04-29-2012, 12:47 PM | #1 |
127
Rep 315
When filling gas, pump stops before full
As title; When I'm pumping gas the pump will stop before its full I have to then pull the pump out a bit and continue. Do these cars typically have problems with EVAP? Or is the fill tube just too narrow?
04-29-2012, 01:45 PM | #3 |
231
Rep 913
I get very little in trying to top off. If you are using the same place to fuel it may be that they have a little zippier pumps than average, you run into them here or there.
04-29-2012, 03:49 PM | #4 |
13
Rep 682
Always happens to me. I rotate the handle a bit and it usually will restart and continue. It bugs me. Never had this issue on any other cars.
Note: only happens to me at chevron....damn!
04-29-2012, 04:44 PM | #7 |
15
Rep 214
This happens to me all the time. Annoys the crap out of me.
2012 BMW M3 Coupe JZB/Fox Red DCT ZCP. Vorsteiner Double Sided Carbon Fiber CSL Boot Lid. Paint Match Grills, Side markers, Reflectors. Carbon Fiber Splitters. Lux Angel Eyes. Custom Rear Section Exhaust with valves. Next mod: Valentine 1
04-29-2012, 04:49 PM | #9 |
Apex Everything!
976
Rep 4,378
Drives: 2007 Honda S2000, 2017 GT350
Only happens for me at Chevron stations with my E90's. Never had this issue with my E82 or E92. I think the pump isn't detecting a good seal so it stops.
2011 E92 M3(Sold). 2007 Honda S2000 (Track Car). 2016 Cayman GT4 (Sold). 2017 Shelby GT350 (AKA Crowd Killer).
My pet project: https://stickershift.com |
04-29-2012, 11:55 PM | #12 |
84
Rep 2,792
Happens to me too. I rotate the handle.
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R |
04-30-2012, 09:56 AM | #13 |
18
Rep 150
Agree. Not unique to Chevron as stated in other parts of this thread. I've had the same issue with Shell and Exon. There is another thread out there with this issue dissected. Something about a pressure buildup. Rotating the nozzle seems to fix the problem, albeit, it may take a couple of tries.
04-30-2012, 10:01 AM | #14 |
21121
Rep 20,741
Drives: 2021 911 turbo
Happens to me too once in a while. It seems to happen when I get a "fast" pump. Pulling the nozzle out a bit usually fixes the problem.
04-30-2012, 07:43 PM | #15 |
1577
Rep 8,076
Drives: 11 E90 M3 Individual
Never had an issue but I always trust that its full on the first stoppage. My E46 and E90 ALWAYS overflows if I try to top it off.
That's what she said.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
05-29-2012, 12:31 AM | #16 | |
14
Rep 46
05-30-2012, 01:23 AM | #17 |
187
Rep 714
sometimes if i tilt the nozzle too much it will stop...so i hafta fill propping the nozzle sort of upwards so the gas is flowing down.
just gotta fiddle with it at times |
05-30-2012, 03:02 AM | #19 |
64
Rep 1,498
This happened to me on my e92 and on my cayman. I had to rotate the nozzle so it will fill up entirely or pull back the suction cup at the head of the nozzle. It is not because the EVAP of the car; it is because of the HEALY system installed on the gas pumps. Either rotate the nozzle or pull back the suction cup on the nozzle. This will occur at stations with new pumps: chevron, 76, wherever. HEALY systems recover the gasoline vapors which build up in pressure as you pump.
E92 328i Jet Black / Gloss Black Grilles / 8000k D1S low beam / 6000k HID fogs / GP Thunder 8500k angels & cornering bulbs / black reflectors / gloss black vinyled window trim / tints / smoked rear turn signals / black roundels / AC Schnitzer roof spoiler / VRS style decklid spoiler / Matte black Stripes / Rear fogs / matte mirrors / 19" LM reps / APR lip |
06-01-2012, 11:42 PM | #20 |
15
Rep 200
so i figured it out finally on my car...when i put the hose in a little cocked to the side so the black boot on the hose doesn't form a good seal around my inlet (allowing air gap), it works just fine and fills up properly.
06-28-2012, 07:05 AM | #21 |
Rep 1
Same problem
Had the same issue with a 3 week old 2013 m3 conv. Also had an icreased emmissions warning. Car has now been back at the dealer for a week with a new valve being replaced that was supposed to be shunting the gas fumes through the exhaust but instead out of the tank. Now replacing the dmtl valve. Pretty good start for 3 weeks in, don't you think? And this replaced a 2011 550i that had so many problems they let me out early....
