03-31-2012, 11:09 PM | #1 |
Rep 1
Lowering Suspension Help!!
I know lowering thread keeps popping up, but wondering if anyone out there could shed some light. I am looking at lowering my 2008 528i. It has the factory suspension (non sport pack) and I am looking for a 1/2" - 1" drop or around 15mm - 25mm
I saw Dinan has a stage one listed for an e60 535i which seem to the characteristics that I wanted. When I contacted my local BMW/Dinan dealer, they said Dinan had no set up for my vehicle! Could they be correct? When looking at so many suspension kits on line, from KW, Bilstein to H&R, all their part numbers on their kits seem to accommodate all E60 models (excluding Xdrive or Dynamic drive). And help, guidance, advice? |
04-10-2012, 09:43 AM | #2 |
51
Rep 591
First are you looking for a coil over setup or just the coils.second you can get the h&r which will probably be the cheapest also depends on if your car is a dd in which case you might want to go with the kw's.the coil over will give you the advantage of choosing the Hight the your car.personally I don't like dinnan. that's your choice.
