03-11-2012, 06:31 PM | #1 |
Rep 64
Review of APEX ARC 8 with Hoosiers
I was at Infineon yesterday with my new track wheels and tires. This is my second set of APEX wheels and this time I went with a staggerd set 18x8.5 in the front and 18x9.5 in the back. Tires are 245 in the front and 255 in the back. These tires run big. I used a 5 mm spacer in the front and 2 degrees of camber. The tires fill the wheel wells. I had no rubbing at all. The tires were easy to get a feel for. They were a little loose until they got warm. I found after the tires got warm they were easy to correct when they did come loose. This is a great setup if you have all the suspension parts to handle the extra grip. The guys at APEX were great to work with and I also had them mount and balance.
03-11-2012, 11:16 PM | #3 | |
Rep 64
With the stock suspension and camber plates there is so much roll that it will even be more with the r-comp. That is why the r-comp has been one of the last things for me. Are others running stock suspensions with r-comp? |
03-12-2012, 09:24 AM | #5 |
476
Rep 1,711
R-comp. tires with stock susp.(even with c.plates) is not a good idea.
OP, Do your gr. control camber plates make noise when driving over uneven road? I vave worshlag plates and they are noisy. |
03-12-2012, 10:55 PM | #6 |
Rep 64
Groundpilot I have not had any noise from the camberplates. The end links on the front sway bars need some spray lube from time to time but that is it.
03-13-2012, 06:44 AM | #7 |
340
Rep 1,293
Buzz, this is great info. Can you let us know how much you have dropped the car? And confirm you are only running neg.2 camber up front? I was under the impression you had to run neg.3 to get 245s to clear the fender. Thanks.
03-13-2012, 05:54 PM | #8 |
99
Rep 1,050
Hey Buzz,
This is Jan from Apex. It was great to meet you at Sears Point. I love your 135 and all your mods were so clean and make so much sense. As an N54 guy I've been through it all so seeing a car as beautifully modified as yours was a pleasure. I hope to see you at more track days. Cheers, Jan |
03-13-2012, 11:02 PM | #9 |
Rep 64
Pig Farmer, I will have to check it but it sets low. The Camber is close to neg 2 but could be some more but no more than neg 2.5. I did contact the guys at APEX and I told them what I had and they told me what would work.
03-13-2012, 11:18 PM | #10 | |
Rep 64
03-14-2012, 12:02 AM | #11 |
99
Rep 1,050
We will be at Thunderhill for both days. We're driving our Apex "Street to Track" project E36 M3 for the first time there.
I'd love to drive your car at Thunderhill. Oh my. I see some very low lap times with that beauty. Let's make sure to connect. |
03-18-2012, 08:25 AM | #12 | |
247
Rep 1,585
Drives: 2011 VO 1M
Garage List 2010 Porsche 911 GT3 [10.00]
2021 BMW X5 SD40i [0.00] 2023 Toyota TRD Pro [0.00] 2011 BMW 1M [9.83] 2014 Ford Raptor [0.00] 2005 Ariel Atom 2 [0.00] 2008 135i SOLD [10.00] |
///1M #643 of #740
03-18-2012, 09:13 AM | #13 |
Rep 64
03-20-2012, 12:08 PM | #15 | |
476
Rep 1,711
I have 12 track days on my R1s and i can easily go for 4 more i think. How about Hoosiers? They dont last nearly as long because of softer compound? |
03-20-2012, 12:20 PM | #16 | |
45
Rep 345
Drives: Many BMW's & Porsche's
As far as 'wear' goes, it depends on what type of driving you are doing. For a race weekend we usually use one set for the entire race weekend. This involves: 3 races, 3 qualifying sessions, and a couple of practice sessions. If you are just doing DE's I would say you can use them as long as the tread is still there(no cords showing).....that is about 3-4 track weekends per set. Overall, it depends on; what you will be using the tires for, how 'hard' you will be on the tires, and if you are able to run a square set-up and flip the tires as needed. Hope that helps. |
03-20-2012, 01:04 PM | #17 |
140
Rep 2,234
so are BFG R1s
"I would quote everything pixelblue said, but you've already read it. Take it from someone who's put the 1 through its paces"
03-20-2012, 01:17 PM | #18 |
45
Rep 345
03-20-2012, 02:06 PM | #19 |
476
Rep 1,711
[QUOTE=TC Kline Racing;
If you are just doing DE's I would say you can use them as long as the tread is still there(no cords showing)..... I would say no, you cant use them as long as the tread is still there. Not even for HPDE. R-comp. tires wear by heat cycles. It doesnt matter how much rubber may be left. Depending on tire compound, after 8-12 heat cycles they get harder and will not grip as before. Softer the compound, sooner they heat cycle and as a result of that grip is not the same. |
03-20-2012, 02:12 PM | #20 |
105
Rep 2,696
If they wear by heat cycles then assuming you're doing a DE that has 4 sessions a day you wear out the tires after 2-3 days....seems a bit excessive no? Or am I defining my heat cycle in correctly?
Faster, faster, faster, until the thrill of speed overcomes the fear of death… – Hunter Thompson
03-20-2012, 02:16 PM | #21 | |
45
Rep 345
[QUOTE=Groundpilot;11584581]
03-20-2012, 02:44 PM | #22 | |
476
Rep 1,711
As far as i know Hoosiers cycle out very quickly, which is a main reason you dont see them at DEs. |
