03-09-2012, 02:43 AM | #1 |
19
Rep 74
Arkym Trunk white paint turned yellow!
hi im using gintani Xpipe + akrapovic exhaust, in less than 2 months the rear end of my Arkym trunk turned yellow, obvious i did the paint job in aftermarket paint shop, people told me this can not be prevented for a white car.
anyone know how i can prevent this from happening again? |
03-09-2012, 05:19 AM | #3 |
37
Rep 517
i doubt if wax can turn it white
335i Cabriolet Jet Black/Coral Red - Retired but will never be forgotten
M3 Coupé DCT Competition Package Mineral White/Fox Red E9X Picture Game: 2 points (Slow sign, Leaves) |
03-09-2012, 05:26 AM | #4 |
273
Rep 5,751
03-09-2012, 08:05 AM | #5 | |
Digger
209
Rep 2,619
Waxing your car does not remove any clear coat whatsoever......
2009 E92 M3 /// Melbourne Red /// Fox Red /// M DKG
Full Innotech Exhaust - DINAN Intake - IND Engine Bay Appearance - IND Hand Stitched Boot Covers - and much more.... |
03-09-2012, 08:19 AM | #6 |
4th down; 4th quarter? Renegade.
87
Rep 3,850
What on earth are you talking about man? If you wax a car with a non-abrasive applicator pad, it absolutely does not remove any clearcoat.
03-09-2012, 08:21 AM | #7 | |
87
Rep 3,850
03-09-2012, 08:27 AM | #8 | |
BimmerPost Supporting Vendor
307
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
The issue with the paint could either be with the base color or the clear. If it did turn yellow then your shop should warranty it and repaint for you for free. Also, waxing too soon after painting could cause gases to be trapped in the paint which could give you ill effects. |
03-09-2012, 08:43 AM | #9 | |
268
Rep 1,883
Drives: 2011 E92 M3
OP, post up some pics, let us see the issue. It might just be the clearcoat. If it is, you might be able to cut it away. Need to have a paint thickness reading done too though, most people wouldn't want to cut the area if it was too thin and wasn't done right.
'11 BMW E92 ///M3 - ZCP and DCT
'15 Ford F-250 - Lariat, 6.7 Powerstroke Turbo-diesel |
03-09-2012, 08:56 AM | #10 |
***Major MammelToe
159
Rep 1,139
Any photos? I would like to see what you are talking about.
E92 M3 SG DCT - AA Filter, Verstraβe Paddles, ECS SS, MH race stud, Stoptech BBK, MR Exhaust,RE Pulley, BPM Tune,Euro bumper and GTS lip, Euro MDM & DCT, KW CS, Recaro PP, TMS Soild Diff Mounts, MRF solid subframe mounts, GTS aero, RPM track built motor.
03-09-2012, 10:38 AM | #12 |
Z
43
Rep 632
Drives: E92 AW M3
+1 AW的车特别容易发黄,特别需要保养
Challenge V-weave Front Lip & Mirror Caps | WSTO painted AW front grill & Mag Blue side grill & Mag Blue Tow Hook & Mag Blue mirror inner ring | Te-37 Mag Blue wrapped with R-S3 | Kreissieg F1 exhaust & X-pipe | KW V3 | Vortex EVO X GT-wing | Tinted LCI taillight | Nadi steering wheel & IND shift extension |
03-09-2012, 11:11 AM | #13 |
Putcha ang ganda...
281
Rep 5,441
ok im a little confused..
his trunk is turning yellow? due to exhaust? i mean yea this usually happens when you have a no cat xpipe due to carbon and usually only in the rear bumper but when your stuck in traffic with no cat the smoke carbon will go up to your trunk causing it to turn yellow to avoid wash the car once a week.. yes it will turn your bumper yellow then black if you dont do anything. yes it will turn yellow if not maintained properly.... a little wax usually do the trick at lease once every 3-5 months. |
03-09-2012, 11:31 AM | #14 | |
87
Rep 3,850
03-09-2012, 12:19 PM | #16 |
307
Rep 13,093
The carbon would just make it dirty, not make it yellow. Only excessive heat due to proximity of the exhaust could cause it to yellow as you would describe it and the exhaust isn't anywhere close enough to do that. The bumper would yellow first if that were the case.
03-09-2012, 12:29 PM | #17 | |
Putcha ang ganda...
281
Rep 5,441
Yea i was thinking about the heat issue but what got me buffled is that he mentioned the exhaust... yea like you said the bumper would be the first to yellow... i say OP post some pics.. we will find out... |
03-09-2012, 12:51 PM | #18 | |
Digger
209
Rep 2,619
I'm confused as well, yellowing paint and now waxing removes clear coat. The OP is not the only member on here with a catless exhaust on a AW car and no one else had reported a yellowing trunk that I recall. I suspect that THE TECH is correct and its something to do more along the lines of the shop that painted it. Regular protectant wax will not clean anything, you'd have to get a mildly abbrasive cleaner wax or polish it. I use megs cleaner wax on the belly of the plane to keep it clean when I degrease it and even that doesn't get it all out. I have to polish it twice a year to keep it like new.
03-09-2012, 12:55 PM | #19 |
Digger
209
Rep 2,619
+1 to the pictures
03-09-2012, 01:40 PM | #20 | |
84
Rep 2,792
Also, I have seen some yellowing of a stock rear bumper actually. A member on here asked me to remove his rear diffuser and the paint had yellowed pretty significantly due to a lack of cleaning and waxing in that area. It was yellow far enough away from the exhaust that it couldn't have been caused solely by heat. The likely reason that you don't see this often is that most people are religious about cleaning and protecting their paint. The paint on this trunk was probably not fully cured and unprotected. The paint will become much more chemical resistant once it is fully cured. |
03-09-2012, 01:44 PM | #21 | |
307
Rep 13,093
03-09-2012, 01:58 PM | #22 | |
84
Rep 2,792
I have experienced this first hand. I've been learning to paint my own parts and I recently put on a diffuser that had cured for only a week, indoors with no heat/sunlight to speed the curing process. After driving in the rain and one car wash (hard water), the finish was horribly etched. I didn't want to wax too soon so the painted was unprotected. I repaired the clear coat (wet sanded and re-cleared) and let it cure for a month, waxed it, and the problem has not reemerged. As far as the curing time, this is an extreme case though because I'm a noob so the paint was thick. That extended the curing time. I'm not suggesting that a month of curing time is the norm. |
