      03-09-2012, 01:01 PM   #1
Alexey
31
Drives: M340
1M from Moscow
My 1M FBO:
- full catless Supersprint incl. DP
- Forge IC
- Forge Recirculation Valves
- KN filter
- Cartuning flash
We must break in a program to remove the logs. Later I will make dyno.
      03-09-2012, 01:55 PM   #2
LotusBoy
Drives: BSM 1M, N55, KW's DDC
Hello Alexey, dobredyin ! Nice Baby-M, and superb sound from the Supersprint exhaust. Together with the intercooler and the ECU, you must have good numbers... I hope you've got good winter tires, too. ;-)
      03-09-2012, 02:04 PM   #3
Alexey
31
Drives: M340
Thanks. In winter tires, I could not ride, took off after two days of use. I leave when the dry, in the summer tires no problem. PS2 the best
      04-21-2012, 04:56 AM   #4
Alexey
31
Drives: M340
del
      04-21-2012, 04:59 AM   #5
Alexey
31
Drives: M340
dyno 430 Hp / 613 Nm
      04-21-2012, 05:16 AM   #6
LotusBoy
Real nice numbers, I would call it a stage 2+ ...
      04-21-2012, 06:23 AM   #7
RimasRS
RimasRS's Avatar
85
Drives: BMW X3 SD
That's freaking expensive exhaust
      04-21-2012, 03:22 PM   #8
///M1
///M1's Avatar
275
Drives: Many
These are reverse engineered to read at the crank I assume, or are they WHP?
Looking at your dyno video, I have to say I've not seen a car strapped so close to the front of the roller (the front tires almost looked like they were about to touch the concrete), usually the car needs to be on the very top of the drums. I have actually experimented (an my AWD car) moving the drums and running different pulls, observed some difference depending on where the tires were relative to the drum. May be less of a factor on a RWD car.
Also, the operator seemed to be hitting the rev limiter for a bit before he let go, especially if you had it raised as part of the tune, I personally wouldn't be quite happy about that.
2011 BMW E82 1///M: AW, all options; Renntech, Akrapovic, Forge, P3, RevoZ CF bits, many mods
1988 BMW E30 M3: Hennarot, S14, stock
2018 Porsche 991.2 GT3: PtS, CXX, LWBS, PCCB
1998 Porsche 993 C4S: Zenith Blue, last aircooled widebody, Bilstein PSS10, Fister II + Fabspeed exhaust
2008 Audi B7 RS 4: Sprint Blue, Audi Exclusive Euro Bucket Interior, Premium+Titanium, many mods
      04-22-2012, 02:10 AM   #9
Alexey
31
Drives: M340
I am no expert in this. I can only say that on the same bench result stock was 337hp.
      04-22-2012, 07:22 AM   #10
LotusBoy
Numbers given should be understood as 'engine power' or 'crank numbers'. Like in most case, power is initially measured at the wheels and then during deceleration drivetrain loss is measured. The given crank power is simply the addition of WHP + drive loss ...
      03-02-2013, 11:49 AM   #11
Alexey
31
Drives: M340
Clutch with single flywheel
      03-02-2013, 11:49 AM   #12
Alexey
31
Drives: M340
Shifter
      03-15-2013, 04:48 PM   #13
Gonchi_ACS1
Drives: BMW ACS1
1addicts
