      02-29-2012, 08:06 AM   #1
Aetey
Aetey's Avatar
Luxembourg
Drives: M Coupe
Steelflex brake lines
Since my 1M will be tracked I'm flirting with steelflex brake lines. Has anyone here ever installed some? If so which ones did you get, did you install them yourself? Might I ask for pictures?
I was thinking along these lines: http://o-brake.com/en_montagematerial_stahlflex.php
Anyone? Anyone? Bueller?
      02-29-2012, 09:32 AM   #2
Pete_vB
Pete_vB's Avatar
118
Drives: '69 GT3, GT4, 1M, 912
I would generally tell you to save your money. Modern stock brake lines are fiber and steel reinforced inside the rubber, meaning that when new they don't expand under pressure like rubber lines once did, so there is only a very small performance advantage to steel braided lines. Modern street based race cars, like the Porsche GT3 Cup cars, often use rubber lines and the teams don't bother upgrading to stainless, which should tell you something.
That being said, stainless lines do protect against abrasion more than rubber lines. In a race car where you're pulling the wheels off regularly there is a good chance you'll eventually abrade the outside of your stock rubber lines. I'd suggest you wait until that happens and then consider replacing with stainless. They generally recommend replacing stainless lines every 2 years, because the braided cover hides and damage that might be hiding underneath.
1M, GT4, 1969 Porsche 911 w/ 997 GT3 Cup Motor (435hp & 2,100 lbs)
      02-29-2012, 11:28 AM   #3
Aetey
Aetey's Avatar
Luxembourg
Drives: M Coupe
I didn't know that Pete, thank you
1addicts
