      03-30-2012, 04:16 PM   #1
BiscottiGelato
BiscottiGelato's Avatar
88
Drives: 09 135i M Sport 6MT
Tracking All Stock
Tracking all stock aside from slight negative camber. Low of 39, High of 45. Forecast calling for light rain all day. Any recommendation on starting pressure? Ideally going to start on the high side and adjust down by chalk.
In terms of how hard I'd drive it, I don't know. My 4th track day and going to be my first wet one. Keeping things all stock until I use up the stock tires and stock pads/rotors.
Thanks!
      03-30-2012, 05:50 PM   #2
pixelblue
pixelblue's Avatar
140
Drives: the silver bullet
2010 135i  [8.90]
my track day tomorrow is pretty much the same as yours except 10 deg warmer. what's your tires? you definitely need to start higher. you won't be able to put as much heat into them. where is GVA?
"I would quote everything pixelblue said, but you've already read it. Take it from someone who's put the 1 through its paces"
      04-02-2012, 07:39 PM   #3
BiscottiGelato
88
GVA is Greater Vancouver Area. Ended up needing 47psi+ before the front tires is not rolling over the sidewall too much. That pressure sounds abit high even especially in wet weather.... I guess I need more neg camber?
1addicts
