06-26-2012, 08:55 AM | #1 |
bimmerphile, technogeek
998
Rep 3,785
Drives: 2012 E82 6MT Sport
Stainless steel valve caps and TPMS
I wanted to replace the cheapie plastic valve stem covers on my wheels with the classic BMW OEM stainless steel valve caps, but I came upon this comment while searching:
"Wheel Valve Stem Cap Stainless Steel (4 Per Car) NOTE: Not for cars with Tire Pressure Monitoring System (TPMS)." Any possible reason why?
06-26-2012, 10:27 AM | #2 |
35
Rep 609
I've had them on my Z4 and transferred them to my 135 when I traded with no problems whatsoever.
NB8S Past Garage: Z4, 135i. Present Garage: 2013 X Drive X1 2.8i.
06-26-2012, 11:39 AM | #3 |
998
Rep 3,785
Maybe I need to submit this question to BMWNA.
06-26-2012, 11:56 AM | #5 |
998
Rep 3,785
06-26-2012, 12:03 PM | #6 |
31
Rep 388
The ones you refer to should not be used with the TPMS. The metal caps can cause the TPMS to malfunction. I bought the fancy Roundel caps for my 2012 135i and they could be used since they are plastic. They look the same as the steel Roundel caps I had on my 2000 323Ci. They also cost the same.
06-26-2012, 12:08 PM | #7 | |
998
Rep 3,785
Being a techogeek, now I'm curious how the TPMS works... Got any technical information on how it works?
06-26-2012, 12:22 PM | #8 |
31
Rep 388
Sorry I do not know how they work or why metal caps affect the TPMS but I was told this by several people who should know. BMW must have responded to people's desire for nicer caps by making the Roundel and M caps plastic.
06-26-2012, 12:25 PM | #9 |
998
Rep 3,785
Ah, that's OK... I'll try Googling the subject... Thanks for the info.
06-26-2012, 12:30 PM | #10 |
↓↓↓ Ex-Con ↓↓↓
34
Rep 1,874
I have had those run of the mill stainless steel caps on my 1er with TPMS for almost 4 years now. Never had a single problem so I am not sure what they could possibly do to damage the unit?
06-26-2012, 12:45 PM | #11 | |
1025
Rep 1,968
I had these on previous non-TPMS BMWs. Loved them so I put them on my non-BMW family car with TPMS (and aluminum valve stems) and learned an expensive lesson. I've stuck with the plastic ones on my 135i. |
06-26-2012, 12:45 PM | #12 | |
998
Rep 3,785
One thing I did read was that the valve stems are aluminum(?) and could chemically react (galvanic corrosion) with the steel valve caps, seizing the caps to the stems...
06-26-2012, 12:51 PM | #13 | |
998
Rep 3,785
Odd that the manufacturer of those TPMS sensors (Beru?) would use aluminum instead of the more typical brass.
06-26-2012, 12:58 PM | #14 |
1025
Rep 1,968
Should be "stuck" (no pun intended)....
Also, @Qunadry, I've never heard of TPMS malfunction, only corrosion, leading to replacement of the more expensive TPMS valve stem. The TPMS continues to function but you can't put air in the tire when cap is fused to the vale stem. |
06-26-2012, 01:47 PM | #15 |
89
Rep 3,732
Drives: BMW S1000XR
Ummm...the presence of an electrolyte and a electronic conducting path between the metals is essential for galvanic corrosion to occur. Thus, I believe it is basic corrosion. In addition, I believe the strange looking caps (w/the TPMS) indicate to any individual that a TPMS is present. Mine were stolen, go figure (?), so I have been using aluminum BMW logo caps.
OP...if it is 304 SS it will not corrode, but I guarantee it is not. I forgot to add; it is possible that a pool of water and salt can become trapped under the cap during the Winter if you are not careful. Then, you could have galvanic corrosion.
BMWCCA member Last edited by ken1137; 06-26-2012 at 02:11 PM.. Reason: adding |
06-26-2012, 02:10 PM | #16 | ||
998
Rep 3,785
06-26-2012, 02:13 PM | #17 | |
89
Rep 3,732
Drives: BMW S1000XR
BMWCCA member |
06-26-2012, 02:16 PM | #18 |
998
Rep 3,785
06-26-2012, 04:09 PM | #19 | |
890
Rep 7,047
From the receiver there is a hard wire connection that feeds that data to the ECU. I found this out because that wire broke in my 135i. The valve stem is part of the TPMS transmitter and may act like an "antenna", and if you use metal caps it may interfere with it's transmission. But, as one poster has stated, his work fine. So, there may be a potential for a problem, but it may work too. Since you have them put them on and see what happens. You can always take them off. Try installing 1 or 2 at a time and drive a bit to see if it affects anything. BTW, if you're sure that your metal caps are stainless, then corrosion shouldn't be a big issue. But, there is still a potential for the metal to somehow interfere with the TPMS transmission, IF that is the potential problem being warned about. Last edited by RPM90; 06-26-2012 at 04:25 PM.. |
06-26-2012, 04:21 PM | #20 | |
890
Rep 7,047
I had this happen in one of my cars years and years ago. The wheels had the traditional brass stems, and I installed a set of aluminum anodized blue caps. Looked very nice on the blue car...kinda ricey. Anyway, drove through the winter with water, salt, slush, and all manner of corrosive material picked up on the road. In spring I went to check pressure and only 2 caps came off. Those had serious corrosion building between the aluminum and brass. The other 2 caps were LOCKED together as if fused by an arc welder. Tried and tried to twist with hands, pliers, different pliers, different hands....NADA! Dremel tool to the rescue. I had to cut them in half to get them off, and did damage a bit of the valve thread. I cleaned them as well as I could and put rubber/vinyl caps on. Stainless caps should work well I would think. I think I've seen a BMW set in stainless. They are semi shiny, but have a cool color that is not like polished steel or chrome. They have a softer sheen. BTW, I've got a cool looking set of metal caps with the BMW roundel on the ends. They are made by BMW, and I don't think they are stainless, too bright and shiny. I had them on my E46 325i. I kept them before returning it for lease end. I took them off cause it felt like they affected the balance of the wheels/tires as I developed a very slight vibration at 55mph up. It was very slight, but I CAN NOT stand steering wheel vibe. They feel quite heavy in hand, and I mean just holding one of them, you can feel the weight. If I ever install them on my 335i Msport, I'll only do it when I can get the wheel/tire set balanced with the caps on. |
06-26-2012, 07:16 PM | #21 | ||||
998
Rep 3,785
LOL, after browsing through eBay, some folks want $20 for a set of four of those plastic "TPMS safe" valve caps... Get real.
06-27-2012, 07:39 AM | #22 |
14
Rep 102
Yes it is true. You should NOT use metal caps on TPMS systems. Corrosion WILL occur between the valve stem and the metal cap! Had it happen to my G-35 Coupe. Had to have the unit replaced.
You must use plastic caps |
