01-30-2012, 10:31 AM | #3 |
72
Rep 1,239
Mine does the same thing and it is not braking. It mainly does it when its cold. I cant remember if it is left or right, but it seems like something needs lube.
● 2015 Cayman S (Current), 2011 1M BSM #297 (Sold), 2008 135i (Sold) ● |
01-30-2012, 12:17 PM | #5 |
72
Rep 1,239
Mine is an odd sound, not so much a squeak and more of mechanical rubbing. Not sure how to explain it, but it does have something to do with the actual turning of the steering wheel. I can make it do it while stopped on a cold morning, so no tire rubbing or anything like that.
01-30-2012, 01:17 PM | #6 | |
684
Rep 5,069
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Garage List 2009 Porsche 911 997.2 [10.00]
2019 Hyundai N (Sold) [10.00] 2013 BMW M3 (Sold) [10.00] 2011 1M Coupe (Sold) [8.78] 2008 E90 M3 (Sold) [8.60] 2007 Z4 Mcpe (Sold) [9.50] 2005 BMW M3 (Sold) [10.00] |
01-30-2012, 01:43 PM | #8 |
NCOIC of Kickin It
78
Rep 946
when i installed my dp's i bent a heat shield so i could stick an extension up there. I forgot to bend it back, and it was rubbing on the boot for the tie rod. it wasnt a squeaking noise, sounded more like a dry bearing.
.02 something to look into. |
01-30-2012, 02:22 PM | #10 |
1760
Rep 1,668
I have it too, never paid any attention to it until this thread..........
IMO it`s a kind of friction in the steeringwheel, only when slow driving or parking..... The question is; is something wrong? |
01-30-2012, 03:30 PM | #11 |
Rep 173
There is a thread in the German 1M Forum regarding the rubbing. BMW already opened a PUMA case and some people already have some parts of the front fender liner replaced. The last thing I read was that screws holding the fender liner / vents in the fender liner can loosen and when re-tightening them the rubbing is gone.
01-30-2012, 03:36 PM | #12 | |
72
Rep 1,239
01-30-2012, 04:43 PM | #13 |
Rep 23
Drives: F15 X5 30d M sport
Yep, mine makes the same noise when turning right on almost full lock. Think I'll get this looked at for peace of mind.
01-30-2012, 05:43 PM | #14 |
79
Rep 1,421
Mine does it intermittently.
-Definitely inside the steering column area. -Started when it got cold. -Sounds like a hookers cot on a Friday night. It sounds like we all have the same issue, very annoying! It went away when I drove to Florida (75 degrees) and came back when I returned home (28 degrees) a few weeks ago.
Dan Parker
01-30-2012, 06:15 PM | #15 | |
684
Rep 5,069
01-30-2012, 07:08 PM | #16 |
116
Rep 3,070
Never had it but it may just confirm the problem if the lower temperature is the trigger cause I got the car in Southern Hemisphere's spring to summer. Smells like some kind of a hydraulic problem to me. Hope u guys will figure it out or BMW will tell us what it is.
01-31-2012, 12:28 AM | #18 | |
684
Rep 5,069
02-05-2012, 03:49 PM | #19 |
Rep 23
Just a quick me too. On full lock, while turning, when cold. Sound is a fluttery creak. Not easy to explain in words. First noticed a couple of months back. Temperature around 10 degrees. Definitely sounds to be coming somewhere from the steering column. Andy.
02-06-2012, 07:38 AM | #21 |
CW2
27
Rep 440
Drives: 1SMC - traded away
+1. Same here. I'm not too worried about it yet. See if it goes away in warmer weather or if it progresses.
Good-bye, ol' Paint...
