07-29-2012, 06:38 PM | #1 |
The Crowing
111
Rep 2,005
Dyno Read
I finally got her on the Dyno. i'm set up with an Injen short ram air intake, Berk Tech axle back race exhaust and JB4 stage 3. if you want to see the runs there on a friends you tube page. http://www.youtube.com/user/loesch8102/videos
i thought the numbers were pretty good for all the more i have done to it. any feedback questions comments or advice would be greatly appreciated. thanks.
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback |
07-29-2012, 06:49 PM | #2 |
The Crowing
111
Rep 2,005
the yellow is AFR, didnt notice its not labeled till right now.
07-29-2012, 07:01 PM | #3 |
736
Rep 3,274
That's really great! From what I know DYNOmite dynos are like Mustang dynos and would read lower than most dynojets. You have very healthy torque numbers for a low reading dyno with pretty much just a JB4 and light mods. Our cars always seem to put down more torque than HP tuned, so you'd have definitely breached 350 or even 360 HP on a dynojet I think... just for comparison to what others usually post from the dynojets. Impressive for no downpipes or meth.
2022 X4 M40i - 2008 135i - 2015 F700GS On Order - 2024 i4 M50 Scruffy's gonna die the way he lived... Mmhm. |
07-29-2012, 07:10 PM | #4 |
The Crowing
111
Rep 2,005
Thanks for the input! I don't know much about other dynos. I wish there was an easy way to find out the crank hp. I think 345 hp to the wheels is a fair statement. I'm extremely happy with what the output is after 3 peices are bolted on. Looking to get downpipes and inter cooler but that's going to have to wait until I hit the lottery. Haha! Or probably next summer. This is my everyday driver so i don't want to have to deal with messing up the emissions crap.
07-30-2012, 12:32 AM | #6 |
80
Rep 655
That torque curve looks pretty ragged to me. Does it drive alright?
Doesn't look like it holds the torque well and peaks very early. Can you log it and make sure it looks good? |
07-30-2012, 07:24 AM | #7 |
The Crowing
111
Rep 2,005
I did a baseline run as well. Lines were still ragged. The numbers came out to around 280hp. Don't remember what the torque was but it was pretty much the same as what I've seen with other readouts of a stock 135i. I would think you would already know what it should be putting out stock. I logged a run on the JB4 software and sent it to Burger to look at that ragged line. The run was on map 5, the auto tuning map. He said because of the really hot intake temp the auto tuning kept backing off to compensate and reduce the knock. It runs great. Doesn't pulsate or anything like that. Burger said everything looks good. This was on pump 93 octane gas. They said that if I ran 100 octane it would help with the line and give a little more power. Still think its badass. Just wish there was an easy way to take those numbers and figure the crank hp.
07-30-2012, 12:05 PM | #8 |
The Crowing
111
Rep 2,005
Any one else out there with dyno read outs please post for comparison?
07-30-2012, 12:31 PM | #9 | |||
80
Rep 655
Here's my dyno chart on California 91 Octane (worst gas money can buy pretty much): Notice how much longer my torque goes up than on your chart and how much smoother it builds and tapers off. The car is very driveable with this tune and strong throughout the revs. Quote:
Figure 15% drivetrain loss and calculate: <rear_hp> / 85 * 100. So in your case 343 / 85 * 100 = 404hp. |
07-30-2012, 08:43 PM | #10 |
The Crowing
111
Rep 2,005
Wow! That is really smooth. I wonder if a new fmic will actually make that gigantic of a difference. I thought our cars were supposed to max out torque early? Pretty new to this stuff so I'm not really sure. Wish I could come into the money for a fmic. It sucks being responsible.
07-31-2012, 08:50 PM | #11 | |
56
Rep 467
I had a JB4 initially but went with Cobb because my old Subaru tuner is a Cobb Pro tuner. Check out the base line with a Cobb OTS map vs his "tuned" map. Nice number for just intake and exhast! |
07-31-2012, 11:45 PM | #12 |
33
Rep 578
I'll throw mine out there since it looks different than the others posted. A flatter torque curve.
2008 135i - MHD/JB4, MS DP's, AMS IC, UI CAI, CDV delete, M3 control arms/Links, RE Toe Link, ECS Trailing Arm, M3 rear SF & Trans bushings, SS brake lines, Michelin PSS.
08-01-2012, 06:23 PM | #13 |
The Crowing
111
Rep 2,005
I wish my read out was as smooth as those reads. Pretty excited about getting a fmic too! Got to start saving! hopefully that will help it smooth out. It runs good now and I don't race it on a track. I think when I get a fmic and downpipes I'm going to pay for a custom tune. Think it's worth the money for a custom tune?
08-01-2012, 08:22 PM | #14 | |
80
Rep 655
Seeing that Cobb torque curve again makes me glad I switched to GIAC
Honestly, I wouldn't worry too much about it. Dynos differ, cars differ, conditions differ. If you say your car runs great, I wouldn't worry about what the graph looks like. I only asked about those fluctuations because it would seem like you'd notice that while driving and also because I could only imagine that the ECU is pulling timing or having boost issues at those points. The curve just looks odd. But if the car runs fine and the logs look good, just enjoy your car! Quote:
Personally, I'm very glad I switch to GIAC. Compare your dyno chart and the Cobb ones posted here. Look how early your torque peaks. I had that before and it was no fun to drive on the autocross track or otherwise. Much happier with the new setup - much more "real world". But again, don't sweat the dyno chart too much. It's much more important how well it drives and how it makes you feel. |
08-01-2012, 09:36 PM | #15 | |
33
Rep 578
08-01-2012, 10:09 PM | #16 | |
56
Rep 467
08-01-2012, 10:19 PM | #17 |
56
Rep 467
[QUOTE=int2str;12430214]Seeing that Cobb torque curve again makes me glad I switched to GIAC
You have a tuned N54 car, it's all about the torque with this motor. I don't care what chip/tune/mod you put on the car. Car is a neck snapper when tuned right. That's part of the fun. I'd go N/A M3 if I wanted linear smooth acceleration. It's so nice when you can feel the boost kick in, it's the best part of having a turbo car...not to mention two turbos. I'm with Brusk, it's about kicking some ass off the line too, if you have the limited slip, man, bring that torque. |
08-02-2012, 12:13 AM | #18 | ||
80
Rep 655
I'm not going to argue one way over another. I'm simply glad I switched. I beat my nearest class rival at the last autocross by nearly a second, that's all I need to know. Quote:
Yet, with 360+ rwhp on 91oct., I certainly don't have to hide from one either. |
08-02-2012, 08:59 AM | #19 | |
33
Rep 578
08-02-2012, 09:01 AM | #20 | |
33
Rep 578
08-02-2012, 06:38 PM | #21 |
The Crowing
111
Rep 2,005
I do like how it builds boost really quick. Ill probably dyno it again after I do any more mods to it. If the stock maps that come with the JB4 doesn't give me a smoother longer torque curve I'll think about getting a custom map done. Cause if I do more mods in going to have to start hitting up the track. I have the JB4 limiting boost in first and second gear anyways to reduce tire slip. Once up to speed I like being able to have instant push in third. thanks for all the comments guys.
08-02-2012, 06:39 PM | #22 |
The Crowing
111
Rep 2,005
O yeah what is VANOS?
