01-09-2012, 11:32 AM | #1 |
Rep 49
Strange Winter Tire Tread Deformation
I bought a set of four 205/50/17, XL load rating Conti Extreme Winter Contacts from Tire Rack about a month and half ago. Checking my tire pressures the other day, I noticed that the rear tread blocks appear to be permanently deformed. They are bent backwards and the sipes are open. See pics below of front and rear to get an idea of how noticeable it is. I've never seen this before on any winter tire I've even owned. Not sure what could be causing this since other than the occasional spirited acceleration into traffic, I have taken it pretty easy on these things. The last picture is of the front, which shows that they are still like new. I have about 1500 miles on them and there is no noticeable wear other than this.
01-09-2012, 11:16 PM | #2 |
Car Geek
3634
Rep 3,600
Sprited driving on a winter tyre in warm temperatures will cause that amount of wear, as the tread blocks soften and massively distort. It really is about overheating the rubber when the tyre is not in it's optimum temperature range. My son and I managed to overheat a set of Dunlop Star Spec summer tyres on my Z4M at autocross this summer when the temperature was 35°C (95°F). We wore away 40% of the tyre tread in about 24km (15 miles) of runs with beads of the tread rolled from the edges of the tread blocks into the grooves between the blocks.
01-10-2012, 09:37 AM | #3 | |
Rep 49
Thanks, but I definitely don't drive these in a spirited fashion. About the most abuse these see is when I get on it to merge onto the highway. I understand that warmer, dry weather is not good for the life of winter tires, and as such I have driven so slowly since putting these on that it has actually started to annoy me. I really wanted my winter setup to last three years, that's why I've babied them.
I'm curious if this will cause issues with traction when we finally get snow? Quote:
01-10-2012, 09:45 AM | #4 | |
Old fart
Rep 107
Which direction they are sipes open, to forward where tyre rotates when you drive forward or backwards. They should be backward "open" because it rotates forward so sipes elapse more of the front of sipes.
But you can check is every tyre right way on the wheel, friction tyres have allmost allways rotate direction so when you assembly tyre's on wheel you have to take a look that every tyre is right way. 2 right, 2 left. There is arrow in sidewall or color dot's inner and outer sidewall or text. Quote:
When you have new friction tyre's or studded tires they should get about 500 km peaceful driving first so tyres settle and they give best traction. Last edited by Järppä; 01-10-2012 at 09:58 AM.. |
01-10-2012, 10:40 AM | #5 |
Rep 49
[QUOTE=Järppä;11121539]Which direction they are sipes open, to forward where tyre rotates when you drive forward or backwards. They should be backward "open" because it rotates forward so sipes elapse more of the front of sipes.
They "point" backwards. In other words, the tread is deformed in the direction of travel, which makes sense since I drive forward most of the time But you can check is every tyre right way on the wheel, friction tyres have allmost allways rotate direction so when you assembly tyre's on wheel you have to take a look that every tyre is right way. 2 right, 2 left. There is arrow in sidewall or color dot's inner and outer sidewall or text. Tires are definitely mounted correctly. There is an outside to the tire, but they are not directional, which is nice! I'm thinking it's the torque that simply crushed these things. The tread on these tires was probably the softest I've ever seen on a winter tire. Reviews of this tire, particularly from 1er owners, were not favorable as far as driving dynamics. Reviewers said the tires did their job well as far as winter tires go, but outside of deep snow or ice, made the car feel very unstable, to the point of being dangerous. Of all the winter tires I've owned, I would have to say these have been the worst as far as the squirmy feeling, but I kept them as the price was good and by most accounts, they deliver when the white stuff falls. I felt that driving slow for three or four months was a fair tradeoff for keeping my car in one piece. Since we have not had an inch of snow all winter here, I have to say I so regret buying these instead of more performance-oriented runflat snows. |
01-10-2012, 01:14 PM | #6 | |
European Editor
10589
Rep 22,992
Fleethammer - a strange question but are these tires unidirectional? Maybe they were mounted backwards - on your alloys? Check the tire sidewalls. Also... our cars put out so much power. Its not that hard to see some wear from soft snow tires. Espcially if the weather is warm and your giving the car some "gas/power". I am amazed on how fast my car goes thru (rear)tires. |
01-10-2012, 02:01 PM | #7 |
NCOIC of Kickin It
78
Rep 946
they look feathered, which is usually a problem with the vehicles toe? is there any reason the alignment would be out of whack? recent modifications? I'd get the alignment rechecked just to be safe.
01-10-2012, 02:14 PM | #8 |
European Editor
10589
Rep 22,992
^^^Good point. On my car, I had the aligment checked and the LR toe was way off. The alignment made a big difference in the way the car tracked at very high speeds (over 130 mph). Post alignment the car was less twitchy. Alignments are needed from time to time. At least to double check there is no problem with the suspension.
01-10-2012, 05:05 PM | #9 | ||
Rep 49
As for any alignment issues, with the few miles I've driven, coupled with the slow speeds, I can't see this really happening, even if the alignment was way off. I bought the car in late July as a CPO, and it tracks perfectly. The brand new OEM run flats the dealer put on it made it through some hard driving in the summer and fall just fine with normal, even wear. There is literally no scrubbing, feathering, or inside or outside edge wear. I'm really starting to think that these tires are not up to the task for this application. |
01-10-2012, 11:01 PM | #10 |
Car Geek
3634
Rep 3,600
With 205mm wide rear winter tyres (that are not performance orientated, such as Michelin PA3 or Pirelli Sottozero tyre), in above freezing temperatures, using the torque of the 135i will flex the tread blocks until they are pressed firmly into the adjacent block and wear off the edge that is flexed into the road, as you describe.
If you have seen the traction control light flash more than a couple of times or just used full throttle every so often with this size and type of winter tyre, I'd be surprised not to see this amount of uneven wear within 2000km or so on a 135i. Probably 10,000km (6,000 miles) will be the maximum usable tyre life (4mm minimum tread depth). |
01-11-2012, 07:14 AM | #11 | |
23
Rep 475
And don't be so sure about CPO and alignment. I just turned in my lease. I was running camber plates up front. I've removed them just before turning in the car. The car is still tracking straight and there isn't any scrubbing noticeable even though I know that the front toe is completely out of whack. |
01-12-2012, 08:57 AM | #12 |
Rep 49
Well I finally got to try these out in winter weather. We had about 3 inches of wintry mix for the morning commute. Not the deepest stuff, but enough that if the summer tires were on I would be in trouble. I have to say these tires are absolute rockstars in the snow/ice. I drove with DSC completely off and barely had any traction issues. It takes a good amount of effort to unhook the car from the road, and in a straight line they just grip and go. It would be nice if I can get them to last two winters now!
01-13-2012, 01:09 AM | #14 | |
Old fart
Rep 107
Five years old friction tyres are horrible when weather is lots of snow and freeze. |
02-02-2017, 09:29 AM | #15 |
213
Rep 1,782
I know this is an old thread but what happed to your snow performance with that kind of wear? My hakkapalitta R2 are doing the same in the rear. It'sprobably due to warmer temperatures and accelerating sometimes.
Koni special active red, eibach pro-kit springs, Remus exhaust, stage 3 intake manifold,Stage 2 AA tune, BMW Short shift kit. Silicon intake pipe. M3 control arms front, M3 rear. ECS trailing arm with whiteline bushings. Purple powerflex subframe bushings. Yellow power flex upper shock mounts. Single mass flywheel OE weight.
02-02-2017, 04:27 PM | #16 |
C2H5OH
3915
Rep 2,144
I would imagine it went to shit. It's the square edges that make a snow/ice tire good. Once the edges are rounded the tires grip is greatly reduced.
Also keep in mind that the XL load rating is not universal. It's simply a heavier load vs the Standard Load version of the tire. The OP's tires really look like the load rating, even though XL, is not correct and on the light side. Finding a tire with more capacity would probably be a good option. |
