07-20-2012, 11:32 AM | #1 |
Rep 50
Drives: White 135i
135i modifications!
What do you guys think about performance modifications. My boyfriend has an M3 and I want to be able to beat him! Right now I can spank him at 40mph or so because my turbos kick in, but off the line I am screwed.
Also, do you think the turbo needs a waste-gate (spelling?) Thanks!
2011 Alpine White 135i with the M package. DCT transmission.
07-20-2012, 12:32 PM | #3 |
456
Rep 6,478
Tune+FMIC+Downpipes should even the playing field quite nicely.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII |
07-20-2012, 12:36 PM | #4 |
81
Rep 1,051
If you are getting beat off the line or at low speed it probably has more to do with the limited slip differential that the M3 has and you don't, or it has better rear tires, and/or he is better controlling the launch and traction. Your engine actually has a very flat power curve and the turbos should be "kicking in" at very low RPM. Maybe you are not keeping the RPMs high enough?
Your car and all gasoline turbocharged engines already have wastegates. You can get a tune for more power. JB4 or Cobb AP or whatever. A better wheel/tire package may help, as well as a limited slip diff. Driver mod might help as well.
2009 BMW 135i 6MT Sport, AFE intake, Cobb AP, Apex 18x8.5+9.5, 255/275 PSS
07-20-2012, 12:46 PM | #5 |
34
Rep 770
IF you are having issues off the line you are probably getting some lag is all. traction control off, foot on brake, press gas until 3k RPMS, and when you take off press the gas pedal into the floor as you let off the brake (if you have an auto). Also, make sure its in sport / manual mode (DCT) and let the car shift. should be much better since you are putting load on those turbos and wont have as much, if any, lag. If yo uhave a 6speed than you and feather the clutch and do the same thing with the e-brake. A tune wouldnt hurt, too
07-20-2012, 12:46 PM | #6 | |
14
Rep 225
07-20-2012, 03:32 PM | #9 |
14
Rep 225
The PPK is a BMW performance softwear tune for the cars ECU. Gives around20 more hp than stock. Can be done at any BMW deealer and does not effect your warranty. There is also a version 2 whitch improves cooling, but most just get the softwear.
07-20-2012, 05:54 PM | #10 |
122
Rep 2,040
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
Yep, we are confused. A stock 135 is pretty fast off the line if used properly. But if you are beating the M3 from 40mph up then it doesn't sound like your car is stock or you are not talking about the newest generation M3. Also, what year, engine version is your 135?
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
07-20-2012, 08:39 PM | #13 |
Rep 50
Drives: White 135i
Thanks for all of your input. I admittedly am not the best driver, however, when jumping into my boyfriend's 2011 M3 from my 2011 135i with M package there is a noticeable difference off the line. That said, I do not know how to use the launch mode in my 135 and I'm not even sure if it has the same launch mode as the M3.
Right now I have Breyton 18" wheels (these were on the car when I bought it) and the car's suspension has been modified (dropped). I know that it has the performance exhaust, but otherwise I believe the car is stock. In terms of the tunes, what would you recommend? I'm a girl, so layman's terms please
07-20-2012, 09:19 PM | #14 |
89
Rep 3,732
Drives: BMW S1000XR
here is my mod list...Cobb A/P Stage II !
Forge FMIC Forge diverter valves HP Autowerks coupling (connects FMIC piping to charge pipe) ER charge pipe Injen DCI Cobb AP – Stage II AR catted DP Berk resonated mids Berk Axle back If you add an LSD there's no doubt. Also, search for Yuchi's Dyno. She ran over 400 whp
BMWCCA member |
07-20-2012, 10:26 PM | #15 |
500
Rep 569
pic of you with your car or it didn't happen
2020 M2 CS | Black Saphire Metallic | DCT / CCB
SOLD: 2012 135i | Le Mans | 6MT 1986 535i | Cirrus Blue Metallic | 5MT |
07-20-2012, 10:40 PM | #16 |
Rep 50
Drives: White 135i
That.Just.Happened.
07-20-2012, 11:36 PM | #17 |
89
Rep 3,732
Drives: BMW S1000XR
BMWCCA member |
07-21-2012, 12:27 AM | #18 |
500
Rep 569
07-21-2012, 02:10 AM | #20 | |
They like my Swag...
433
Rep 3,762
Drives: 15 GSM 435i GC
Don't mention it.
2015 435i Gran Coupe - Current 2008 AW 135i - Sold |
