12-27-2011, 03:04 PM | #1 |
Rep 183
x drive issues
recently became the owner of an 08 5 series but when i got the car it didn't come with the manuel and every time i turn it on i get this error message. whe i go to get my plates i am going to bring this up to them but just wanted to see if i can find out what it was before hand. any ideas?
http://e60.5post.com/forums/attachme...1&d=1325019779 |
12-31-2011, 01:08 PM | #3 |
87
Rep 1,253
Drives: F10535, E90M3, E30M3, E28M5
Garage List 2017 Alpina B6 GC [0.00]
2014 535xi M Sport [0.00] 2014 X3 3.5 M Sport [0.00] 2011 M3 E90 [9.74] 2007 Z4 M Coupe [7.00] 1990 M3 [9.50] 1988 M5 [10.00] |
OP: My situation is similar but also slightly different. This past Tuesday, I received the same error messages with my Mom's 2010 528xi along with a battery discharging message.
The car hadn't been driven for awhile and the Battery had discharged quite a bit. I received the Battery Discharged Error Message along with the ones you experienced. I called BMW Roadside Assistance, they jumped the car and I immediately drove it to the Local Dealer. Dealer cleared all of the codes and told me these were normal codes for when the battery is discharging or discharged. Good Luck and Congrats on your New 5 Series!
ESS VT-1 550 | M24 Oil Cooler | Fall Line Half Cage | RaceTech 4009W | 6 pt Harness | Lifeline Zero 360 Fire Suppression | Rear Seat Delete | Motion Control DA Dampers w/remote reservoirs | 900/650 Hyperco Springs | RD Sport Sway Bars | Brembo 380 BBK | GC Camber Plates | Hoosier R7 | Eisenmann Sport | Stack Gauges | Painted Challenge Front Lip | Painted ZCP Rear Spoiler | Xpel Ultimate Film | LuxAngelEyes |
12-31-2011, 11:52 PM | #4 |
Rep 183
thanks man, now that you mention it i do remember seeing a battery icon at one point...i'll try using one of those solar battery stimulators and see if that makes a difference
01-01-2012, 09:09 AM | #5 |
87
Rep 1,253
^ My Dealer pulled up a Vehicle Driving History and pointed out that Mom's 528xi was averaging 1-2 miles per trip during the last 36 trips. Not enough to charge the Battery.
I have a Battery Tender for my M3 (stored during the Winter). If your Solar Powered thing doesn't work, you may consider a tender. Saw you're at the Jersey Shore, I visit Family in SH often...... Kind regards, Chris
ESS VT-1 550 | M24 Oil Cooler | Fall Line Half Cage | RaceTech 4009W | 6 pt Harness | Lifeline Zero 360 Fire Suppression | Rear Seat Delete | Motion Control DA Dampers w/remote reservoirs | 900/650 Hyperco Springs | RD Sport Sway Bars | Brembo 380 BBK | GC Camber Plates | Hoosier R7 | Eisenmann Sport | Stack Gauges | Painted Challenge Front Lip | Painted ZCP Rear Spoiler | Xpel Ultimate Film | LuxAngelEyes Last edited by CBS; 01-01-2012 at 08:44 PM.. |
01-02-2012, 09:15 PM | #6 |
Rep 183
i've started using the solar battery tender and it's been good so far and i haven't been driving around as much as i normally do so maybe that's the problem.
yes i grew up on ortley beach, thanks for the help chris! |
01-06-2012, 06:44 PM | #7 |
87
Rep 1,253
^ Glad to learn the solar battery tender works! If you get a chance, would you be able to share the manufacturer info? My "plug-in" tender is only good in my garage and I sometimes have to park at the airport for a week+.
Nothing like the Jersey Shore! Have been going since '90 - Enjoy!
06-01-2012, 12:59 AM | #8 | |
Rep 19
I also do a lot of short trips and go away for weeks at time, the optima can be fully discharged and recharges faster than the OEM battery, it's a marine battery like they use on boats, which don't get driven daily. |
