01-31-2012, 10:13 AM | #1 |
21
Rep 844
Rear O2 and EGT help
Hey guys
I recently had the EURO headers installed and had my O2's relocated My mechanic put the EGT sensor up further towards the headers than on the stock secondary cat section however it is still on the pipe before the headers. Does it need to be moved back? I am currently throwing some codes 2C7F 2C6C 2C7B 2C6A 2C93 Any idea what might be causing these? Two of the codes are O2 swapped in the wrong place however we took the section off and switched them and it is still throwing them. Any help would be much appreciated. Last edited by avsbmw; 01-31-2012 at 02:52 PM.. |
01-31-2012, 05:42 PM | #2 |
60
Rep 1,097
the rear o2s should be behind the cats almost to the flange. The egt should be just about on the bend of the s pipe where it is larger than the normal pipe diameter. This is based on my euro cat section waiting for install hardware in my garage.
01-31-2012, 06:18 PM | #3 |
56
Rep 1,739
Drives: 2008 Z4MC
If u follow Euro spec:
OR THREAD--> http://www.zpost.com/forums/showthread.php?t=614987 The guy moved his EGT into his headers with a substantial HP increase. However AFAIK he's the only one to have done this with any success. Could be wrong |
02-01-2012, 12:26 PM | #4 |
21
Rep 844
Is there a reason the EGT is so far back towards the cats? Why would it not work further up on the section?
Does everyone who moves the EGT back extend the wires so it will reach? |
02-03-2012, 10:55 AM | #6 |
25
Rep 296
Why are we so worried about the rear o2 sensors? I understand it will throw codes but won't ess or someone just delete them from the ecu? The primary sensors adjust and monitor air fuel for maximum performance what are we doing with the secondary? balancing performance with maximum cat efficiancy?
02-03-2012, 01:38 PM | #7 |
21
Rep 844
yes i just don't like seeing the codes but not worried about performance from the rear O2s. However through a EGT plausibility code and trying to figure that out.
02-04-2012, 06:28 AM | #9 | |
442
Rep 2,747
This is a great place to start checking. A simple leak can send you on a never ending journey of tracking codes
LINK TO 07 IR PHOTO JOURNAL:http://www.zpost.com/forums/showthread.php?t=1303735
LINK TO 06 IB MOD JOURNAL:http://www.zpost.com/forums/showthread.php?t=403119 |
02-04-2012, 08:09 AM | #10 | |
2435
Rep 11,669
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
02-04-2012, 01:49 PM | #11 | |
56
Rep 1,739
Drives: 2008 Z4MC
Gets to the point where u just want to line up everyone and Check for leaks X2 |
02-04-2012, 05:17 PM | #13 |
2435
Rep 11,669
be sure to re-torque at the header flange as well.
