12-11-2011, 04:54 AM | #1 |
11
Rep 49
Question regarding 128i suspension upgrade
I've been looking around the forum for awhile looking for info on upgading the suspension on my 128i coupe.
I've pretty much settled on Koni FSD's with Eibach Pro-kits and an E93 M3 front sway bar. My question is this: Considering my 128i did not come with the sports package, would it be necessary to get a rear sway bar for this combo? If so, would an E92 M3 bar at the rear be a better setup than the E93 M3? Thanks in advance. |
12-11-2011, 01:12 PM | #2 |
11
Rep 49
I should probably add that I don't plan to track the car. I simply want less body roll and more confidence-inspiring handling, while keeping the relatively neutral handling.
12-11-2011, 02:31 PM | #3 |
Rep 20
I would say start with your Koni FSD's with Eibach Pro-kits and an E93 M3 front sway bar, see what you think and if you feel like you need more then order up the rear one. Sounds like it should be plenty tight the way your doing it, but everyone likes their car a little different.
12-11-2011, 07:00 PM | #4 | |
AutoXer
34
Rep 683
2009 135i, Alpine White, 6MT, M-Sport, iDrive, iPod/USB, Heated Seats, Premium Sound, BMW Assist
12-11-2011, 09:23 PM | #5 |
Vrooom :)
315
Rep 2,602
i think someone said the M3 rear was too thick for the rear. Try getting the sport suspension one.
2014 C7 Corvette Stringray - Laguna Blue - NPP Exhaust - Competition Seats
12-11-2011, 09:27 PM | #6 |
19
Rep 399
Throw a set of coilover and upgrade to m pkg's rear sway bar. Since you have to drop the rear to install the sway bar, would suggest install the rear bushings at the same time. E93 front sway bar and front control arm kit are good investment as well. will cost you a few since you do not have sport pkg and for cosmic, may consider the performance bumps as well.
12-11-2011, 09:44 PM | #7 | |
210
Rep 2,233
12-12-2011, 01:24 PM | #9 |
19
Rep 399
if you are going to do the front end, consider do the front control arm kit as the same time. more neg f camber, and better steering responses, worth the extra bucks i feel.
which bump stops are you talking about? |
12-12-2011, 03:28 PM | #10 |
11
Rep 49
I must have misunderstood you. When you referred to performance bumps, that's what came to mind (bump stops).
As far as the front control arms, from my experience (although not with BMW's) lowering springs cause a bit of neg. camber on their own. From what I've read in here, the front control arms simply add a little neg. camber. Are there other benefits? I'm a little concerned with tire wear, so what kind of front neg. camber can I expect with the front control arms and the drop from the Pro-kits? I would hope not more than -1.0 to -1.5 degrees. |
12-20-2011, 07:10 AM | #11 | |
63
Rep 638
2015 428i Coupe
2009 328i E93 |
