07-24-2012, 05:48 AM | #1 |
126
Rep 3,099
Rear Subframe Bushing upgrade: what to get
i see there's a large range available on http://www.turnermotorsport.com/BMW-...nd-mounts.aspx
it's a DD, on fairly decent roads, will be matched with just about all other upgrades possible and a decent set of coilovers (spring rates not yet known) - and really unless it's going to be intolerably harsh, i'm more keen for better handling and flatness. turner solid alu ($300ish) or oem M3 bushings for $255 would the solid alu ones offer much better handling for not much worse harshness? $45 extra seems not bad to me? i'm guessing the M3 ones are actually urethane, not 'rubber' rubber? too? |
07-24-2012, 07:13 AM | #2 |
P1
Rep 106
I'll add a 3rd option in for you http://www.akgmotorsport.com/catalog...ion%2FBushings
I've got no experience with any of them. I am fairly certain that the M3 ones are just solid rubber rather than our stock ones which have holes/gaps in the rubber to allow more deflection.
'86.5 325eis Track Ho | '08 128i Daily | '16 Tacoma
07-24-2012, 09:04 AM | #3 |
89
Rep 3,732
Drives: BMW S1000XR
Buy these...
http://hpashop.com/BMW-Rear-Subframe...e-bushings.htm search for Dackelone's review and my review.
BMWCCA member |
07-24-2012, 09:24 AM | #4 | |
European Editor
10539
Rep 22,992
+1. Here is my writeup... Dackel's replacement of rear suspension OE bushings with M3 ones… http://www.1addicts.com/forums/showt...frame+bushings I would go with the M3 bushings. They really do not ride much harsher than stock bushings. But they do not allow the rear axle to move around like the OE bushings do. Gone forever will be that rubber band effect when you get on the gas in a corner! You should also search for user; Wolfe He tired several transmission bushings (on his 128i, 6MT) - to get a more positive shifter feel. In the end he went with M3 units. I think that says a lot about how well the factory M parts are made. He felt the hardened aftermarket bushings just were too rough of a "feeling" to deal with day in and day out. I am still VERY HAPPY with my M3 bushings. Our cars should have come with it!! The ride is great, yet the control is there when you throw the car into a turn or drive at high speeds. I really like them. Dack
07-24-2012, 09:06 PM | #5 | |
126
Rep 3,099
The akg urethane ones look pretty nice.. Argh choice! Now i have 3 (or 4?) to pick from lol |
07-24-2012, 10:15 PM | #6 | |
89
Rep 3,732
Drives: BMW S1000XR
Also, your link...the rear subframe bushings look very similar to stock. The exception would be the Delrin Al bushings, but I think those were made for racing.
BMWCCA member Last edited by ken1137; 07-24-2012 at 10:25 PM.. |
07-26-2012, 05:06 PM | #7 | |
126
Rep 3,099
07-26-2012, 05:25 PM | #8 |
European Editor
10539
Rep 22,992
One of our 1addicts 'Ring junkies Elsabor67 tried those rear bushing inserts. He liked them so much he is now installing M3 bushings!! ie: he did not care of the way the rear end still had some wiggle/mushiness with those inserts installed.
The M parts are the way to go guys. Don't even mess around with these other "improved" parts. There is a reason why M stuff works on and off the track. Dack
07-26-2012, 05:40 PM | #9 | |
126
Rep 3,099
i only linked full bushings what about the BMW racing group n stuff then? :P i believe one issue with stiffer bushings, is you need to run stiffer spring rates at the same time, or you'll still get varying levels of bounciness due to having effectively mismatched suspension settings |
07-27-2012, 08:59 AM | #10 | |
European Editor
10539
Rep 22,992
I would still stay away from solid bushings. I prefer the M stuff for the street. Dack
