BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
EXXEL Distributions
      06-27-2012, 10:47 AM   #1
docsdoc
docsdoc's Avatar
Drives: 2012 M3 Vert
OS Giken LSD
Has anyone replaced their OEM LSD with an OS Giken clutch type LSD? If so did you dyno?
2012 E93 M3, Akra Evo, ESS Tune, AA Green Filter, MoFo Coding, CF License Plate Frame
      06-27-2012, 10:49 AM   #2
kchu221
JDM whore
kchu221's Avatar
South Korea
188
Drives: 2009 997.1 Turbo
i believe ive seen one person do it, but i dont think he ever dyno'd after!
2013 Lamborghini Gallardo LP550-2
      06-27-2012, 10:53 AM   #3
docsdoc
docsdoc's Avatar
I'm curious about the torque curve with the OS Giken.
      06-27-2012, 10:56 AM   #4
tibra1
No_Country
127
Drives: 2011 ZCP M3 - 2007 335i crashd
OSG is top notch..had got one for my 335i but wrecked the car before installing..they do make one specific for e9x M3..
      06-27-2012, 10:56 AM   #5
THE TECH
BimmerPost Supporting Vendor
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
Not sure how a LSD would change anything in regards to torque or power.
      06-27-2012, 11:10 AM   #6
docsdoc
docsdoc's Avatar
I'm not sure either, but got this off their website: "The OS Giken Traction Control LSDs are much like other clutch type LSDs in that they offer the quick, positive response that some drivers prefer vs. a gear based or torque biasing differential..."
      06-27-2012, 11:13 AM   #7
THE TECH
THE TECH's Avatar
307
That just refers to the way the locking mechanism works in controlling the disks. Has nothing to do with power output on the vehicle.
      06-27-2012, 11:19 AM   #8
GIdriver
GIdriver's Avatar
68
Drives: 2014 E63 AMG-S
Apparently torque to the wheels can be improved. I admit that despite reading a bit about this, I do not completely understand it. Perhaps one of our experts can chime in. Straight from Dinan's site (Dinan's 3.45 differential for DCT M3's):
Dinan lowers the stock 3.15 final drive ratio to a 3.45, taking full advantage of torque multiplication for a substantial 9.5% increase in torque delivered to the road! The improved acceleration comes with only a minor increase in engine speed at cruise.
      06-27-2012, 11:21 AM   #9
THE TECH
THE TECH's Avatar
307
Yeah but they are changing gears. Changing an LSD has nothing to do with the gear ratio.
      06-27-2012, 11:25 AM   #10
zsapphire7
zsapphire7's Avatar
104
Drives: 08 e92 M3
Thats torque to the road in the same gear. The dyno would read the same because tq is calculated for the engine. All dynos will calculate it based on gear ratios. Else youll get different numbers depending on which gear you dyno at.
      06-27-2012, 11:27 AM   #11
docsdoc
docsdoc's Avatar
Agree - However, the OS Giken LSD is mechanically different than the OEM gear-based LSD. That's why I was wondering whether the torque curve would be different. I certainly wouldn't expect any increase in peak torque, but maybe a peak shift in the curve to lower RPMs...or not
      06-27-2012, 11:28 AM   #12
GIdriver
GIdriver's Avatar
68
Yeah, I just saw the OS Giken site and realize that now. My mistake.
      06-27-2012, 11:29 AM   #13
THE TECH
THE TECH's Avatar
307
Yes, it is different. But we are talking about the way in which the LSD locks up which has nothing to do with changing torque or power curves.
      06-27-2012, 11:55 AM   #14
tibra1
No_Country
127
The OSG offers 100% full lock up as opposed to gear type LSD (Quaife, Wavetrac)..honestly I think the M3 diff does as well..because it too is a clutch type differential.. but the theory is more torque to the wheels less on drivetrain loss.
Unless you are spending life on the track this is a very expensive upgrade..and most will be okay w the stock LSD
Correct..but most do go with more aggresive gearing in conjuction with LSD..
      06-27-2012, 11:56 AM   #15
tibra1
No_Country
127
The M3 stock LSD is NOT a gear type LSD..its a clutch type just like the OSG
      06-27-2012, 11:57 AM   #16
THE TECH
THE TECH's Avatar
307
But they are mutually exclusive and the OP is asking about the LSD. LSD does not change torque/power curves. If we wanna start talking about gears, then that's a completely different subject.
      06-27-2012, 11:59 AM   #17
tibra1
No_Country
127
Absoluetly right.
      06-27-2012, 11:59 AM   #18
docsdoc
docsdoc's Avatar
my bad
      06-27-2012, 12:02 PM   #19
tibra1
No_Country
127
my bad
Take it from me..stick with the stocker..its a great unit (if we had open diffs like on the 335i then yea)..doing LSD swaps is ever so tricky..we are talking about microns of tolerances..your installer has to be spot on..and the OSG make noises..you have to use OSG's gear oil..which is a very heavy weight oil... 80W-250
      06-27-2012, 12:04 PM   #20
THE TECH
THE TECH's Avatar
307
Agreed 100%. Complete waste of money otherwise.
      06-27-2012, 12:07 PM   #21
docsdoc
docsdoc's Avatar
It was more out of curiosity - I'm actually considering a swap to the Dinan 3.45 unit, but I came across the OSG while researching...
      06-27-2012, 01:29 PM   #22
Mbauer
21
Drives: E92 187outx3
The only way the diff would make the car more powerful is if the differential offered less friction in its rotational assembly. Basically how much applied force does it take to turn the gears. The engine would still be the same but the drivetrain loss percentage would be less, so you would get more power to the ground.
The Dinan diff would be ok for a NA car, but would probly be too short for a supercharged car. Your also gonna be cruising a few 100 more RPMs on the freeway also. If its worth it is up to your own application and use.
m3post
