04-05-2012, 10:13 AM | #1 |
324
Rep 247
FS: E46 M3 racecar
Front-running E46 M3 racecar available. Dead-nuts reliable, zero mechanical DNFs in 3 seasons. The best of everything. $48K or will take an E92 M3 in partial trade, located in Richmond, Virginia. Email me at maxxfish at gmail dot com for more info and pics. E46 M3 #123 Build Sheet Chassis: 2002 BMW M3 with 31,000 miles on chassis and drivetrain. Frame is straight, rear subframe is reinforced. 2680 pounds wet. Drivetrain: S54 engine with 31,000 miles, valves adjusted within 1500 miles, oil changed every other race Dinan S54 Performance cams Dinan Cold Air intake and Mass Air Meter assembly Fall Line Underdrive pulley kit Vallo Alternator underdrive pulley Supersprint headers Fall Line custom 3” exhaust with Sportsman muffler Bimmerworld Oil restrictor C&R all-aluminum radiator with Spal electric fan Fall Line T2 Oil cooler kit Fall Line power steering cooler kit with braded ltainless lines and AN fittings Epic Motorsports custom tune, makes 343 wheel HP, 257 wheel torque. Car currently has a 20HP detune installed to meet class restrictions (easily removed by a remote reflash via the internet). Bimmerworld solid aluminum engine and transmission mounts BMW 4.10 race limited slip differential Clutchmasters Stage-7 lightweight flywheel and race clutch Clutch Delay valve deleted Bimmerworld fuel starvation kit 6-speed manual transmission with Jaffster race shift knob. 3rd-gear synchro is a little crunchy on downshifts, but it doesn’t cause any issues and has been like this for 2 years. A spare 6-speed transmission is also included with good syncros (just needs bellhousing swapped) Suspension: Moton Clubsport remote reservoir shocks with rear coilovers with Eibach ERS 900/450 springs Bimmerworld E46 Race front control arms (only two race weekends on these) http://store.bimmerworld.com/e36-wid...arms-p995.aspx Ground Control Race roll-center-correcting tie rods (only two race weekends on these) Moton front camber plates Monoball adjustable rear control arm kit Turner Motorsports Sway bar set 30mm ront, 25mm rear Ground Control Rear Trailing arm (RTAB) bearings (solid/spherical) Ground Control Front Control arm (FCAB) bearings (solid/spherical) Brakes: Brembo F50 Front 14” brake kit Brembo Lotus Rear brake kit Stainless lines Willwood Race brake fluid Carbotech XP-20 pads ABS and traction control still in car (TC can be turned off from the cockpit) Wheels: 4- Enkei NT-03 18x10 wheels with Hoosier 265/645/18 slicks 4- Enkei WDM 18x8.5 wheels with Hoosier H2O wets TC-Kline bullet nose race wheel studs Exterior/Body: MA Shaw fiberglass doors MA Shaw fiberglass trunklid Bimmerworld Race wing and standoffs Alumalite front splitter with adjustable aluminum supports Mirror delete (race mirrors inside car) Lexan side and rear windows Custom Vinyl graphics Interior/safety Custom rollcage built to the hightest safety and stiffness specs, fully gusseted and tied into the rear subframe Racetech Head restraint seat (FIA certified) on VAC Motorsport brackets Shroth 6-point HANS-compatible harness (FIA certified) Momo suede steering wheel with quick-release hub Pyrotect window net and right-side net SPA mechanical 4-liter AFFF Fire system Odyssey Lightweight battery Longacre Full View Convex mirror Wiring harness thinned out for weight 40 pound ballast plates (easily removable) All sound deadening removed and interior/cage painted in POR-15 Extensive spares package: VANOS O2 sensors Coil packs (6) 6-speed transmission Brake Rotors (used but with plenty of life left) Brake pads Coilover springs of different weights More… Detailed pics at http://s116.photobucket.com/albums/o...fish/E46M3123/ Last edited by maxxfish; 04-06-2012 at 08:38 PM.. |
04-05-2012, 11:10 AM | #3 |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
Nice car. GLWS.
04-05-2012, 12:07 PM | #4 |
1 Stock M
76
Rep 1,650
Drives: Something Slow
GLWS
Veteran USMC/Iraqi Freedom
Current: E46 M3 Retired: 2009 E90 AW M3 Retired: 2007 E90 AW 335i. |
04-05-2012, 12:12 PM | #5 |
11817
Rep 23,187
damn looks hot.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
04-07-2012, 10:34 AM | #8 |
530
Rep 6,149
Looks like a lot of care was put in to this car. GLWS!
If you will be purchasing ANY AT&T services online or in store could you mention that you were referred by me? My Employee Referral ID is eo4489. This would be a great help and it costs you nothing, thank you!
05-26-2012, 04:48 PM | #10 |
11817
Rep 23,187
Is the new e92 for a DD, or another track project car?
05-26-2012, 08:18 PM | #12 |
11817
Rep 23,187
Nice. I wanna see the build progress. Love your e46.
