "marbles" to your tires.) Last edited by Finnegan; 08-12-2012 at 02:20 PM.. |
08-12-2012, 02:18 PM | #7 | |
460
Rep 4,531
08-12-2012, 02:26 PM | #8 | |
Dog Listener
703
Rep 7,850
Star Specs aren't so bad, and the tread blocks, and worn tires mean less tread squirm (and heat). I've also learned to control my slip angles a bit more and don't work the tires quite so hard, which means more consistent tire temps (and consistency of traction) during a session. Again, normal stuff, and goes with the game. The other stuff about managing tires, and etc. just comes with tire, instruction, experience, etc. Nothing new there either, same as learning the tricks and little things in AutoX. |
08-12-2012, 03:39 PM | #9 | ||
460
Rep 4,531
