07-31-2012, 09:53 PM | #1 |
Supreme Allied Commander
3863
Rep 54,426
Drives: F80 M3
BMW 1M Adjustable HD Swaybar Endlinks
When you lower your 1M with aftermarket coilovers, the swaybar is moved from the ideal factory geometry to an offset that decreases the ability of the swaybar to perform. The swaybar frame mount and the end of the bar should be on the same horizontal plane. The factory end links are a solid piece. When the car is lowered, the OEM links cannot compensate for the longer length needed to keep the swaybar in its ideal location. Get immediate response from your sway bar and precise control over your suspension. What this means to you is tighter, more responsive handling.
HP Autowerks is happy to introduce these HD 1M adjustable end links. With adjustable end links you can return the bar to its ideal leverage point while lowered. They also afford the peace of mind that the links or shock link mount will not fail as is common in factory units, as they will now be adjusted properly. HP Autowerks end links are adjustable while on the vehicle. Stock length is 13" and the most popular lenth we sell is 13.25" with another 1.25" of adjustments to cover just about all coilover applications, including AST, JRZ, Koni, KW and Moton. Please inquire on special lengths to fit your particular needs. ***These links will not work with OEM struts*** |
