01-13-2012, 08:56 AM | #1 |
11
Rep 190
Heading to strip tonight. Anyone done Map 7 for N55?
2012 135i 6MT. 2500 miles, JB stage 2, catless DP. Going to run 4 gallons of MS109 and 2 gallons 93. Can't find much info on Map 7 on N55 other than E85 mix results.
What a difference Map 7 made with my N54 on 100 oct, hoping the same for tonight! I'll let you know results! |
01-13-2012, 05:50 PM | #4 |
The Stig!
54
Rep 889
Drives: 2008 135i 6MT
Good luck man! Anxiously waiting, and also jealous you have a track open where you live! I am chomping at the bit to run mine!
2008 135i - FBO + JB4 15ohm + Water Meth
01-14-2012, 09:48 AM | #5 |
11
Rep 190
Alright, I'm number 1769 on the slip. 12.8 @ 111 mph!
I'm satisfied with the times, as there was little grip on the track last night. Everyone was having issues. Pulled a 2.0 60 ft, however, had to feather throttle in 2nd and 3rd to keep traction. If I would've made more passes, I'm sure 12.6 or so may have been possible. |
01-14-2012, 09:41 PM | #9 |
11
Rep 190
MS109 was the plan. Which I will try next time. After I reduce boost in first and second gear!
Instagram: "mattyates85" FB: "Matt Yates"
2013 335iS DCT, Alpine/Saddle JB4, BMS Flash, DCI, RECORD 1/4 JB4/Flash ONLY: 11.9 @118 mph After Dp's installed: 11.57 @120 mph(best trap 121 mph) |
01-16-2012, 01:48 PM | #11 |
11
Rep 190
It was a late model Mustang with Drag tires and fully set up. I'd imagine he wouldve ran low 11's. Somehow, i got squezzed in with some event they were running that night, I went up against some pretty set up cars. Hard to launch when you have some V8 with open exhaust two-stepping next to you!
