GetBMWParts
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      01-30-2012, 11:40 PM   #1
thehank
11
Drives: e90
Confirmed engine
Cant list the source....
INLINE 6 cylinder with 3 turbos, 1 of them being electric.
      01-31-2012, 07:24 AM   #2
Uli_HH
Uli_HH's Avatar
Germany
106
Drives: AW M3 E90)/ 523i Touring
NO ... an electric Turbo doesn´t exist , this people are misunderstandig the BMW patent. In this patent the E-Motor drives the Turbosystem directly and not by air like an electric supercharger !!!
There are only two alternatives:
- I6 with 1 greater TwinScroll and "eTurbo" - could perhaps be quoted as TriTurbo by BMW terms.
- I6 with 2 TwinScrolls and "eTurbo" - quoted as Biturbo or perhaps OuadTurbo.
Greets Uli_HH
      01-31-2012, 02:09 PM   #3
mapezzul
Special Agent
mapezzul's Avatar
74
Drives: Depends on the day!
Greets Uli_HH
The first is what has been described to me- as the eTurbo does not need two scrolls as it was explained to me.
You might also like to see that the mainstream media has now picked up on our reporting....
Friday I heard from my source and posted elsewhere as was confirmed by your source as well and today Road and Track are reporting the same.
http://www.roadandtrack.com/future-c...ng-2014-bmw-m3
[SIGPIC][/SIGPIC]
      01-31-2012, 03:44 PM   #4
Luis Lahoz
Brazil
Drives: E46 Silver M3
Light car / powerful engine
A M3 should have a strong engine and light weight otherwise we'll mede to get used to see Porsches passing us by...
      01-31-2012, 11:41 PM   #5
thehank
11
Drives: e90
My guess would be a centrifugal style. Basically an electric motor drives a gear reduction impeller. Would probly only be used to spool up the smallest turbo most likely....
They could use higher voltage to run it???? The could use a combo a/c compressor with a built in high voltage alternator that could recharge a small high voltage battery to power it???
      02-01-2012, 01:58 AM   #6
Uli_HH
Uli_HH's Avatar
Germany
106
How I understand the BMW Electric Turbo Drive Patent it works as follows:
The E-Motor is conected with an clutch directly to the turbo scroll.
- at low rpm it drives the turbo alone, so that it could charge the engine despite low exhaust pressure.
- at middle rpm where are enough exhaust pressure it would be disconected via the clutch.
- at high rpm it reduces boost pressure by working as generator and producing energy for the battery ... because of this there would no need for the (sensitive) pop-off-valves.
Maybe someone has a better explanation!?
Greets Uli_HH
      02-01-2012, 12:47 PM   #7
Mbauer
21
Drives: E92 187outx3
Greets Uli_HH
Confirmed everything you listed. It will use a planetary gear set. No blow off valves.
      02-01-2012, 12:48 PM   #8
Mbauer
21
Currently 450hp
      02-02-2012, 01:53 PM   #9
Str8 RippiN
Str8 RippiN's Avatar
48
Drives: E46 ZCP ///M3
hmmm.. i think they should do a light weight higher displacement inline 6 with a twin turbo system. I don't know if the new electric turbos system (guessing) will be appropriate for an ///M
      02-02-2012, 07:19 PM   #10
Deathboy
21
Drives: GT4
Originally Posted by Mbauer View Post
Currently 450hp
i wonder how much torque it will have, considering 560torque in the tri turbo deisel?
      02-02-2012, 10:23 PM   #11
thehank
11
Drives: e90
plenty of torque in the N20
      02-03-2012, 02:23 AM   #12
Uli_HH
Uli_HH's Avatar
Germany
106
450hp / 600Nm
and with "Performence-Package"
470hp / 630Nm
      02-03-2012, 11:06 AM   #13
aajami
aajami's Avatar
432
Drives: Space Gray '09 E92 M3
450hp / 600Nm
470hp / 630Nm
Can you give more details on the Performance Package, Uli? Available at launch? Europe only? Can it be retrofitted at a later date to soften the learning curve for owners?
I'm sure it's far too early to know those answers, but still...
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem
      02-07-2012, 10:57 PM   #14
bimmerjph
bimmerjph's Avatar
121
Drives: 2005 Z4 3.0
So to get this straight the I6 has been confirmed? Thats the most important thing.
      02-07-2012, 11:40 PM   #15
aajami
aajami's Avatar
432
No pun intended...
      02-08-2012, 02:24 PM   #16
bimmerjph
bimmerjph's Avatar
121
Drives: 2005 Z4 3.0
Originally Posted by aajami View Post
No pun intended...
hah. No pun intended.
      02-08-2012, 03:52 PM   #17
BMW269
No_Country
435
Drives: BMW
450hp / 600Nm
470hp / 630Nm
600 Nm seems too much. Rather 550 Nm. Other wise it should either have 475 PS or rev only till 6.000 RPM, unless the TriTurbo does some magic.
      02-09-2012, 03:01 AM   #18
swamp2
swamp2's Avatar
611
Drives: E92 M3
Ugh, potentially different power levels available in the M3 or M4 or whatever it will be called. It will cost BMW precisely $0 (software) to offer different power levels and they will be charging at least $3k (USD) for the little power bump.
Bad BMW, bad.
E92 M3 | Space Gray on Fox Red | M-DCT | CF Roof | RAC RG63 Wheels | Brembo 380mm BBK |
| Vorsteiner Ti Exhaust | Matte Black Grilles/Side Gills/Rear Emblem/Mirrors |
| Alekshop Back up Camera | GP Thunders | BMW Aluminum Pedals | Elite Angels |
| XPEL Full Front Wrap | Hardwired V1 | Interior Xenon Light Kit |
      02-09-2012, 06:21 PM   #19
bimmerjph
bimmerjph's Avatar
121
Drives: 2005 Z4 3.0
Bad BMW, bad.
Everything costs money, even software.
      02-10-2012, 02:25 AM   #20
swamp2
swamp2's Avatar
611
Drives: E92 M3
Yeah, I know, I am in the software business. What I meant, more precisely and in more detail, is that the cost of the physical items in the different engine level cars will be precisely zero. Similarly the cost for BMW to develop the software to increase turbo boost will be miniscule. To be fair a significant amount of testing will need to be done, but that is the only cost. Their profit margin on this options will probably be higher than the margins on most other options.
f80post
